When creating a local Nucleus server on your workstation, there’s no authorization e-mail process. The account that you create initially should work immediately.
However, there are a few TCP ports that are bound for specific services. One of these ports is TCP 3009, which on your system may have a conflict.
Can you please run a netstat -a on your computer and see if TCP 3009 is being used (i.e., bound) to another application?
Additionally, you can telnet to localhost on 3009 and if you the connection is accepted?
If it’s not another application using the port, it may be local firewall and/or security software related (blocking the port binding.)
Please review the notes above and let us know what you find.
I looked for port 3009 with netsat -a and could not find any entries with such number.
I also check it with telnet (not sure if I did it correctly though) and it doesn’t show me any connection.
Understood. So that I understand the context correctly, you installed Nucleus Workstation on a server within your environment? Also, the screenshots that you posted above are those from your local computer or from the server?
Thank you for your patience on this issue. I was relocating and was away for a number of days. I’m going to message you directly and let’s see if we can connect on this issue and get you fixed up!
