— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
I could not find clear support for that in the provided Jetson Orin NX documentation. However, I can provide some general guidance based on the context.
The issue you’re experiencing with the captured image becoming striped/corrupted when changing the Output Size on Jetson Orin NX might be related to the camera driver or ISP configuration.
In the context, there are some discussions about camera-related issues on Jetson platforms, such as the “Orin camera can not preview” topic, which mentions a potential issue with the camera driver. However, this topic is specific to Jetson AGX Orin and might not be directly applicable to your situation.
Another topic, “Poor image quality after flashing” on Jetson Orin Nano, mentions some fixes applied to resolve blurry capture results, but it’s not clear if this is related to your specific issue.
Regarding Argus APIs, ISP configuration steps, or debugging methods, the provided context does not offer specific guidance for your situation. However, it’s worth noting that the “Camera Driver 640X480 Not getting output in ARGUS” topic on Jetson Xavier NX mentions some potential issues with sensor configuration and ISP settings.
To further troubleshoot the issue, you might want to try the following:
- Verify that the camera driver is properly configured and that the sensor settings are correct.
- Check the ISP configuration and ensure that it’s set up correctly for the desired output size.
- Use debugging tools, such as the
v4l2-ctl command, to inspect the camera settings and capture parameters.
- Consult the Jetson Orin NX documentation and the Argus API documentation for more information on camera configuration and ISP settings.
If you’re still experiencing issues, it might be helpful to provide more details about your setup, including the camera model, sensor settings, and ISP configuration.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
