Can't make CUDA 9.1 samples running
Hello, Im very new to CUDA and having problems with the samples, Im using 4 Tesla C2075 and 1 Quadro 4000, driver version is 390.87 and running CUDA 9.1 on ubuntu 16.04. The samples pops up a window screen very quick and close
Fortunaly the deviceQuery is running, here is the output:
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 5 CUDA Capable device(s)
Device 0: “Tesla C2075”
CUDA Driver Version / Runtime Version 9.1 / 9.1
CUDA Capability Major/Minor version number: 2.0
Total amount of global memory: 6067 MBytes (6361841664 bytes)
MapSMtoCores for SM 2.0 is undefined. Default to use 64 Cores/SM
(14) Multiprocessors, ( 64) CUDA Cores/MP: 896 CUDA Cores
GPU Max Clock rate: 1147 MHz (1.15 GHz)
Memory Clock rate: 1566 Mhz
Memory Bus Width: 384-bit
L2 Cache Size: 786432 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65535), 3D=(2048, 2048, 2048)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (65535, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 8 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: “Quadro 4000”
Total amount of global memory: 1985 MBytes (2081619968 bytes)
( 8) Multiprocessors, ( 64) CUDA Cores/MP: 512 CUDA Cores
GPU Max Clock rate: 950 MHz (0.95 GHz)
Memory Clock rate: 1404 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 524288 bytes
Warp size: 32
Run time limit on kernels: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 5 / 0
Compute Mode:
Device 2: “Tesla C2075”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 9 / 0
Compute Mode:
Device 3: “Tesla C2075”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 10 / 0
Compute Mode:
Device 4: “Tesla C2075”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 11 / 0
Compute Mode:
Peer access from Tesla C2075 (GPU0) → Quadro 4000 (GPU1) : Yes
Peer access from Tesla C2075 (GPU0) → Tesla C2075 (GPU2) : Yes
Peer access from Tesla C2075 (GPU0) → Tesla C2075 (GPU3) : Yes
Peer access from Tesla C2075 (GPU0) → Tesla C2075 (GPU4) : Yes
Peer access from Quadro 4000 (GPU1) → Tesla C2075 (GPU0) : Yes
Peer access from Quadro 4000 (GPU1) → Tesla C2075 (GPU2) : Yes
Peer access from Quadro 4000 (GPU1) → Tesla C2075 (GPU3) : Yes
Peer access from Quadro 4000 (GPU1) → Tesla C2075 (GPU4) : Yes
Peer access from Tesla C2075 (GPU2) → Tesla C2075 (GPU0) : Yes
Peer access from Tesla C2075 (GPU2) → Quadro 4000 (GPU1) : Yes
Peer access from Tesla C2075 (GPU2) → Tesla C2075 (GPU3) : Yes
Peer access from Tesla C2075 (GPU2) → Tesla C2075 (GPU4) : Yes
Peer access from Tesla C2075 (GPU3) → Tesla C2075 (GPU0) : Yes
Peer access from Tesla C2075 (GPU3) → Quadro 4000 (GPU1) : Yes
Peer access from Tesla C2075 (GPU3) → Tesla C2075 (GPU2) : Yes
Peer access from Tesla C2075 (GPU3) → Tesla C2075 (GPU4) : Yes
Peer access from Tesla C2075 (GPU4) → Tesla C2075 (GPU0) : Yes
Peer access from Tesla C2075 (GPU4) → Quadro 4000 (GPU1) : Yes
Peer access from Tesla C2075 (GPU4) → Tesla C2075 (GPU2) : Yes
Peer access from Tesla C2075 (GPU4) → Tesla C2075 (GPU3) : Yes
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.1, CUDA Runtime Version = 9.1, NumDevs = 5
Result = PASS
I was able to run “simpleGL” version, but it was just a red point in a black environment, anyone know why i cant run the samples and how to solve?
cuda 9 doesn’t support Tesla C2075 or Quadro 4000.
Those are both Fermi devices (old) and the last cuda version that supports it is CUDA 8.0
Thank you for the answer, installed CUDA 8.0 and now the samples is working
