Hello All,
I’m developing 4K serdes transmission system by custom image sensor.
video clock : 959MHz
MIPI rate : 1495Mbps
mipi signal transmission is received check by osciloscope in jetson TX2 .
i ran gst-launch-1.0 in 3840 x 2160 resolution mode.
it occured error as shown below.
root@livsmed-desktop:/home/livsmed# /usr/sbin/nvargus-daemon
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== gst-launch-1.0[8633]: Connection established (7F8E3651D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvIspAfConfigParamsSanityCheck: Error: positionWorkingHigh is not larger than positionWorkingLow positionWorkingHigh = 0, positionWorkingLow = 0
SCF: Error Timeout: ISP port 0 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 478)
Error: waitCsiFrameStart timeout guid 1
VI Stream Id = 2 Virtual Channel = 0
************VI Debug Registers**********
VI_CSIMUX_STAT_FRAME_8 = 0x00010002
VI_CSIMUX_FRAME_STATUS_0 = 0x00000100
VI_CFG_INTERRUPT_STATUS_0 = 0x3f000000
VI_ISPBUFA_ERROR_0 = 0x00000000
VI_FMLITE_ERROR_0 = 0x00000000
VI_NOTIFY_ERROR_0 = 0x00000000
CSI Stream Id = 2 Brick Id = 1
************CSI Debug Registers**********
CILA_INTR_STATUS_CILA[0x20400] = 0x00000110
CILB_INTR_STATUS_CILB[0x20c00] = 0x00000190
INTR_STATUS[0x200a4] = 0x00000002
ERR_INTR_STATUS[0x200ac] = 0x00000002
ERROR_STATUS2VI_VC0[0x20094] = 0x00000002
ERROR_STATUS2VI_VC1[0x20098] = 0x00000000
ERROR_STATUS2VI_VC2[0x2009c] = 0x00000000
ERROR_STATUS2VI_VC3[0x200a0] = 0x00000000
SCF: Error BadValue: timestamp cannot be 0 (in src/services/capture/NvViCsiHw.cpp, function waitCsiFrameStart(), line 637)
SCF: Error BadValue: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error BadValue: Worker thread ViCsiHw frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
SCF: Error Timeout: ISP Stats timed out! (in src/services/capture/NvIspHw.cpp, function waitIspStatsFinished(), line 566)
PowerServiceCore:handleRequests: timePassed = 10132
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDeviceIsp.cpp, function waitCompletion(), line 423)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 949)
SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1032)
SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 992)
SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
SCF: Error Timeout: ISP port 1 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 501)
SCF: Error Timeout: NvRmSyncWait failed (in src/api/Buffer.cpp, function cpuWaitFences(), line 615)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function cpuWaitInputFences(), line 536)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function acquire(), line 673)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function ScopedBufferLock(), line 650)
SCF: Error Timeout: ISP port 2 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 512)
SCF: Error Timeout: (propagating from src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 524)
SCF: Error Timeout: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error Timeout: Worker thread IspHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
# tracer: nop
# entries-in-buffer/entries-written: 575/575 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
gst-plugin-scan-8677 [005] .... 437.961954: tegra_channel_open: vi-output, s5k2x5 2-0010
gst-plugin-scan-8677 [005] .... 437.963141: tegra_channel_set_power: s5k2x5 2-0010 : 0x1
gst-plugin-scan-8677 [005] .... 437.963150: camera_common_s_power: status : 0x1
gst-plugin-scan-8677 [005] .... 437.965501: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
gst-plugin-scan-8677 [005] .... 437.965503: csi_s_power: enable : 0x1
gst-plugin-scan-8677 [005] .... 437.967157: tegra_channel_close: vi-output, s5k2x5 2-0010
gst-plugin-scan-8677 [005] .... 437.967160: tegra_channel_set_power: s5k2x5 2-0010 : 0x0
gst-plugin-scan-8677 [005] .... 437.967166: camera_common_s_power: status : 0x0
gst-plugin-scan-8677 [005] .... 437.969271: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
gst-plugin-scan-8677 [005] .... 437.969271: csi_s_power: enable : 0x0
nvargus-daemon-8683 [005] .... 438.466552: tegra_channel_close: vi-output, s5k2x5 2-002d
nvargus-daemon-8683 [005] .... 438.466554: tegra_channel_set_power: s5k2x5 2-002d : 0x0
nvargus-daemon-8683 [005] .... 438.466558: camera_common_s_power: status : 0x0
nvargus-daemon-8683 [005] .... 438.468666: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8683 [005] .... 438.468667: csi_s_power: enable : 0x0
nvargus-daemon-8683 [005] .... 438.468868: tegra_channel_open: vi-output, s5k2x5 2-0010
nvargus-daemon-8683 [005] .... 438.468872: tegra_channel_set_power: s5k2x5 2-0010 : 0x1
nvargus-daemon-8683 [005] .... 438.468878: camera_common_s_power: status : 0x1
nvargus-daemon-8683 [003] .... 438.471195: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8683 [003] .... 438.471197: csi_s_power: enable : 0x1
nvargus-daemon-8683 [003] .... 438.471212: tegra_channel_close: vi-output, s5k2x5 2-0010
nvargus-daemon-8683 [003] .... 438.471214: tegra_channel_set_power: s5k2x5 2-0010 : 0x0
nvargus-daemon-8683 [003] .... 438.471219: camera_common_s_power: status : 0x0
nvargus-daemon-8683 [003] .... 438.473361: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8683 [003] .... 438.473365: csi_s_power: enable : 0x0
nvargus-daemon-8683 [003] .... 438.473616: tegra_channel_open: vi-output, s5k2x5 2-0010
nvargus-daemon-8683 [003] .... 438.473624: tegra_channel_set_power: s5k2x5 2-0010 : 0x1
nvargus-daemon-8683 [003] .... 438.473636: camera_common_s_power: status : 0x1
nvargus-daemon-8683 [003] .... 438.475973: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8683 [003] .... 438.475976: csi_s_power: enable : 0x1
nvargus-daemon-8683 [003] .... 438.476055: tegra_channel_close: vi-output, s5k2x5 2-0010
nvargus-daemon-8683 [003] .... 438.476058: tegra_channel_set_power: s5k2x5 2-0010 : 0x0
nvargus-daemon-8683 [003] .... 438.476065: camera_common_s_power: status : 0x0
nvargus-daemon-8683 [003] .... 438.478186: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8683 [003] .... 438.478189: csi_s_power: enable : 0x0
nvargus-daemon-8683 [003] .... 438.478438: tegra_channel_open: vi-output, s5k2x5 2-0010
nvargus-daemon-8683 [003] .... 438.478444: tegra_channel_set_power: s5k2x5 2-0010 : 0x1
nvargus-daemon-8683 [003] .... 438.478452: camera_common_s_power: status : 0x1
nvargus-daemon-8683 [003] .... 438.480791: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8683 [003] .... 438.480792: csi_s_power: enable : 0x1
nvargus-daemon-8683 [003] .... 438.480887: tegra_channel_close: vi-output, s5k2x5 2-0010
nvargus-daemon-8683 [003] .... 438.480889: tegra_channel_set_power: s5k2x5 2-0010 : 0x0
nvargus-daemon-8683 [003] .... 438.480893: camera_common_s_power: status : 0x0
nvargus-daemon-8683 [003] .... 438.482997: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8683 [003] .... 438.482998: csi_s_power: enable : 0x0
nvargus-daemon-8683 [003] .... 438.505428: tegra_channel_open: vi-output, s5k2x5 2-002d
nvargus-daemon-8683 [003] .... 438.505437: tegra_channel_set_power: s5k2x5 2-002d : 0x1
nvargus-daemon-8683 [003] .... 438.505447: camera_common_s_power: status : 0x1
nvargus-daemon-8683 [003] .... 438.507812: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8683 [003] .... 438.507815: csi_s_power: enable : 0x1
nvargus-daemon-8683 [003] .... 438.507841: tegra_channel_close: vi-output, s5k2x5 2-002d
nvargus-daemon-8683 [003] .... 438.507844: tegra_channel_set_power: s5k2x5 2-002d : 0x0
nvargus-daemon-8683 [003] .... 438.507851: camera_common_s_power: status : 0x0
nvargus-daemon-8683 [003] .... 438.509977: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8683 [003] .... 438.509980: csi_s_power: enable : 0x0
nvargus-daemon-8683 [003] .... 438.510216: tegra_channel_open: vi-output, s5k2x5 2-002d
nvargus-daemon-8683 [003] .... 438.510221: tegra_channel_set_power: s5k2x5 2-002d : 0x1
nvargus-daemon-8683 [003] .... 438.510230: camera_common_s_power: status : 0x1
nvargus-daemon-8683 [003] .... 438.512555: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8683 [003] .... 438.512557: csi_s_power: enable : 0x1
nvargus-daemon-8683 [003] .... 438.512643: tegra_channel_close: vi-output, s5k2x5 2-002d
nvargus-daemon-8683 [003] .... 438.512646: tegra_channel_set_power: s5k2x5 2-002d : 0x0
nvargus-daemon-8683 [003] .... 438.512651: camera_common_s_power: status : 0x0
nvargus-daemon-8683 [003] .... 438.514768: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8683 [003] .... 438.514769: csi_s_power: enable : 0x0
nvargus-daemon-8683 [003] .... 438.514985: tegra_channel_open: vi-output, s5k2x5 2-002d
nvargus-daemon-8683 [003] .... 438.514989: tegra_channel_set_power: s5k2x5 2-002d : 0x1
nvargus-daemon-8683 [003] .... 438.514995: camera_common_s_power: status : 0x1
nvargus-daemon-8683 [003] .... 438.517303: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8683 [003] .... 438.517303: csi_s_power: enable : 0x1
nvargus-daemon-8683 [003] .... 438.517385: tegra_channel_close: vi-output, s5k2x5 2-002d
nvargus-daemon-8683 [003] .... 438.517387: tegra_channel_set_power: s5k2x5 2-002d : 0x0
nvargus-daemon-8683 [003] .... 438.517391: camera_common_s_power: status : 0x0
nvargus-daemon-8683 [003] .... 438.519497: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8683 [003] .... 438.519498: csi_s_power: enable : 0x0
kworker/4:1-992 [004] .... 438.554702: rtos_queue_peek_from_isr_failed: tstamp:13964362140 queue:0x0b4b4500
kworker/4:1-992 [004] .... 438.554707: rtcpu_start: tstamp:13964363351
kworker/4:1-992 [004] .... 438.554709: rtos_queue_send_from_isr_failed: tstamp:13964372328 queue:0x0b4a7258
kworker/4:1-992 [004] .... 438.554709: rtos_queue_send_from_isr_failed: tstamp:13964372436 queue:0x0b4aad68
kworker/4:1-992 [004] .... 438.554710: rtos_queue_send_from_isr_failed: tstamp:13964372542 queue:0x0b4ac998
kworker/4:1-992 [004] .... 438.554711: rtos_queue_send_from_isr_failed: tstamp:13964372650 queue:0x0b4ae518
kworker/4:1-992 [004] .... 438.554711: rtos_queue_send_from_isr_failed: tstamp:13964372755 queue:0x0b4af2d8
kworker/4:1-992 [004] .... 438.554712: rtos_queue_send_from_isr_failed: tstamp:13964372861 queue:0x0b4b0098
kworker/4:1-992 [004] .... 438.554713: rtos_queue_send_from_isr_failed: tstamp:13964372966 queue:0x0b4b0e58
kworker/4:1-992 [004] .... 438.554713: rtos_queue_send_from_isr_failed: tstamp:13964373074 queue:0x0b4b1c18
kworker/4:1-992 [004] .... 438.554714: rtos_queue_send_failed: tstamp:13964373537 queue:0x0b4a7258
kworker/4:1-992 [004] .... 438.722703: rtos_queue_peek_from_isr_failed: tstamp:13969362486 queue:0x0b4b4500
CaptureSchedule-8702 [003] .... 438.758762: tegra_channel_open: vi-output, s5k2x5 2-0010
CaptureSchedule-8702 [003] .... 438.758772: tegra_channel_set_power: s5k2x5 2-0010 : 0x1
CaptureSchedule-8702 [003] .... 438.758783: camera_common_s_power: status : 0x1
CaptureSchedule-8702 [005] .... 438.761132: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
CaptureSchedule-8702 [005] .... 438.761137: csi_s_power: enable : 0x1
CaptureSchedule-8702 [000] .... 438.768917: tegra_channel_set_stream: enable : 0x1
CaptureSchedule-8702 [000] .... 438.770406: tegra_channel_set_stream: 150c0000.nvcsi--2 : 0x1
CaptureSchedule-8702 [000] .... 438.770409: csi_s_stream: enable : 0x1
CaptureSchedule-8702 [000] .... 438.770410: tegra_channel_set_stream: s5k2x5 2-0010 : 0x1
kworker/4:1-992 [004] .... 438.778727: rtos_queue_send_from_isr_failed: tstamp:13971127439 queue:0x0b4a7258
kworker/4:1-992 [004] .... 438.778730: rtos_queue_send_from_isr_failed: tstamp:13971127556 queue:0x0b4aad68
kworker/4:1-992 [004] .... 438.778731: rtos_queue_send_from_isr_failed: tstamp:13971127664 queue:0x0b4ac998
kworker/4:1-992 [004] .... 438.778732: rtos_queue_send_from_isr_failed: tstamp:13971127770 queue:0x0b4ae518
kworker/4:1-992 [004] .... 438.778733: rtos_queue_send_from_isr_failed: tstamp:13971127874 queue:0x0b4af2d8
kworker/4:1-992 [004] .... 438.778733: rtos_queue_send_from_isr_failed: tstamp:13971127979 queue:0x0b4b0098
kworker/4:1-992 [004] .... 438.778734: rtos_queue_send_from_isr_failed: tstamp:13971128084 queue:0x0b4b0e58
kworker/4:1-992 [004] .... 438.778734: rtos_queue_send_from_isr_failed: tstamp:13971128188 queue:0x0b4b1c18
kworker/4:1-992 [004] .... 438.778736: rtos_queue_send_failed: tstamp:13971128630 queue:0x0b4a7258
kworker/4:1-992 [004] .... 438.778736: rtos_queue_send_from_isr_failed: tstamp:13971321324 queue:0x0b4a7258
kworker/4:1-992 [004] .... 438.778737: rtos_queue_send_from_isr_failed: tstamp:13971321432 queue:0x0b4aad68
kworker/4:1-992 [004] .... 438.778738: rtos_queue_send_from_isr_failed: tstamp:13971321539 queue:0x0b4ac998
kworker/4:1-992 [004] .... 438.778738: rtos_queue_send_from_isr_failed: tstamp:13971321645 queue:0x0b4ae518
kworker/4:1-992 [004] .... 438.778739: rtos_queue_send_from_isr_failed: tstamp:13971321749 queue:0x0b4af2d8
kworker/4:1-992 [004] .... 438.778739: rtos_queue_send_from_isr_failed: tstamp:13971321854 queue:0x0b4b0098
kworker/4:1-992 [004] .... 438.778740: rtos_queue_send_from_isr_failed: tstamp:13971321959 queue:0x0b4b0e58
kworker/4:1-992 [004] .... 438.778741: rtos_queue_send_from_isr_failed: tstamp:13971322076 queue:0x0b4b1c18
kworker/4:1-992 [004] .... 438.778741: rtos_queue_send_failed: tstamp:13971322519 queue:0x0b4a7258
kworker/4:1-992 [004] .... 438.890763: rtos_queue_peek_from_isr_failed: tstamp:13974362544 queue:0x0b4b4500
kworker/4:1-992 [004] .... 439.058710: rtos_queue_peek_from_isr_failed: tstamp:13979362541 queue:0x0b4b4500
kworker/4:1-992 [004] .... 439.114843: rtos_queue_send_from_isr_failed: tstamp:13981630129 queue:0x0b4a7258
kworker/4:1-992 [004] .... 439.114852: rtos_queue_send_from_isr_failed: tstamp:13981630275 queue:0x0b4aad68
kworker/4:1-992 [004] .... 439.114854: rtos_queue_send_from_isr_failed: tstamp:13981630416 queue:0x0b4ac998
kworker/4:1-992 [004] .... 439.114857: rtos_queue_send_from_isr_failed: tstamp:13981630556 queue:0x0b4ae518
kworker/4:1-992 [004] .... 439.114859: rtos_queue_send_from_isr_failed: tstamp:13981630693 queue:0x0b4af2d8
kworker/4:1-992 [004] .... 439.114861: rtos_queue_send_from_isr_failed: tstamp:13981630831 queue:0x0b4b0098
kworker/4:1-992 [004] .... 439.114864: rtos_queue_send_from_isr_failed: tstamp:13981630970 queue:0x0b4b0e58
kworker/4:1-992 [004] .... 439.114866: rtos_queue_send_from_isr_failed: tstamp:13981631111 queue:0x0b4b1c18
kworker/4:1-992 [004] .... 439.114871: rtos_queue_send_failed: tstamp:13981632610 queue:0x0b4a7258
kworker/4:1-992 [004] .... 439.226800: rtos_queue_peek_from_isr_failed: tstamp:13984362513 queue:0x0b4b4500
kworker/4:1-992 [004] .... 439.394779: rtos_queue_peek_from_isr_failed: tstamp:13989362515 queue:0x0b4b4500
kworker/4:1-992 [004] .... 439.506784: rtos_queue_peek_from_isr_failed: tstamp:13994362521 queue:0x0b4b4500
kworker/4:1-992 [004] .... 439.674791: rtos_queue_peek_from_isr_failed: tstamp:13999362540 queue:0x0b4b4500
kworker/4:1-992 [004] .... 439.842755: rtos_queue_peek_from_isr_failed: tstamp:14004362537 queue:0x0b4b4500
