Hi all,
I’m trying to create a portable power source for my Jetson Xavier. I was trying to use this powerbank. Since the USB3 ports of the powerbank only produce 5V unless triggered, I had to use an Arduino to trigger 12V out of the powerbank.
The Arduino was able to trigger 12V out of the power bank but the Jetson Xavier wouldn’t turn on when I plug power into its DC barrel jack. Does anyone know why this is the case? Notably, the power bank feeds 5V into the Jetson Xavier first before the trigger cause it to feed 12V.
Any help would be appreciated. Thank you.
