Can't unroll loop: unexpected call OPs
When compiling this kernel
__global__ void kernel(int *f) {
	int i;
	#pragma unroll
	for(i=0; i <= 8; i++) {
 	f[i] = 48 >> i;
	if(i > 32)
 	__threadfence_block();
I’m getting this error:
/home/nikratio/test.cu(5): Advisory: Loop was not unrolled, unexpected call OPs
Removing the if clause fixes the problem. But why is that? Unrolling this seems really straightforward to me…
The “unexpected call OP” in this case is the call to __threadfence_block().
Yes, but why is this preventing unrolling of the loop?
I use cuobjdump to check assembly code, nvcc remove __threadfence_block,
and have following equivalent code
int i = 0 ;
while{
    int k = 48 ;
    f[0] = k >> i ;
    f++ ;
    i++ ;
    if ( i > 8 ) break ;
I have no idea why nvcc cannot unroll the loop.
However if you comment
if ( i > 32 )
then nvcc can unroll the loop.
I think the problem is __threadfence_block()
#pragma unroll
for(int i = 0 ; i <= 8 ; i++){
    f[i] = 48 >> i ;
cantnot be unrolled. __threadfence() has the same problem, but __syncthreads() is fine.
