I met a problem about usb port. In a custom board, the usb2-0 works as expected in OTG when flashing. I also want to use it as an connector to communicate with PC. But when it connected to PC, nothing happen and no dmesg. And my usb2-0 is type-C. My dtb setting is as following:
pads {
usb2 {
clocks = <0x02 0xa5>;
clock-names = "trk";
lanes {
usb2-0 {
status = "okay";
#phy-cells = <0x00>;
nvidia,function = "xusb";
phandle = <0x2b8>;
and
ports {
usb2-0 {
status = "okay";
mode = "otg";
vbus-supply = <0x2b5>; /*"vdd-5v-sys"*/
usb-role-switch;
connector {
compatible = "usb-b-connector\0gpio-usb-b-connector";
label = "micro-USB";
type = "micro";
vbus-gpio = <0x50 0x99 0x01>;
and
xudc@3550000 {
compatible = "nvidia,tegra234-xudc";
reg = <0x00 0x3550000 0x00 0x8000 0x00 0x3558000 0x00 0x8000>;
reg-names = "base\0fpci";
interrupts = <0x00 0xa6 0x04>;
clocks = <0x02 0x109 0x02 0x115 0x02 0x113 0x02 0x110>;
clock-names = "dev\0ss\0ss_src\0fs_src";
power-domains = <0x02 0x0b 0x02 0x0a 0x02 0x0c>;
power-domain-names = "dev\0ss\0host";
nvidia,xusb-padctl = <0x2b7>;
iommus = <0x56 0x0f>;
dma-coherent;
status = "okay";
charger-detector = <0x2b9>;
avdd-usb-supply = <0x2b4>;
phys = <0x2b8>;
phy-names = "usb2-0";
phandle = <0x468>;
xhci@3610000 {
compatible = "nvidia,tegra234-xhci\0nvidia,tegra234-xusb";
reg = <0x00 0x3610000 0x00 0x40000 0x00 0x3600000 0x00 0x10000 0x00 0x3650000 0x00 0x10000>;
reg-names = "base\0fpci\0bar2";
interrupts-extended = <0x01 0x00 0xa3 0x04 0x01 0x00 0xa4 0x04 0x01 0x00 0xa7 0x04 0x0a 0x4c 0x04 0x0a 0x4d 0x04 0x0a 0x4e 0x04 0x0a 0x4f 0x04 0x0a 0x50 0x04 0x0a 0x51 0x04 0x0a 0x52 0x04>;
interrupt-names = "xhci\0mbox\0padctl\0wake0\0wake1\0wake2\0wake3\0wake4\0wake5\0wake6";
clocks = <0x02 0x10a 0x02 0x10b 0x02 0x10c 0x02 0x10d 0x02 0x10e 0x02 0x10f 0x02 0x110 0x02 0x111 0x02 0x113 0x02 0x115 0x02 0x67 0x02 0x0e 0x02 0x64>;
clock-names = "xusb_hs_src\0xusb_host\0xusb_core_superspeed_clk\0xusb_falcon_src\0xusb_falcon_host_clk\0xusb_falcon_superspeed_clk\0xusb_fs_src\0xusb_fs_host_clk\0xusb_ss_src\0xusb_ss\0pll_u_480m\0clk_m\0pll_e";
power-domains = <0x02 0x0c 0x02 0x0a>;
power-domain-names = "xusb_host\0xusb_ss";
interconnects = <0x03 0x4a 0x03 0x4b>;
interconnect-names = "dma-mem\0dma-mem";
iommus = <0x56 0x0e>;
dma-coherent;
status = "okay";
phys = <0x2ba 0x2bb 0x2bc 0x2bd 0x2be>;
phy-names = "usb2-1\0usb2-2\0usb3-0\0usb3-1\0usb3-2";
phandle = <0x469>;
BR
Salutonn
