can't mount /dev/mmcblk1 on TX2
    [b]I have an emmc memory connect to sdcard interface,and I got /dev/mmcblk1 under /dev when I input "fdisk -l" it display as below :[/b]
Disk /dev/mmcblk0: 29.1 GiB, 31268536320 bytes, 61071360 sectors[ 813.366261] sdhci-tegra 3400000.sdhci: error -19 in autocal-pu-pd-offset settings
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 00000000-0000-0000-0000-000000000000
Device Start End Sectors Size Type
/dev/mmcblk0p1 4097 58724352 58720256 28G Microsoft basic data
/dev/mmcblk0p2 58724353 58732544 8192 4M Microsoft basic data
/dev/mmcblk0p3 58732545 58733056 512 256K Microsoft basic data
/dev/mmcblk0p4 58733057 58733568 512 256K Microsoft basic data
/dev/mmcblk0p5 58733569 58739712 6144 3M Microsoft basic data
/dev/mmcblk0p6 58739713 58739716 4 2K Microsoft basic data
/dev/mmcblk0p7 58739717 58740924 1208 604K Microsoft basic data
/dev/mmcblk0p8 58740925 58741924 1000 500K Microsoft basic data
/dev/mmcblk0p9 58741925 58746020 4096 2M Microsoft basic data
/dev/mmcblk0p10 58746021 58758308 12288 6M Microsoft basic data
/dev/mmcblk0p11 58758309 58762404 4096 2M Microsoft basic data
/dev/mmcblk0p12 58762405 59024548 262144 128M Microsoft basic data
/dev/mmcblk0p13 59024549 59090084 65536 32M Microsoft basic data
/dev/mmcblk0p14 59090085 59221156 131072 64M Microsoft basic data
/dev/mmcblk0p15 59221157 59221668 512 256K Microsoft basic data
/dev/mmcblk0p16 59221669 59745956 524288 256M Microsoft basic data
/dev/mmcblk0p17 59745957 61071326 1325370 647.2M Microsoft basic data
Disk /dev/mmcblk1: 55.1 GiB, 59190018048 bytes, 115605504 sectors
Disklabel type: dos
Disk identifier: 0x60becb51
that has an error “[ 813.366261] sdhci-tegra 3400000.sdhci: error -19 in autocal-pu-pd-offset settings”
I ignore it and use “fdisk /dev/mmcblk1” add a new partition that also has same error “sdhci-tegra 3400000.sdhci: error -19 in autocal-pu-pd-offset settings” then I input n,p,w to add a new partition. finally it has “/dev/mmcblk1p1”.But when I mount this block by “mount /dev/mmcblk1p1 /mnt” it reminder me as below:
[ 1590.029810] sdhci-tegra 3400000.sdhci: error -19 in autocal-pu-pd-offset settings
mount: wrong fs type, bad option, bad superblock on /dev/mmcblk1p1,
missing codepage or helper program, or other error
   In some cases useful info is found in syslog - try
   dmesg | tail or so.
and “fdisk -l” show:
Disk /dev/mmcblk0: 29.1 GiB, 31268536320 bytes, 61071360 sectors[ 1670.996801] sdhci-tegra 3400000.sdhci: error -19 in autocal-pu-pd-offset settings
Disklabel type: gpt
Disklabel type: dos
Device Boot Start End Sectors Size Id Type
/dev/mmcblk1p1 2048 115605503 115603456 55.1G 83 Linux
Can someone help me.What the error " sdhci-tegra 3400000.sdhci: error -19 in autocal-pu-pd-offset settings",and why I can’t mount this block.
Hi zhangbaofeng,
I tried to new partition and mount /dev/mmcblk1p1 to /mnt are no problem.
I think you can try to format your SDcard to FAT format and try again.
It sounds like this is custom eMMC wired to the SD card interface, and not really an SD card. If this is the case, then perhaps there are other settings involved.
