Hello! I’ve been using Ubuntu 20.04 alongside ROS Noetic for my course in my previous laptop which had an AMD CPU with an iGPU, so never really had to struggle with drivers. I had to get a new laptop (ASUS TUF Gaming F15 2022) which has an Intel i7-12700H and an RTX 3060. The 12th gen processor (as far as I know) means I had to install a newer kernel (which was a hassle by itself because the laptop wouldn’t boot to GUI (or not at all in some cases, had to do a minimal install with no updates and no extra drivers/proprietary software and unplug the ethernet cable during the whole process)).
I ended up using mainline to install the 5.16.20 kernel via the Ctrl + Alt + F2 CLI, but it still didn’t boot into GUI until I sudo apt installed the nvidia drivers 470. Seeing that this worked I would have thought that the NVIDIA GPU was the one rendering the desktop, but when I run nvidia-smi it outputs the “not installed or not running” error.
**aaron@lap-aarongrt:~$** sudo lshw -C display
[sudo] password for aaron:
*-display UNCLAIMED
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: iomemory:600-5ff iomemory:620-61f memory:5f000000-5fffffff memory:6000000000-61ffffffff memory:6200000000-6201ffffff ioport:3000(size=128) memory:60000000-6007ffff
*-display UNCLAIMED
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 0c
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list
resources: iomemory:620-61f iomemory:400-3ff memory:622e000000-622effffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
**aaron@lap-aarongrt:~$** nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:6371): GLib-GObject-CRITICAL **: 18:28:45.665: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 18:28:45.667: PRIME: No offloading required. Abort
** Message: 18:28:45.667: PRIME: is it supported? no
I spent the whole yesterday trying out solutions, including the prime-select nvidia one and a bunch more.
I’ll be including the nvidia-bug-report.sh output file incase it’s of use to you guys. If you have any clue of what’s going on please let me know!
Aarón RT
Edit: I disabled Secure Boot and Fast Boot and am running Dual Boot with Windows11
nvidia-bug-report.log.gz (81.0 KB)
