I used L4T-ML to build the Yolov5 development environment and installed the required libraries.
I was able to use detect.py to identify objects in pictures (as shown in the first command in the picture). But when I try to open the camera, it tells me that the camera cannot be opened.
Hi @Mariaa, what camera are you using? Is it MIPI CSI or USB?
When you started the container, if you manually ran docker run did you mount the V4L2 device with --device /dev/video0 ? Note that the docker_run.sh script from jetson-containers does this for you automatically.
It is USB (realsense d435). Sorry I am a newbie, and I failed to understand the meaning of “mount the V4L2 device”, I ran docker run with docker run -id --name=yolov5 --network host --runtime nvidia -w /home/yolo -v /home/nvidia/yolo/yolov5:/home/yolo nvcr.io/nvidia/l4t-ml:r32.5.0-py3
Have I forgotten any steps?
@Mariaa do you now see the /dev/video0 device inside container? Have you been able to test that V4L2 camera outside of camera using similar/same cv2.VideoCapture code to confirm that it’s working?
I see the /dev/video0 inside container now, but I still got a similar error, it looks like there is an extra sentence VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV I tried to use the solution on the Internet export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libv4l/v4l1compat.so, but it doesn’t seem to work.
@Mariaa have you gotten your RealSense camera to work outside of container and that it typically works with V4L2?
