We want to use pin can_gpio2_paa2 (Jetson signal GPIO9/MOTION_INT) and can_gpio2_paa3 (Jetson signal CAN1_ERR) as open-drain outputs, so we added the following pinmux definitions to the device tree
can_gpio2_paa2 {
nvidia,pins = "can_gpio2_paa2";
nvidia,function = "rsvd1";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
nvidia,open-drain = <TEGRA_PIN_ENABLE>;
can_gpio3_paa3 {
nvidia,pins = "can_gpio3_paa3";
nvidia,function = "rsvd0";
But we got this error during boot:
[ 0.722449] tegra186-pinctrl 2430000.pinmux: Config param 0003 (nvidia,open-drain) not supported on group can_gpio2_paa2
[ 0.733811] tegra186-pinctrl 2430000.pinmux: pin_config_group_set op failed for group 26
[ 0.742263] tegra186-pinctrl 2430000.pinmux: Error applying setting, reverse things back
[ 0.750733] tegra186-pinctrl 2430000.pinmux: failed to select default state
It seems the OD field of both pins is prohibited in the pinmux driver t18x/drivers/pinctrl/pinctrl-tegra186.c (flagged with value -1 between value ‘10’ and ‘12’) shown below,
PINGROUP(can_gpio2_paa2, GPIO, RSVD1, RSVD2, RSVD3, 0x3038, 1, Y, -1, 6, -1, 9, 10, -1, 12, Y, -1, -1, Y),
PINGROUP(can_gpio3_paa3, RSVD0, RSVD1, RSVD2, RSVD3, 0x3040, 1, Y, -1, 6, -1, 9, 10, -1, 12, Y, -1, -1, Y),
The TX2 datasheet didn’t seem to mention OD is disallowed when these pins are used as GPIO. Could you please confirm if it’s the case or just a software bug? Thanks.
