Today I try to use deepstream4.0.1 TX2 Jetpack4.2.2.
It can’t get RTSP stream data from camera, maybe it’s the compatibility issue with camera that same with deepstream4.0.
But my question is it can’t quit from program after input ‘q’, I found it’s no response for function ‘destroy_pipeline (appCtx[i])’ ,It’s OK for Deepstream4.0.
log:
sudo ./deepstream-app -c ../../../objectDetector_Yolo/deepstream_app_config_yoloV3.txt
Using winsys: x11
Creating LL OSD context new
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
cb_sourcesetup set 100 latency
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
** INFO: <bus_callback:175>: Pipeline running
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
q
Quitting
----(no response from here!!!)
done:
g_print ("Quitting\n");
for (i = 0; i < num_instances; i++) {
if (appCtx[i]->return_value == -1)
return_value = -1;
destroy_pipeline (appCtx[i]);(**********************no response for this function*******)
g_mutex_lock (&disp_lock);
if (windows[i])
XDestroyWindow (display, windows[i]);
windows[i] = 0;
g_mutex_unlock (&disp_lock);
g_free (appCtx[i]);
if (display)
XCloseDisplay (display);
display = NULL;
g_mutex_clear (&disp_lock);
if (main_loop) {
g_main_loop_unref (main_loop);
