Can't install TensorRT in virtual environment of Jetson AGX Xavier
Description
Hi! I have a Jetson AGX Xavier and I want to install TensorRT in a virtual environment. I follow the instruction in Overview — NVIDIA TensorRT Documentation , and use the deb file in Jetpack4.4( tensorrt_7.1.3.0-1+cuda10.2_arm64.deb). There is no error occur when I install. I try to verify the installation by Verify the installation, and it shows
ii  graphsurgeon-tf                            7.1.3-1+cuda10.2                                 arm64        GraphSurgeon for TensorRT package
ii  libnvinfer-bin                             7.1.3-1+cuda10.2                                 arm64        TensorRT binaries
ii  libnvinfer-dev                             7.1.3-1+cuda10.2                                 arm64        TensorRT development libraries and headers
ii  libnvinfer-doc                             7.1.3-1+cuda10.2                                 all          TensorRT documentation
ii  libnvinfer-plugin-dev                      7.1.3-1+cuda10.2                                 arm64        TensorRT plugin libraries
ii  libnvinfer-plugin7                         7.1.3-1+cuda10.2                                 arm64        TensorRT plugin libraries
ii  libnvinfer-samples                         7.1.3-1+cuda10.2                                 all          TensorRT samples
ii  libnvinfer7                                7.1.3-1+cuda10.2                                 arm64        TensorRT runtime libraries
ii  libnvonnxparsers-dev                       7.1.3-1+cuda10.2                                 arm64        TensorRT ONNX libraries
ii  libnvonnxparsers7                          7.1.3-1+cuda10.2                                 arm64        TensorRT ONNX libraries
ii  libnvparsers-dev                           7.1.3-1+cuda10.2                                 arm64        TensorRT parsers libraries
ii  libnvparsers7                              7.1.3-1+cuda10.2                                 arm64        TensorRT parsers libraries
ii  nvidia-container-csv-tensorrt              7.1.3.0-1+cuda10.2                               arm64        Jetpack TensorRT CSV file
ii  python-libnvinfer                          7.1.3-1+cuda10.2                                 arm64        Python bindings for TensorRT
ii  python-libnvinfer-dev                      7.1.3-1+cuda10.2                                 arm64        Python development package for TensorRT
ii  python3-libnvinfer                         7.1.3-1+cuda10.2                                 arm64        Python 3 bindings for TensorRT
ii  python3-libnvinfer-dev                     7.1.3-1+cuda10.2                                 arm64        Python 3 development package for TensorRT
ii  tensorrt                                   7.1.3.0-1+cuda10.2                               arm64        Meta package of TensorRT
ii  uff-converter-tf                           7.1.3-1+cuda10.2                                 arm64        UFF converter for TensorRT package
However, I can’t import tensorrt in python. What should I do next?
Environment
TensorRT Version: 7.1.3.0
GPU Type: Jetson AGX Xavier
Nvidia Driver Version:
CUDA Version: 10.2
CUDNN Version: No
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
Have you created the virtual environment with --system-site-packages?
You can find more information in the following topic:
Thanks, I’ll try it.
