Suggest you to run with virtual environment.
NVIDIA recommends setting up a python environment using miniconda. The following instructions show how to setup a python conda environment.
- Follow the instructions in this link to set up a conda environment using a miniconda.
- Once you have installed
miniconda, create a new environment by setting the Python version to 3.7.
conda create -n launcher python=3.7
- Activate the
condaenvironment that you have just created.
conda activate launcher
Once you have activated your
condaenvironment, the command prompt should show the name of your conda environment. -
When you are done with you session, you may deactivate your
condaenvironment using thedeactivatecommand:
conda deactivate
- You may re-instantiate this created
condaenvironment using the following command.
