Can't see the command history option in windows list
I am trying to follow the tutorial to create a cube using my extension in python, but I can’t see the command history window anywhere
@iwarsame38 you can find the extension in the extension manager (iirc, it’s called something like “command util” or similar). simply install and/or enable it; furthermore, if you use it often, you can toggle on “autoload” on it.
Found it, it’s an extension called ‘Command Utils’. Thank you!
