Can't use my egpu
Hi, my laptop has RTX 2060. “Create” works fine with it. But when I plug in my egpu with RTX 3080 and open “Create”, it gives me this message:
“RTX engine creation failed. RTX renderers in viewport will be disabled. Please make sure selected GPU is RTX-capable, and GPU drivers meet requirements”.
Can you help me please?
Hi @zack_saimon! Welcome to the Community! I have alerted the dev team about your issue. Thanks for reaching out to us!
Hi @zack_saimon! The development team would like to see your full log report. You can grab the log file here: C:\Users\<USERNAME>\.nvidia-omniverse\logs
Also, which eGPU are you using?
kit_20211006_132954.log (382.0 KB)
AORUS RTX 3080 GAMING BOX
hello @zack_saimon
Can I request some more information?
Can you do two tests for me. Want to see if any of these tests result in Create working with your eGPU attached.
Get a Windows command prompt at the location of the desired Create version to be run. This location can be found by using the Launcher.
  • Go to Launcher “Library” tab
  • Select “Create” on the left pane
  • Click on the hamburger icon and scroll down to “settings” and select
  • Choose the version of Create and click on the “folder” icon OR get path from dialog
  • Will show you path to folder that we want to get command prompt at
At the command prompt run
omni.create.singlegpu.bat --/renderer/activeGpu=<Number, 0…N>
Where activeGpu is the GPU instance to use
In your case there are the two tests
omni.create.singlegpu.bat --/renderer/activeGpu=0
And then
omni.create.singlegpu.bat --/renderer/activeGpu=1
The first test will only use your laptop GPU
Second will only use the eGPU
Please tell me if any of these results in a viable Create.
Can you collect after each test?
Create works fine in both tests!
@zack_saimon - Thank you very much. Test was to see if multi-GPU related vs eGPU. Seems to be in the multi-GPU area. Will continue to look into this.
Not that i expect anything, but assume when you now start Create from Launcher (which will use all GPUs) it still fails?
Yes
hello @zack_saimon
Your problem is in the area of multiple GPUs. I have created a case for development to investigate. At the moment i do not have a workaround that would allow you to use both GPUs at the same time. My steps above will allow you to use one or the other.
I have communicated the logs and debug that you have provided. Once the problem has been identified and a release issued will respond to this post
OM-39300
