Can't Resolve Racing I'm getting random, different outputs...
I’m trying to implement a matrix orthonormalization algorithm. There’s no problem with small matrices but I’m getting weired outputs with larger inputs. I suppose this is due to some racing but I have considered everything to avoid any memory hazard. Threads in my algorithm need to modify the input matrix (a global variable). So I use __threadfence() to flush and make sure every other thread gets the new values. But still, although I have tried to consider everything, I get wrong results sometimes. It produces the right answer most of the time though. Last time I tested, I got 11 correct results out of 15 times of running the application.
Here is the kernel code:
#include <math.h>
The following function implements the stabilized Gram–Schmidt orthonormalization.
Matrix "a" will contain the orthogonal matrix "Q" at the end.
__device__ unsigned int flag = 0; // number of orthogonalized columns
__global__ void orthonormalize(float* a) {
	__shared__ float s[BLOCK_DIM];
	int tid = threadIdx.x;
	int idx = blockIdx.x * blockDim.x + tid;
	float me;
	int i = 0;
	while (i < blockIdx.x) {
		if (flag > i) {
			float vi = a[i * blockDim.x + tid];
	 		me = a[idx];
	 		s[tid] = vi * me;
	 		__syncthreads();
	 		int k = blockDim.x / 2;
 			while (k != 0) {
				if(tid < k)
					s[tid] += s[tid + k];
				__syncthreads();
				k /= 2;
			if (blockDim.x % 2 != 0 && tid == 0)
				s[0] += s[blockDim.x - 1];
	 		__syncthreads();
	 		a[idx] -= s[0] * vi;
	 		__threadfence_block();
	 		i++;
	me = a[idx];
	s[tid] = me * me;
	__syncthreads();
	i = blockDim.x / 2;
	while (i != 0) {
		if(tid < i) {
			s[tid] += s[tid + i];
		__syncthreads();
		i /= 2;
	__syncthreads();
	a[idx] = me / sqrtf(s[0]);
	__threadfence();
	if (tid == 0) flag++;
	__threadfence();
I have also attached this kernel code along with a testing host code.
Any ideas what I’m missing?
orthonormalize.zip (1.34 KB)
I have not gone through your code…
__threadfence() dont guarantee block synchronization… If you are trying to schronize blocks, you are not going anywhere.
Yea I know that and I’m not trying to sync blocks. I use threadfence right after updating the global variable to make every thread read the new values from that point on.
