Can't read fuses or boot after burning fuses
Hello Nvidia forums,
I followed the guide Secure Boot — NVIDIA Jetson Linux Developer Guide to create a fuse file, fuse the board, then attempted to boot. After fusing I can’t boot, flash, or read the fuses back.
I’m using Orin AGX Devkit and 36.4.3.
My fuse.xml:
<genericfuse MagicId="0x45535546" version="1.0.0">
  <fuse name="PublicKeyHash" size="64" value="0xXXXXXXXXXXXXXXXXXXXb99515a20d616847320b1513e33398413126693cd433ba32452b6f1c68fae73a5e45c71d77148d5cb435583eeec6510116ef6938cd7d3"/>
  <fuse name="SecureBootKey" size="32" value="0xXXXXXXXXXXXXXXXXXXX63a18b86ca147ce6c8343b2c1dc95fd4791ce5b75414a"/>
  <fuse name="OemK1" size="32" value="0xXXXXXXXXXXXXXXXXXXXcbd87ed4ceee307a3d7baef0c6e94fd7094aa6a7cbb69"/>
  <fuse name="BootSecurityInfo" size="4" value="0x20a"/>
</genericfuse>
Note that I’m using an ECP256 key and I didn’t set production mode.
My command line:
sudo ./odmfuse.sh -i 0x23 -k ../keys/ecp256.pem -S ../keys/sbk.key -X fuse.xml jetson-agx-orin-devkit
My fuse log is attached.
fuseburn.log (99.5 KB)
When I try to flash or read fuses afterward I get a similar error:
sudo ./odmfuseread.sh -i 0x23 -S ~/jetson_install/keys/sbk.key -k ~/jetson_install/keys/ecp256.pem jetson-agx-orin-devkit
The end of the fuse read command looks like this:
[   0.5983 ] Boot Rom communication
[   0.5987 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader_encrypt.bin.signed --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader_encrypt.bin.signed --download bct_mb1 mb1_bct_MB1_sigheader_encrypt.bct.signed
[   0.5991 ] BR_CID: 0xAA012344705DD4431800000016FF01C0
[   0.6001 ] Sending bct_br
[   0.6002 ] Sending mb1
[   0.6005 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader_encrypt.bin.signed --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader_encrypt.bin.signed --download bct_mb1 mb1_bct_MB1_sigheader_encrypt.bct.signed
[   0.6036 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.6047 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.6056 ] Retrieving board information
[   0.6059 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   0.6066 ] Retrieving EEPROM data
[   0.6067 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/calum/jetson_install/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   0.6078 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.6087 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.6091 ] Dumping customer Info
[   0.6095 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   0.6104 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/calum/jetson_install/Linux_for_Tegra/bootloader/custinfo_out.bin
[   0.6107 ] File tmp.bct open failed
Error: Return value 19
Command tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/calum/jetson_install/Linux_for_Tegra/bootloader/custinfo_out.bin
Reading board information failed.
fuseread.log (19.6 KB)
I get a similar error when flashing with
sudo ./flash.sh -v ~/jetson_install/keys/sbk_nox.key -u ~/jetson_install/keys/ecp256.pem  jetson-agx-orin-devkit internal
And the board is stuck in recovery mode:
$ lsusb|grep NVI
Bus 001 Device 031: ID 0955:7023 NVIDIA Corp. APX
So is there any way for me to flash or boot the board, or verify the fuse values? Or is my board bricked?
hello c.blair,
it looks you’re able to parse BR_CID, however, it’s timeout in USB write.
please try disable autosuspend on host PC with below command:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
plug out the USB cable, put jetson back into recovery mode again and plug the usb cable back.
