Can't login in SDKManager - Login token could not be validated
Hello, I’m unable to login with just installed SDKManager on ubuntu 22.04. It says “Login token could not be validated“
Hello dgrigorov,
Does the issue still exist? If yes, could you please attach ~/.nvsdkm/sdkm.log file for more investigation?
sure
sdkm.log (6.6 KB)
Hello dgrigorov,
Are you able to manually login with a browser at https://developer.nvidia.com/account ?
The manual login step is to verify whether you have the privilege to login using sdk manager. Once you’re logged in, you should also be able to see a list of your program memberships at https://developer.nvidia.com/account/programs .
yes, i can log in and i can open both links
Hello dgrigorov,
The login failure is due to a network connectivity timeout when SDK Manager tries to exchange authorization codes for access tokens, even though you can successfully log in manually through a web browser.
What You Need to Do
  • Check Firewall/Antivirus Settings
    • Temporarily disable firewall and antivirus
    • Add SDK Manager to allowed applications if this fixes the issue
  • Check Proxy Settings
    • Configure SDK Manager to use the same proxy settings as your browser
    • Go to SDK Manager Settings → Proxy Settings
  • Try Again
    • Wait a few minutes and retry (might be temporary network congestion)
Thank you EdwardZhou,
strangely enough, it started to work by itself suddenly. I suspect the same - network connectivity.
If it’ll suddenly stop working I’ll try suggested approach.
Thank you!
Hi dgrigorov,
Great to hear it’s working now.
Feel free to reach out if you encounter any other issues!
