Can't run Riva tts
Hardware - GPU RTX3060
Hardware - CPU AMD Ryzen 5 3600-6core
Operating System Gigabyte
Riva Version
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
When I tried to bash riva_start.sh, this happens :
$ bash riva_start.sh
Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
ae38663e0f590e88948844ad62613c77d9c218f4c2f20ef24a48b566864e0dd8
OCI runtime exec failed: exec failed: unable to start container process: exec: “C:/Program Files/Git/usr/bin/grpc_health_probe”: stat C:/Program Files/Git/usr/bin/grpc_health_probe: no such file or directory: unknown
Waiting for Riva server to load all models…retrying in 10 seconds
Health ready check failed.
Check Riva logs with: docker logs riva-speech
I already tried to bash config > clean and rebash riva_init.sh
**but still have same issue. **
below is the logs of container when I bash riva_start.sh:
2023-04-28 10:52:05 ERROR: ld.so: object ‘[FATAL’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘tini’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘(7)]’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘exec’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘C’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘/Program’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘Files/Git/usr/bin/bash’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘failed’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘No’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘such’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘file’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘or’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05 ERROR: ld.so: object ‘directory’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:05
2023-04-28 10:52:05 ==========================
2023-04-28 10:52:05 === Riva Speech Skills ===
2023-04-28 10:52:05
2023-04-28 10:52:05 NVIDIA Release 22.07 (build 42007163)
2023-04-28 10:52:05 Riva Speech Server Version 2.4.0
2023-04-28 10:52:05
2023-04-28 10:52:05 Copyright (c) 2018-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
2023-04-28 10:52:05
2023-04-28 10:52:05 Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
2023-04-28 10:52:05
2023-04-28 10:52:05 This container image and its contents are governed by the NVIDIA Deep Learning Container License.
2023-04-28 10:52:05 By pulling and using the container, you accept the terms and conditions of this license:
2023-04-28 10:52:05 https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
2023-04-28 10:52:05
2023-04-28 10:52:05 I0428 01:52:05.632777 90 metrics.cc:650] Collecting metrics for GPU 0: NVIDIA GeForce RTX 3060
2023-04-28 10:52:05 I0428 01:52:05.688788 90 tritonserver.cc:2123]
2023-04-28 10:52:05 ±---------------------------------±---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+
2023-04-28 10:52:05 | Option | Value |
2023-04-28 10:52:05 > Riva waiting for Triton server to load all models…retrying in 1 second
2023-04-28 10:52:06 > Riva waiting for Triton server to load all models…retrying in 1 second
2023-04-28 10:52:05 | server_id | triton |
2023-04-28 10:52:05 | server_version | 2.21.0 |
2023-04-28 10:52:05 | server_extensions | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_memory binary_tensor_data statistics trace |
2023-04-28 10:52:05 | model_control_mode | MODE_NONE |
2023-04-28 10:52:05 | strict_model_config | 1 |
2023-04-28 10:52:05 | rate_limit | OFF |
2023-04-28 10:52:05 | pinned_memory_pool_byte_size | 268435456 |
2023-04-28 10:52:05 | cuda_memory_pool_byte_size{0} | 1000000000 |
2023-04-28 10:52:05 | response_cache_byte_size | 0 |
2023-04-28 10:52:05 | min_supported_compute_capability | 6.0 |
2023-04-28 10:52:05 | strict_readiness | 1 |
2023-04-28 10:52:05 | exit_timeout | 30 |
2023-04-28 10:52:05
2023-04-28 10:52:05 I0428 01:52:05.688832 90 server.cc:247] No server context available. Exiting immediately.
2023-04-28 10:52:05 error: creating server: Invalid argument - --model-repository must be specified
2023-04-28 10:52:06 ERROR: ld.so: object ‘[FATAL’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘tini’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘(7)]’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘exec’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘C’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘/Program’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘Files/Git/usr/bin/bash’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘failed’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘No’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘such’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘file’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘or’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:06 ERROR: ld.so: object ‘directory’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘[FATAL’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘tini’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘(7)]’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘exec’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘C’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘/Program’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘Files/Git/usr/bin/bash’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘failed’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘No’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘such’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘file’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘or’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 ERROR: ld.so: object ‘directory’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-04-28 10:52:07 > Riva waiting for Triton server to load all models…retrying in 1 second
2023-04-28 10:52:08 > Triton server died before reaching ready state. Terminating Riva startup.
2023-04-28 10:52:08 Check Triton logs with: docker logs
2023-04-28 10:52:08 /opt/riva/bin/start-riva: line 1: kill: (90) - No such process
Hi @yeriel29
Thanks for your interest in Riva
I may be wrong but initial guess looks like some problem within Docker Volume
Kindly request to run bash riva_clean.sh and try again
Also we kindly request to share the output of the below command
docker volume ls
before and after running bash riva_clean.sh
Thank you for reply!
I tried bash riva_clean.sh and run init and start again but still have a same issue.
Here is the output from command:
Before bash riva_clean.sh:
$ docker volume ls
DRIVER VOLUME NAME
local riva-model-repo
After bash riva_clean.sh:
$ docker volume ls
DRIVER VOLUME NAME
I am having the same problem on windows. Did you find the solution ?
No, still struggling with same issue.
I’ve delete all data about Riva and re-bash everything, but still same. Hope I can find a reason to solve it.
I have tried following this on ubuntu and windows and ubuntu app on windows. Everywhere there is a separate issue preventing from running the server. I think Ubuntu app on windows was where it progressed the most then got stuck.
Follow this process:
Then this
https://ngc.nvidia.com/setup/installers/cli
Then initialize and start riva via shell … see maybe it helps. It hasn’t for me. Sometimes it says GPC key is invalid, on ubuntu OS, sometimes, it cant store credentials. On windows i get the error you posted about.
Hey, i got it working atleast from that error. Do the following:
distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add -
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit
sudo systemctl restart docker
then bash riva_init.sh
It takes so much time, if you are running it on your PC … since the version is for datacenter with cluster of GPUs. I was running this on laptop and gave up
Hi @bhatt226
Apologies for the delay, Thanks for your kind inputs and feedback, Really appreciate your proactive feedback
Yes, the nvidia-container-toolkit is required for docker to leverage GPU
@yeriel29 , Apologies for the delay
Can you try setting up nvidia-container-toolkit and try
https://docs.nvidia.com/datacenter/cloud-native/container-toolkit/archive/1.12.1/install-guide.html#setting-up-nvidia-container-toolkit
hello im facing the same problem on windows 10
and i couldn’t find a way to install nvidia container toolkit on windows 10
