Hello, I am trying to train from a custom dataset. I have followed the Jetson AI Fundamentals S3E5 video and I have a problem when using camera-capture tool, when selecting the Dataset path from the tool it creates the 3 folders needed and ads Annotations and JPEGs fine but the ImageSet/Main folder contains only 2 files : train.txt, trainval.txt and I am missing the “test.txt” and “val.txt” files witch are needed to run train_ssd.py
Hi @vineri13052002, just copy the train.txt file that you have to test.txt and val.txt. It will be fine for a test model that you are training.
Thanks a lot that seems to have done the trick
