Can't push metadata in RTSP stream using deepstream-app
• Hardware Platform (Jetson / GPU) - Jetson Orin AGX
• DeepStream Version - 7.0
• JetPack Version (valid for Jetson only) - 6.0
• TensorRT Version - 8.6.2
I am trying to add metadata along with the video to the RTSP output generated by deepstream-app.
  1. I have modified create_udpsink_bin() and start_rtsp_streaming() functions in deepstream_sink_bin.c file.
  2. I am using a custom plugin rtponvifmeta (please see capabilities below) and sending JSON sample metadata from create_udpsink_bin function.
  3. Data flow path for metadata is metasrc → rtponvifmeta → udpsink at 5001 port under create_udpsink_bin.
  4. In start_rtsp_streaming, udpsrc at port 5001 → rtsp server. To achieve this I have modified below
  sprintf (udpsrc_pipeline,
      "( udpsrc name=pay0 port=%d buffer-size=%lu caps=\"application/x-rtp, media=video, "
      "clock-rate=90000, encoding-name=%s, payload=96 \" )"
      "( udpsrc name=pay1 port=%d buffer-size=%lu caps=\"application/x-rtp, media=application, "
        "clock-rate=1000, encoding-name=VND.ONVIF.METADATA \" )",
      updsink_port_num, udp_buffer_size, encoder_name, updsink_port_num+1, udp_buffer_size);
I confirmed that data is received on pay1 using a pad probe callback of type GST_PAD_PROBE_TYPE_BUFFER. However metadata is not received on RTSP url. Using ffmpeg, I can see the two streams as below, and I can play video in VLC on a remote PC using rtsp link generated by deepstream-app.
Stream #0:0: Video: h264 (Constrained Baseline), yuv420p(progressive), 1920x1080, 30 fps, 30 tbr, 90k tbn, 180k tbc
  Stream #0:1: Data: none
rtponvifmeta caps
Pad Templates:
  SINK template: 'sink'
    Availability: Always
    Capabilities:
      application/onvif-metadata
                 parsed: true
  SRC template: 'src'
    Capabilities:
      application/x-rtp
                  media: { (string)application }
             clock-rate: 1000
          encoding-name: VND.ONVIF.METADATA
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
  SRC: 'src'
    Pad Template: 'src'
  SINK: 'sink'
    Pad Template: 'sink'
Can you please help me figure out why rtsp metadata is not received? How I can resolve this issue of metadata not received.
DeepStream sends the encoded stream by udpsink. opensource gst-rtsp-server receives stream by udpsrc, then transmits to clients.
seems you want to add rtsp meta in rtspserver. This issue would be outside of DeepStream. please refer to rtspserver code.
Thanks for your response and sharing the link. I would like to know if the video and metadata has to be in sync to get the metadata in output rtsp stream.
Also from the link you have shared I found below statement at gst-rtsp-server/docs at master · GStreamer/gst-rtsp-server · GitHub.
The pipeline description should contain elements named payN, one for each
 stream (ex. pay0, pay1, ...). Also, for increased compatibility each stream
 should have a different payload type which can be configured on the payloader.
I added payload=98 for metadata as well as pt=98 and still I am not getting metadata in rtsp stream. However, when I try to fetch rtsp stream I get below warning in deepstream-app. Does this mean udpsrc is ignoring payload or pt and therefore I am not see metadata in rtsp output. How can I get rid of this warning.
(deepstream-app:770119): GLib-GObject-WARNING **: 01:15:24.486: g_object_get_is_valid_property: object class 'GstUDPSrc' has no property named 'pt'
gstudpsrc is Gstreamer opensource plugn, which has pt property. how did you set pt=98? if using h264 encoding, the default value should be 96. please refer to Gstreamer opensource rtph264pay.
