In JetPack 5, it can send and receive file via Bluetooth with the same board and wireless module. But JetPack 6 has some issues in Bluetooth. Orin can send file to another devices, but cannot receive file from another devices. I found that the Bluetooth controller has no OBEX UUID in bluetoothctl. JetPack 5 :
JetPack 6 :
If I want to send file with my ubuntu laptop, it will appear Object Push error in bluetooth.service.
According to distributor of Real Tech reply, they have tested other modules and found that can’t receive file via Bluetooth.
Are there any changes to Bluetooth in the new kernel version?
So you use AGX Orin developer kit + RTL8822CE module and it works well? Would like to make sure if you have tried the default setup and don’t hit the issue.
We don’t have Intel AX210 and AX200. It looks like it may require to enable additional kernel config or kernel driver. This would need other users to share experience.
By default RTL8822CE module is with AGX Orin developer kit, so you should have it if you have the developer kit. Please check with your team and see if you can have the module for testing and as a reference module.
I have tested the default RTL8822CE with AGX Orin developer kit, it has the same problem with RTL8852BE’s Bluetooth issue. It can send file to other devices, but cannot receive file from another device. Please check it again.
Below are some informations about RTL8822CE module.
We can observe the issue on AGX Orin developer kit with Jetpack 6.0GA. It looks to be an issue in Ubuntu 22.04. Can send file to the other device but cannot receive file. Seems like the request is rejected by the system. The function works fine on 5.1.3 which is Ubuntu 20.04.
We think the kernel driver is good and the issue is in Ubuntu 22.04.
You are right there was a typo. Jetpack 5.1.3 is with Ubuntu 20.04. I have corrected it.
We are checking it and also if you have further idea, please share it. The sample rootfs is Ubuntu 22.04.4. Please let us know if later version fixes it.
The Bluetooth USB dongle can work on x86 in ubuntu 22.04, but cannot work on Jetson AGX Orin in JP5.1.3 and JP6. It can identify Bluetooth device in hciconfig, but I can not up the hci device. Is it not supported on Jetson AGX Orin?
Hi DaneLLL,
I am Derek’s coworker,
We followed your instructions to modify the defconfig on AGX Orin developer kit and re-flashed the system, but we found that many drivers could not be successfully loaded. Below is the dmesg output regarding the errors.
[ 4.428717] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 4.433431] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.433907] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[ 4.434389] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[ 4.434827] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (511:0)
[ 7.351291] pcie_tegra194: disagrees about version of symbol module_layout
[ 7.364625] phy_tegra194_p2u: disagrees about version of symbol module_layout
[ 7.379563] nvme_core: disagrees about version of symbol module_layout
[ 7.393641] typec: disagrees about version of symbol module_layout
[ 7.407776] typec: disagrees about version of symbol module_layout
[ 7.421330] typec: disagrees about version of symbol module_layout
[ 7.435569] tegra_xudc: disagrees about version of symbol module_layout
[ 7.448900] tegra_bpmp_thermal: disagrees about version of symbol module_layout
[ 7.463016] pwm_tegra: disagrees about version of symbol module_layout
[ 7.476498] pwm_fan: disagrees about version of symbol module_layout
[ 8.372856] EXT4-fs (mmcblk0p1): recovery complete
[ 8.373723] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 8.397047] Rootfs mounted over PARTUUID=4c89453a-c6ad-4686-bd41-e987a50cbbfe
[ 8.405673] Switching from initrd to actual rootfs
[ 8.489570] systemd[1]: System time before build time, advancing clock.
[ 15.426967] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 15.429095] pci 0005:00:00.0: Removing from iommu group 55
[ 15.429167] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 15.436768] irq: IRQ289: trimming hierarchy from :bus@0:pmc@c360000
[ 15.477109] tegra-xusb 3610000.usb: Adding to iommu group 56
[ 15.479039] nvidia_modeset: disagrees about version of symbol module_layout
[ 15.504190] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 15.504240] tegra-xusb 3610000.usb: xHCI Host Controller
[ 15.504329] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 15.505273] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 15.505436] tegra-xusb 3610000.usb: irq 127, io mem 0x03610000
[ 18.914636] l4tbr0: port 2(usb1) entered blocking state
[ 18.914649] l4tbr0: port 2(usb1) entered forwarding state
[ 18.914707] l4tbr0: port 1(usb0) entered blocking state
[ 18.914710] l4tbr0: port 1(usb0) entered forwarding state
[ 18.914896] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 26.485523] nvidia_modeset: disagrees about version of symbol module_layout
[ 26.677811] nvidia_modeset: disagrees about version of symbol module_layout
[ 26.857137] nvidia_modeset: disagrees about version of symbol module_layout
[ 27.043704] nvidia_modeset: disagrees about version of symbol module_layout
[ 27.202755] nvidia_modeset: disagrees about version of symbol module_layout
[ 1646.824160] VIN_SYS_5V0: Underflow of regulator enable count
[ 1646.824467] tegra-xudc 3550000.usb: ep 3 disabled
[ 1646.824490] tegra-xudc 3550000.usb: ep 2 disabled
[ 1646.824505] tegra-xudc 3550000.usb: ep 5 disabled
[ 1646.824521] tegra-xudc 3550000.usb: ep 4 disabled
