Capture bayer image with a BufferOutputStream
Hallo,
I want to get the raw bayer image of my camera using the ARgus library.
I can do this using an EGLOutputStream with the PixelFormat set to PIXEL_FMT_RAW16.
But I don’t find a corresponding NvBufferColorFormat if I want to use a BufferOutputStream.
So is it possible to capture the bayer images using a BufferOutputStream?
Suppose you can reference to the sample code of the MMAPI.
I found a sample using the EGLOutputStream but I did not find a sample using the BufferOutputStream to generate a raw bayer image.
Looks like BufferOutputStream unable to set the output format of PIXEL_FMT_RAW16
Which sample using the BufferOutputStream like you want?
