I try to download source code using under command in my company network environment.
$ git clone -n git://nv-tegra.nvidia.com/3rdparty/u-boot.git
I set git proxy as follows.
[http]
proxy = http://user:password@proxyserver :port
[https]
Under error show up
Cloning into 'u-boot'...
fatal: unable to connect to nv-tegra.nvidia.com:
nv-tegra.nvidia.com[0: 216.228.121.37]: errno=Connection timed out
My company inhibits git protol, so I try using https protocol as follows.
git clone -n https://nv-tegra.nvidia.com/3rdparty/u-boot.git/
Under error show up
fatal: unable to access āhttps://nv-tegra.nvidia.com/3rdparty/u-boot.git/ ā: gnutls_handshake() failed: Illegal parameter
My question is that ānv-tegra.nvidia.com ā supports to access with https protocol?
Sorry error message is mistake.
Below message is show up.
$ git clone -n https://nv-tegra.nvidia.com/3rdparty/u-boot.git
Cloning into āu-bootāā¦
fatal: repository āhttps://nv-tegra.nvidia.com/3rdparty/u-boot.git/ ā not found
kayccc
January 18, 2018, 6:03am
2
Hi naoki.yoshida,
Sorry for the late reply, have you resolved the source code download problem?
Thank you for reply.
I have not solved this problem yet, and Iām waiting for someoneās feedback or advice.
Hello kayccc & naoki.yoshida,
Iām having the same problem. My org blocks git://, but I donāt seem to be able to use https://
$ git clone https://nv-tegra.nvidia.com/3rdparty/u-boot.git
Thanks,
Gavin
VickNV
January 23, 2018, 2:59am
5
We have no http access support on nv-tegra now.
Could you work out this with your it guys? Or you can download the source via from the download center (e.g. https://developer.nvidia.com/embedded/dlc/l4t-sources-28-2 )
Hello vickyy,
OK, I understood. I will download the source from download center, but I would like nv-tegra to support http access later.
Hi, I get the same following error when using source_sync.sh. Any advice to handle it?
āStuart
stuart-Studio-XPS-9100:~/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra$ ./source_sync.sh
Downloading default kernel/kernel-4.9 sourceā¦
Cloning into ā/home/stuartx/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/sources/kernel/kernel-4.9āā¦
fatal: unable to connect to nv-tegra.nvidia.com :
nv-tegra.nvidia.com [0: 216.228.121.37]: errno=Connection timed out
/home/stuartx/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/sources/kernel/kernel-4.9 source sync failed!
Downloading default kernel/nvgpu sourceā¦
Cloning into ā/home/stuartx/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/sources/kernel/nvgpuāā¦
/home/stuartx/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/sources/kernel/nvgpu source sync failed!
ā¦
Hey Stuart - I ended up using git protocol instead of https.
Gavin
Hi Gavin,
Thanks for the response. Should I modify the source_sync.sh script or should I change the system configuration?
āStuart
Hi Gavin,
In other words, how to make it (the source_sync.sh script) work? Please provide the details.
Thanks,
āStuart
