Can't open jetson-io.py on jetson xavier nx
We are working on setting up CAN BUS for the nvidia jetson xavier nx for communication with a sensor.
We have a problem with opening the jetson-io.py program for configuring the GPIO-pins. We have followed this CAN-BUS guide: https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/HR/ControllerAreaNetworkCan.html
and also this guide:
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/HR/ConfiguringTheJetsonExpansionHeaders.html#hr-configuringthejetsonexpansionheaders-runningjetsonio
When running the command " sudo /opt/nvidia/jetson-io/jetson-io.py " we see a window popping up and immediately closing.
We have tried to run " sudo /opt/nvidia/jetson-io/jetson-io.py | less " which gives us the error: No DTB found for NVIDIA Jetson Xavier NX Developer Kit!
We get same error opening other files as config-by-function.py etc.
In the /boot/dtb folder we have stored: kernel_tegra194-xavier-nx-cti-NGX007.dtb kernel_tegra194-xavier-nx-cti-NGX007.dtb.sig tegra194-p3668-all-p3509-0000.dtb
Hi adamgm,
Are you using the devkit or custom board for Xavier NX?
For me, it seems you are using custom carrier board with custom dtb.
Jetson-IO tool is only available for the devkit.
If you are using the custom carrier board, please use devmem command or pinmux spreadsheet to configure for pinmux instead.
