Can't set GPIO default value
Hello NVIDIA,
我遇到个问题,感觉这个GPIO默认值不受控制,我在Linux_for_Tegra\bootloader\generic\BCT\tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi 已经更改pinmux了,也在Linux_for_Tegra\bootloader\tegra234-mb1-bct-gpio-p3767-dp-a03.dtsi设置默认值了,我开机读寄存器感觉设置的不对:
希望是开机将PH.00设置输出为高,PG.06设置输出为低,都是双向高阻态
root@nv-desktop:/home/nv# busybox devmem 0x02434040
0x00000050
root@nv-desktop:/home/nv# busybox devmem 0x02434080
0x00000051
root@nv-desktop:/home/nv# gpioinfo |grep PH.00
line 43: “PH.00” unused output active-high
root@nv-desktop:/home/nv# gpioinfo |grep PG.06
line 41: “PG.06” unused output active-high
root@nv-desktop:/home/nv# cat /sys/kernel/debug/gpio|grep “PH.00”
gpio-391 (PH.00 )
root@nv-desktop:/home/nv# cat /sys/kernel/debug/gpio|grep “PG.06”
gpio-389 (PG.06 )
我用配寄存器的方式试过,必须高阻态+内部上下拉才能正确点亮熄灭
root@nv-desktop:/home/nv# busybox devmem 0x02434040 w 0x54
root@nv-desktop:/home/nv# busybox devmem 0x02434040 w 0x58
root@nv-desktop:/home/nv# busybox devmem 0x02434080 w 0x54
root@nv-desktop:/home/nv# busybox devmem 0x02434080 w 0x58
DTS config:
                        soc_gpio19_pg6 {
                                nvidia,pins = "soc_gpio19_pg6";
                                nvidia,function = "rsvd1";
                                nvidia,pull = <TEGRA_PIN_PULL_NONE>;
                                nvidia,tristate = <TEGRA_PIN_ENABLE>;
                                nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                                nvidia,lpdr = <TEGRA_PIN_DISABLE>;
                        soc_gpio21_ph0 {
                                nvidia,pins = "soc_gpio21_ph0";
                                nvidia,function = "rsvd0";
excel config:
目前的问题:
  1. 为什么dts配置后,默认值不对?
  2. gpioset也感觉不受控制,设置后,用devmem读寄存器值没变
root@nv-desktop:/home/nv# gpioset --mode=wait `gpiofind 'PG.06'`=0
root@nv-desktop:/home/nv# gpioset --mode=wait `gpiofind 'PG.06'`=1
0x00000451
hello liteblue,
may I know which Jetpack release version you’re working with?
and… the board SKU of your Orin NX?
My BSP package version is jetpack6.0 , r36.3.
Board ID(3767) version(301) sku(0000) revision(G.1)
Chip SKU(00:00:00:D3) ramcode(00:00:00:01) fuselevel(fuselevel_production) board_FAB(301)
please see-also Topic 301171 to apply the patch for verification.
Hi Jerry,
应用补丁后gpio工具不会导致pinmux变化了,但是gpioget好像得到的值与实际测量不同,以下set为0后,读到的是1,实际测量刚开始是0V,随后几秒后变成1.2V。
gpioget gpiofind 'PCC.01'
1
怎么读GPIO寄存器的?我可以看下是不是被正确改了
Hi Jerry,
gpioget `gpiofind 'PCC.01'`
1
gpioset为1后,退出gpioset程序,会在十多秒后从1.8V降到1.2V。
pinmux始终未变化
# busybox devmem 0x0c302050
0x00000041
对应GPIO寄存器怎么查找的?我可以看下是不是被正确改了
hello liteblue,
(1) please set the GPIO with --mode=wait for keeping its state.
(2) pinmux it’s the default settings of bpmp, it’s not used by kernel stage.
