Hi all,
maybe it’s me, but I cannot understand the relations between the tegra_sinterface/port-index in CSI, sensor definition and VI.
There is a drawing about port-index that it’s clearly incomplete, and also the other explanations are not really helpful.
Can I get some clarification please?
Sensor Programming
hello albert.burbea,
please see-also forum topic for the mappings of the NVCSI and VI port-index, Topic 69753.
Hi, yes, I found that document but it wasn’t much better. I’ve also asked for help to the vendor, but definitely we need something clearer. Thanks.
may I know which part you did not understand?
or.. could you please give an example of board schematic, let’s review your port bindings.
HI Jerry,
In our design we are connected to CSI0, no I2CMUX.
I am getting all the time this message when I boot the system
zedx 0-0020: Driver Version : v1.3.0
zedx 0-0020: Probing v4l2 sensor.
zedx 0-0020: tegracam sensor driver:video1_v2.0.6
zedx 0-0020: Enable gmsl for channel 0 and id 0
r8169 0008:01:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 0-0020 bound
zedx 0-0020: Detected ZED-X sensor
zedx 0-0020: zedx_probe: Serial Number : 48321271
zedx 0-0020: zedx_probe: CHANNEL: 0 ID: 0
Video device name is video0
Video device ID is 0
t194-nvcsi 13e00000.host1x:nvcsi@15a00000: Failed to create device link ( 13e00000.host1x:nvcsi@15a00000: Failed to create device link (0x180) with 0-00200x180) with 0-0020
Same for camera 0-0038
The cameras addresses are actually correct (Bus I2C0, addresses 0x20 and 0x38)
Attaching full dmesg and device tree from /proc/device-tree
dmesg.txt (84.4 KB)
proc_device-tree.txt (392.0 KB)
Then, running
v4l2-ctl -d /dev/video0 --stream-mmap
I get only timeout and resetting of sensors.
Thanks for your help!!
am I understand your camera connections as below correctly?
ZED-X → max9295 → max9296 → CSI0?
if yes.. please revise the port-index to 0x0
you may see-also Jetson Virtual Channel with GMSL Camera Framework since you’re going to have two camera for sharing the CSI port.
HI,
yes, you are correct. I moved the port-index to 0x0 and the tegra_sinterface to serial_a.
Now I am facing this issue:
in dmesg:
tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
The message is not really clear. What can this “ivc channel driver” be?
Interestingly, it looks that is not related directly to the camera, since also the dbg and diag channels are complaining about it.
sorry for late reply, I’ve losing your status update.
could you please check To verify the port binding result? there should be video node created if you’ve correct port bindings.
the video devices are created, but - still - no frame is grabbed.
I saw that also in R36.3 produces the “ivc channel driver missing”
I am a bit at loss.
it’s IVC devices to communicate with rce-fw.
please check whether you’re able to parse the camera device capability. i.e. $ v4l2-ctl -d /dev/video0 --list-formats-ext
please also assign the sensor supported formats into v4l pipeline for testing the stream.
for instance,
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100
is it possible to arrange hardware resources to probe the MIPI signaling?
you may check whether sensor is outputting the frames to CSI channel.
besides,
let’s follow the steps to enable VI tracing logs for more details.
modprobe rtcpu_debug #for JP-6.1 or later.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
