I have read the Thread ‘Can’t boot Ubuntu 14.04 LTS after CUDA 7 install’ already. But I dont use a Laptop computer.
What I did before this problem appeared:
- Fresh install of Kubuntu 16.04.1
- Complete Upgrade to newest packages
- reboot
- CUDA 8 install following this http://docs.nvidia.com/cuda/cuda-installation-guide-linux/#axzz4YsRprotJ procedure. I opted for installing the CUDA *.deb package
- reboot > everything worked fine
- compiled CUDA samples
- run one of the sampled successfully
- installed MATLAB, tested MATLAB
- turned the computer off (shut down)
Next day
- started the computer
- black screen with blinking cursor, after some time black screen, monitor turns off (waited 5min)
- booted into GRUB, started Ubuntu in RECOVERY mode, selected RESUME, booted into X.
- In RECOVERY X worked, NVIDIA drivers were loaded, checked
matlab@Emt-matlab:~$ nvidia-smi
Thu Feb 16 14:18:33 2017
| NVIDIA-SMI 375.26 Driver Version: 375.26 |
| 0 GeForce GTX 960 Off | 0000:01:00.0 On | N/A |
| 20% 48C P5 18W / 120W | 210MiB / 4037MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1365 G /usr/lib/xorg/Xorg 144MiB |
| 0 1588 G kwin_x11 24MiB |
| 0 1597 G /usr/bin/krunner 1MiB |
| 0 1615 G /usr/bin/plasmashell 38MiB |
worked fine
- restarted the computer booted in NORMAL (NON-RECOVERY) mode. > black screen with blinking cursor again.
- So far I am only able to boot into X using RECOVERY mode.
[UPDATE]
- booting into RECOVERY now leads into black screen, the monitor stays turned on. I have not changed anything on the system except running nvidia-bug report.
[UPDATE 2]
- I can startx in tty0 via sudo startx and startx in RECOVERY mode.
[UPDATE 3]
The attached log files seem to be very empty, even though i could run
XX@XX:~$ sudo startx -- -logverbose 6
[sudo] password for matlab:
xauth: timeout in locking authority file /home/matlab/.Xauthority
X.Org X Server 1.18.4
Release Date: 2016-07-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-45-generic x86_64 Ubuntu
Current Operating System: Linux Emt-matlab 4.4.0-62-generic #83-Ubuntu SMP Wed Jan 18 14:10:15 UTC 2017 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-62-generic root=UUID=2f5fd48e-1d3b-41b7-a3ce-2daeaa6dbaa0 ro recovery nomodeset
Build Date: 02 November 2016 10:06:10PM
xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.33.6
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.2.log", Time: Thu Feb 16 15:12:35 2017
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
and
root@XX:~# nvidia-bug-report.sh
nvidia-bug-report.sh will now collect information about your
system and create the file 'nvidia-bug-report.log.gz' in the current
directory. It may take several seconds to run. In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module. While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.
Please include the 'nvidia-bug-report.log.gz' log file when reporting
your bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com'.
Running nvidia-bug-report.sh...Specifying boot ID has no effect, no persistent journal was found
If the bug report script hangs after this point consider running with
--safe-mode command line argument.
complete.
nvidia-bug-report.RECOVERY-ROOT-XSERVER.log.gz (303 KB)
nvidia-bug-report-RECOVERY.log.gz (251 KB)
nvidia-bug-report-NORMAL-SSH.log.gz (64 KB)
