I have connected SmartSens sensor through FPDLINK-III to Xavier AGX with JP5.1.1. This sensor can provide HDR and Linear Image. With Linear mode everything is OK. HDR Can be staggered (which actually not supported by jetson platform) and separated by 2 VC: 0 is for long frame and 1 is for shot frame. I’ve created “fuse” sensor for short frame sensor to be able receive frames from /dev/video0 and /dev/video1 interfaces. Long frame stream through /dev/video0 is working perfectly but short frames on /dev/video1 reads with errors, I have 1-2 frames per second.
<pre> kworker/0:3-134 [000] .... 1283.535139: rtcpu_vinotify_event: tstamp:40803006293 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305686623904 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1283.535142: rtcpu_vinotify_event: tstamp:40803006446 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305686629408 data:0x0000000031000001
kworker/0:3-134 [000] .... 1283.535143: rtcpu_vinotify_event: tstamp:40803006600 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305686684064 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1283.535143: rtcpu_vinotify_event: tstamp:40803006734 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305686689632 data:0x0000000031000002
kworker/0:3-134 [000] .... 1283.647105: rtcpu_vinotify_error: tstamp:40805771372 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:1305784659008 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.647108: rtcpu_vinotify_event: tstamp:40805823284 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:1305784325824 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.647109: rtcpu_vinotify_event: tstamp:40805823421 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:1305784659008 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.703101: rtcpu_vinotify_event: tstamp:40807701311 cch:0 vi:0 tag:FS channel:0x00 frame:1 vi_tstamp:1305843107360 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.703103: rtcpu_vinotify_event: tstamp:40807701453 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:1305843107392 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.703103: rtcpu_vinotify_event: tstamp:40807701607 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:1305843440512 data:0x0000000000000001
kworker/0:3-134 [000] .... 1283.703104: rtcpu_vinotify_event: tstamp:40807701739 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:1305843441792 data:0x0000000008020001
kworker/0:3-134 [000] .... 1283.703105: rtcpu_vinotify_error: tstamp:40807936790 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:0 vi_tstamp:1305853954208 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.703105: rtcpu_vinotify_event: tstamp:40808014336 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:0 vi_tstamp:1305853954208 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.703106: rtcpu_vinotify_event: tstamp:40808014469 cch:-1 vi:0 tag:FS channel:0x01 frame:1 vi_tstamp:1305856386784 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.703106: rtcpu_vinotify_error: tstamp:40808023280 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:1 vi_tstamp:1305856720000 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.703107: rtcpu_vinotify_event: tstamp:40808327394 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:1 vi_tstamp:1305856720000 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.759100: rtcpu_vinotify_event: tstamp:40809766629 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:1305912505568 data:0x0000000004370002
kworker/0:3-134 [000] .... 1283.759102: rtcpu_vinotify_event: tstamp:40809766785 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:1305912505984 data:0x0000000000000000
kworker/0:3-134 [000] .... 1283.759102: rtcpu_vinotify_event: tstamp:40809766922 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:1305912508096 data:0x0000000002020001
kworker/0:3-134 [000] .... 1283.759105: rtcpu_vinotify_event: tstamp:40810048823 cch:0 vi:0 tag:FE channel:0x00 frame:1 vi_tstamp:1305912735712 data:0x0000000000000020
kworker/0:3-134 [000] .... 1283.759105: rtcpu_vinotify_event: tstamp:40810048966 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:1305912735744 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.759106: rtcpu_vinotify_event: tstamp:40810049119 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:1305912739968 data:0x0000000000020001
kworker/0:3-134 [000] .... 1283.759106: rtcpu_vinotify_event: tstamp:40810049252 cch:0 vi:0 tag:FS channel:0x00 frame:2 vi_tstamp:1305915168320 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.759107: rtcpu_vinotify_event: tstamp:40810049406 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:1305915168320 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.759107: rtcpu_vinotify_event: tstamp:40810049540 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:1305915501504 data:0x0000000000000001
kworker/0:3-134 [000] .... 1283.759108: rtcpu_vinotify_event: tstamp:40810049689 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:1305915502752 data:0x0000000008020002
kworker/0:3-134 [000] .... 1283.759125: rtcpu_vinotify_event: tstamp:40810049823 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305915570624 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1283.759126: rtcpu_vinotify_event: tstamp:40810049973 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305915576192 data:0x0000000031000003
kworker/0:3-134 [000] .... 1283.759127: rtcpu_vinotify_error: tstamp:40810188701 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:1 vi_tstamp:1305926015200 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.815095: rtcpu_vinotify_error: tstamp:40810275183 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:2 vi_tstamp:1305928780928 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.815097: rtcpu_vinotify_event: tstamp:40810361875 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:1 vi_tstamp:1305926015200 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.815098: rtcpu_vinotify_event: tstamp:40810362023 cch:-1 vi:0 tag:FS channel:0x01 frame:2 vi_tstamp:1305928447776 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.815098: rtcpu_vinotify_event: tstamp:40810362155 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:2 vi_tstamp:1305928780928 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.871091: rtcpu_vinotify_event: tstamp:40812027172 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:2 vi_tstamp:1305984566496 data:0x0000000004370002
kworker/0:3-134 [000] .... 1283.871092: rtcpu_vinotify_event: tstamp:40812027311 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:2 vi_tstamp:1305984566944 data:0x0000000000000000
kworker/0:3-134 [000] .... 1283.871093: rtcpu_vinotify_event: tstamp:40812027464 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:1305984569056 data:0x0000000002020002
kworker/0:3-134 [000] .... 1283.871094: rtcpu_vinotify_event: tstamp:40812027595 cch:0 vi:0 tag:FE channel:0x00 frame:2 vi_tstamp:1305984796704 data:0x0000000000000020
kworker/0:3-134 [000] .... 1283.871094: rtcpu_vinotify_event: tstamp:40812333837 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:1305984796736 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.871095: rtcpu_vinotify_event: tstamp:40812333976 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:1305984801920 data:0x0000000000020002
kworker/0:3-134 [000] .... 1283.871095: rtcpu_vinotify_event: tstamp:40812334129 cch:0 vi:0 tag:FS channel:0x00 frame:3 vi_tstamp:1305987229312 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.871096: rtcpu_vinotify_event: tstamp:40812334265 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:1305987229312 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.871113: rtcpu_vinotify_event: tstamp:40812334416 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:3 vi_tstamp:1305987562496 data:0x0000000000000001
kworker/0:3-134 [000] .... 1283.871114: rtcpu_vinotify_event: tstamp:40812334552 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:1305987563744 data:0x0000000008020003
kworker/0:3-134 [000] .... 1283.871114: rtcpu_vinotify_event: tstamp:40812334702 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305987631584 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1283.871115: rtcpu_vinotify_event: tstamp:40812334834 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1305987637184 data:0x0000000031000004
kworker/0:3-134 [000] .... 1283.871115: rtcpu_vinotify_error: tstamp:40812440603 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:1305998076128 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.871116: rtcpu_vinotify_error: tstamp:40812527098 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:3 vi_tstamp:1306000841888 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.871116: rtcpu_vinotify_event: tstamp:40812646763 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:1305998076128 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.871117: rtcpu_vinotify_event: tstamp:40812646896 cch:-1 vi:0 tag:FS channel:0x01 frame:3 vi_tstamp:1306000508736 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.871117: rtcpu_vinotify_event: tstamp:40812647046 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:3 vi_tstamp:1306000841888 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.927092: rtcpu_vinotify_event: tstamp:40814279077 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:3 vi_tstamp:1306056627488 data:0x0000000004370002
kworker/0:3-134 [000] .... 1283.927094: rtcpu_vinotify_event: tstamp:40814279231 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:3 vi_tstamp:1306056627904 data:0x0000000000000000
kworker/0:3-134 [000] .... 1283.927094: rtcpu_vinotify_event: tstamp:40814279368 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:1306056630048 data:0x0000000002020003
kworker/0:3-134 [000] .... 1283.927095: rtcpu_vinotify_event: tstamp:40814279519 cch:0 vi:0 tag:FE channel:0x00 frame:3 vi_tstamp:1306056857696 data:0x0000000000000020
kworker/0:3-134 [000] .... 1283.927096: rtcpu_vinotify_event: tstamp:40814279658 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:1306056857696 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.927097: rtcpu_vinotify_event: tstamp:40814587420 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:1306056862912 data:0x0000000000020003
kworker/0:3-134 [000] .... 1283.927097: rtcpu_vinotify_event: tstamp:40814587565 cch:0 vi:0 tag:FS channel:0x00 frame:4 vi_tstamp:1306059290272 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.927098: rtcpu_vinotify_event: tstamp:40814587722 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:1306059290304 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.927115: rtcpu_vinotify_event: tstamp:40814587854 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:4 vi_tstamp:1306059623424 data:0x0000000000000001
kworker/0:3-134 [000] .... 1283.927116: rtcpu_vinotify_event: tstamp:40814588006 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:1306059624704 data:0x0000000008020004
kworker/0:3-134 [000] .... 1283.927116: rtcpu_vinotify_event: tstamp:40814588142 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306059692800 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1283.927117: rtcpu_vinotify_event: tstamp:40814588291 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306059698368 data:0x0000000031000005
kworker/0:3-134 [000] .... 1283.927117: rtcpu_vinotify_error: tstamp:40814692507 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:3 vi_tstamp:1306070137120 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.927118: rtcpu_vinotify_error: tstamp:40814778993 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:4 vi_tstamp:1306072902880 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.927118: rtcpu_vinotify_event: tstamp:40814900470 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:3 vi_tstamp:1306070137120 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.927119: rtcpu_vinotify_event: tstamp:40814900616 cch:-1 vi:0 tag:FS channel:0x01 frame:4 vi_tstamp:1306072569728 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.927119: rtcpu_vinotify_event: tstamp:40814900747 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:4 vi_tstamp:1306072902880 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.983086: rtcpu_vinotify_event: tstamp:40816530996 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:4 vi_tstamp:1306128688480 data:0x0000000004370002
kworker/0:3-134 [000] .... 1283.983087: rtcpu_vinotify_event: tstamp:40816531136 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:4 vi_tstamp:1306128688896 data:0x0000000000000000
kworker/0:3-134 [000] .... 1283.983087: rtcpu_vinotify_event: tstamp:40816531289 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:1306128691008 data:0x0000000002020004
kworker/0:3-134 [000] .... 1283.983088: rtcpu_vinotify_event: tstamp:40816531420 cch:0 vi:0 tag:FE channel:0x00 frame:4 vi_tstamp:1306128918624 data:0x0000000000000020
kworker/0:3-134 [000] .... 1283.983088: rtcpu_vinotify_event: tstamp:40816531577 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:1306128918624 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.983089: rtcpu_vinotify_event: tstamp:40816531711 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:1306128922848 data:0x0000000000020004
kworker/0:3-134 [000] .... 1283.983090: rtcpu_vinotify_event: tstamp:40816841009 cch:0 vi:0 tag:FS channel:0x00 frame:5 vi_tstamp:1306131351232 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.983090: rtcpu_vinotify_event: tstamp:40816841153 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:1306131351232 data:0x0000000800000000
kworker/0:3-134 [000] .... 1283.983091: rtcpu_vinotify_event: tstamp:40816841305 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:5 vi_tstamp:1306131684416 data:0x0000000000000001
kworker/0:3-134 [000] .... 1283.983111: rtcpu_vinotify_event: tstamp:40816841437 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:1306131685696 data:0x0000000008020005
kworker/0:3-134 [000] .... 1283.983112: rtcpu_vinotify_event: tstamp:40816841586 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306131753952 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1283.983113: rtcpu_vinotify_event: tstamp:40816841718 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306131759552 data:0x0000000031000006
kworker/0:3-134 [000] .... 1283.983114: rtcpu_vinotify_error: tstamp:40816944417 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:4 vi_tstamp:1306142198112 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.983114: rtcpu_vinotify_error: tstamp:40817030895 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:5 vi_tstamp:1306144963840 data:0x0000000000000569
kworker/0:3-134 [000] .... 1283.983115: rtcpu_vinotify_event: tstamp:40817154060 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:4 vi_tstamp:1306142198112 data:0x0000000000000220
kworker/0:3-134 [000] .... 1283.983115: rtcpu_vinotify_event: tstamp:40817154191 cch:-1 vi:0 tag:FS channel:0x01 frame:5 vi_tstamp:1306144630720 data:0x0000000000000010
kworker/0:3-134 [000] .... 1283.983116: rtcpu_vinotify_event: tstamp:40817154339 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:5 vi_tstamp:1306144963840 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.039078: rtcpu_vinotify_event: tstamp:40818857423 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:5 vi_tstamp:1306200749408 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.039079: rtcpu_vinotify_event: tstamp:40818857582 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:5 vi_tstamp:1306200749824 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.039080: rtcpu_vinotify_event: tstamp:40818857719 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:1306200751936 data:0x0000000002020005
kworker/0:3-134 [000] .... 1284.039081: rtcpu_vinotify_event: tstamp:40818857871 cch:0 vi:0 tag:FE channel:0x00 frame:5 vi_tstamp:1306200979616 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.039081: rtcpu_vinotify_event: tstamp:40818858009 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:1306200979616 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.039082: rtcpu_vinotify_event: tstamp:40818858162 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:1306200983872 data:0x0000000000020005
kworker/0:3-134 [000] .... 1284.039098: rtcpu_vinotify_event: tstamp:40818858295 cch:0 vi:0 tag:FS channel:0x00 frame:6 vi_tstamp:1306203412224 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.095068: rtcpu_vinotify_event: tstamp:40819160432 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:1306203412224 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.095069: rtcpu_vinotify_event: tstamp:40819160586 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:6 vi_tstamp:1306203745408 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.095070: rtcpu_vinotify_event: tstamp:40819160739 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:1306203746688 data:0x0000000008020006
kworker/0:3-134 [000] .... 1284.095071: rtcpu_vinotify_event: tstamp:40819160873 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306203811360 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1284.095071: rtcpu_vinotify_event: tstamp:40819161022 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306203816928 data:0x0000000031000007
kworker/0:3-134 [000] .... 1284.095072: rtcpu_vinotify_error: tstamp:40819196318 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:5 vi_tstamp:1306214259040 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.095073: rtcpu_vinotify_error: tstamp:40819282801 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:6 vi_tstamp:1306217024832 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.095073: rtcpu_vinotify_event: tstamp:40819473475 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:5 vi_tstamp:1306214259040 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.095074: rtcpu_vinotify_event: tstamp:40819473623 cch:-1 vi:0 tag:FS channel:0x01 frame:6 vi_tstamp:1306216691648 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.095074: rtcpu_vinotify_event: tstamp:40819473757 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:6 vi_tstamp:1306217024832 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.151068: rtcpu_vinotify_event: tstamp:40821039141 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:6 vi_tstamp:1306272810400 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.151069: rtcpu_vinotify_event: tstamp:40821039296 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:6 vi_tstamp:1306272810848 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.151070: rtcpu_vinotify_event: tstamp:40821039453 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:1306272812960 data:0x0000000002020006
kworker/0:3-134 [000] .... 1284.151070: rtcpu_vinotify_event: tstamp:40821039589 cch:0 vi:0 tag:FE channel:0x00 frame:6 vi_tstamp:1306273040608 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.151071: rtcpu_vinotify_event: tstamp:40821039746 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:6 vi_tstamp:1306273040608 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.151071: rtcpu_vinotify_event: tstamp:40821039881 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:1306273044832 data:0x0000000000020006
kworker/0:3-134 [000] .... 1284.151072: rtcpu_vinotify_event: tstamp:40821109325 cch:0 vi:0 tag:FS channel:0x00 frame:7 vi_tstamp:1306275473216 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.151072: rtcpu_vinotify_event: tstamp:40821109465 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:1306275473216 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.151073: rtcpu_vinotify_event: tstamp:40821414017 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:7 vi_tstamp:1306275806336 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.151074: rtcpu_vinotify_event: tstamp:40821414156 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:1306275807616 data:0x0000000008020007
kworker/0:3-134 [000] .... 1284.151074: rtcpu_vinotify_event: tstamp:40821414309 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306275872704 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1284.151075: rtcpu_vinotify_event: tstamp:40821414441 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306275878272 data:0x0000000031000008
kworker/0:3-134 [000] .... 1284.151076: rtcpu_vinotify_error: tstamp:40821448224 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:6 vi_tstamp:1306286320032 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.151076: rtcpu_vinotify_error: tstamp:40821534718 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:7 vi_tstamp:1306289085824 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.151077: rtcpu_vinotify_event: tstamp:40821727067 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:6 vi_tstamp:1306286320032 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.151077: rtcpu_vinotify_event: tstamp:40821727198 cch:-1 vi:0 tag:FS channel:0x01 frame:7 vi_tstamp:1306288752640 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.151078: rtcpu_vinotify_event: tstamp:40821727349 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:7 vi_tstamp:1306289085824 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.207067: rtcpu_vinotify_event: tstamp:40823292014 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:7 vi_tstamp:1306344871392 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.207068: rtcpu_vinotify_event: tstamp:40823292171 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:7 vi_tstamp:1306344871840 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.207069: rtcpu_vinotify_event: tstamp:40823292310 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:1306344873952 data:0x0000000002020007
kworker/0:3-134 [000] .... 1284.207070: rtcpu_vinotify_event: tstamp:40823292465 cch:0 vi:0 tag:FE channel:0x00 frame:7 vi_tstamp:1306345101536 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.207070: rtcpu_vinotify_event: tstamp:40823292605 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:1306345101536 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.207071: rtcpu_vinotify_event: tstamp:40823292758 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:1306345105760 data:0x0000000000020007
kworker/0:3-134 [000] .... 1284.207072: rtcpu_vinotify_event: tstamp:40823373368 cch:0 vi:0 tag:FS channel:0x00 frame:8 vi_tstamp:1306347534144 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.207072: rtcpu_vinotify_event: tstamp:40823373565 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:8 vi_tstamp:1306347534144 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.207073: rtcpu_vinotify_event: tstamp:40823373698 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:8 vi_tstamp:1306347867328 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.207073: rtcpu_vinotify_event: tstamp:40823667731 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:8 vi_tstamp:1306347869600 data:0x0000000008020008
kworker/0:3-134 [000] .... 1284.207074: rtcpu_vinotify_event: tstamp:40823667867 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306347950624 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1284.207089: rtcpu_vinotify_event: tstamp:40823668018 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306347956192 data:0x0000000031000009
kworker/0:3-134 [000] .... 1284.207090: rtcpu_vinotify_error: tstamp:40823700130 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:7 vi_tstamp:1306358381024 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.207091: rtcpu_vinotify_error: tstamp:40823786616 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:8 vi_tstamp:1306361146752 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.207091: rtcpu_vinotify_event: tstamp:40823980664 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:7 vi_tstamp:1306358381024 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.207092: rtcpu_vinotify_event: tstamp:40823980812 cch:-1 vi:0 tag:FS channel:0x01 frame:8 vi_tstamp:1306360813632 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.207093: rtcpu_vinotify_event: tstamp:40823980943 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:8 vi_tstamp:1306361146752 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.263060: rtcpu_vinotify_event: tstamp:40825545739 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:8 vi_tstamp:1306416932320 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.263061: rtcpu_vinotify_event: tstamp:40825545879 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:8 vi_tstamp:1306416932736 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.263062: rtcpu_vinotify_event: tstamp:40825546035 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:8 vi_tstamp:1306416934848 data:0x0000000002020008
kworker/0:3-134 [000] .... 1284.263063: rtcpu_vinotify_event: tstamp:40825546169 cch:0 vi:0 tag:FE channel:0x00 frame:8 vi_tstamp:1306417162528 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.263063: rtcpu_vinotify_event: tstamp:40825546324 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:8 vi_tstamp:1306417162528 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.263064: rtcpu_vinotify_event: tstamp:40825546459 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:8 vi_tstamp:1306417166752 data:0x0000000000020008
kworker/0:3-134 [000] .... 1284.263065: rtcpu_vinotify_event: tstamp:40825625304 cch:0 vi:0 tag:FS channel:0x00 frame:9 vi_tstamp:1306419595136 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.263065: rtcpu_vinotify_event: tstamp:40825625448 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:1306419595136 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.263066: rtcpu_vinotify_event: tstamp:40825625601 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:9 vi_tstamp:1306419928320 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.263066: rtcpu_vinotify_event: tstamp:40825625734 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:9 vi_tstamp:1306419929568 data:0x0000000008020009
kworker/0:3-134 [000] .... 1284.263082: rtcpu_vinotify_event: tstamp:40825921328 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306420011744 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1284.263082: rtcpu_vinotify_event: tstamp:40825921466 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306420017312 data:0x000000003100000a
kworker/0:3-134 [000] .... 1284.263083: rtcpu_vinotify_error: tstamp:40825952036 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:8 vi_tstamp:1306430441952 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.319061: rtcpu_vinotify_error: tstamp:40826038522 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:9 vi_tstamp:1306433207744 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.319062: rtcpu_vinotify_event: tstamp:40826234252 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:8 vi_tstamp:1306430441952 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.319063: rtcpu_vinotify_event: tstamp:40826234386 cch:-1 vi:0 tag:FS channel:0x01 frame:9 vi_tstamp:1306432874528 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.319064: rtcpu_vinotify_event: tstamp:40826234536 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:9 vi_tstamp:1306433207744 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.375063: rtcpu_vinotify_event: tstamp:40827799348 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:9 vi_tstamp:1306488993312 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.375065: rtcpu_vinotify_event: tstamp:40827799504 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:9 vi_tstamp:1306488993728 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.375066: rtcpu_vinotify_event: tstamp:40827799641 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:9 vi_tstamp:1306488995840 data:0x0000000002020009
kworker/0:3-134 [000] .... 1284.375082: rtcpu_vinotify_event: tstamp:40827799793 cch:0 vi:0 tag:FE channel:0x00 frame:9 vi_tstamp:1306489223520 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.375082: rtcpu_vinotify_event: tstamp:40827799930 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:1306489223520 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.375083: rtcpu_vinotify_event: tstamp:40827800083 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:9 vi_tstamp:1306489227744 data:0x0000000000020009
kworker/0:3-134 [000] .... 1284.375084: rtcpu_vinotify_event: tstamp:40827877522 cch:0 vi:0 tag:FS channel:0x00 frame:10 vi_tstamp:1306491656128 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.375085: rtcpu_vinotify_event: tstamp:40827877683 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:1306491656128 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.375085: rtcpu_vinotify_event: tstamp:40827877823 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:10 vi_tstamp:1306491989248 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.375086: rtcpu_vinotify_event: tstamp:40827877972 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:10 vi_tstamp:1306491990496 data:0x000000000802000a
kworker/0:3-134 [000] .... 1284.375086: rtcpu_vinotify_event: tstamp:40827878106 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306492056928 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1284.375087: rtcpu_vinotify_event: tstamp:40828174882 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306492073184 data:0x000000003100000b
kworker/0:3-134 [000] .... 1284.375088: rtcpu_vinotify_error: tstamp:40828203937 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:9 vi_tstamp:1306502502944 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.375088: rtcpu_vinotify_error: tstamp:40828290427 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:10 vi_tstamp:1306505268736 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.375089: rtcpu_vinotify_event: tstamp:40828487961 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:9 vi_tstamp:1306502502944 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.375089: rtcpu_vinotify_event: tstamp:40828488111 cch:-1 vi:0 tag:FS channel:0x01 frame:10 vi_tstamp:1306504935520 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.375090: rtcpu_vinotify_event: tstamp:40828488242 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:10 vi_tstamp:1306505268736 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.431062: rtcpu_vinotify_event: tstamp:40830052919 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:10 vi_tstamp:1306561054304 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.431063: rtcpu_vinotify_event: tstamp:40830053059 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:10 vi_tstamp:1306561054720 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.431064: rtcpu_vinotify_event: tstamp:40830053224 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:10 vi_tstamp:1306561056832 data:0x000000000202000a
kworker/0:3-134 [000] .... 1284.431065: rtcpu_vinotify_event: tstamp:40830053357 cch:0 vi:0 tag:FE channel:0x00 frame:10 vi_tstamp:1306561284416 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.431065: rtcpu_vinotify_event: tstamp:40830053513 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:1306561284448 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.431066: rtcpu_vinotify_event: tstamp:40830053648 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:10 vi_tstamp:1306561288672 data:0x000000000002000a
kworker/0:3-134 [000] .... 1284.431067: rtcpu_vinotify_event: tstamp:40830129579 cch:0 vi:0 tag:FS channel:0x00 frame:11 vi_tstamp:1306563717024 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.431067: rtcpu_vinotify_event: tstamp:40830129722 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:1306563717056 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.431068: rtcpu_vinotify_event: tstamp:40830129873 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:11 vi_tstamp:1306564050240 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.431068: rtcpu_vinotify_event: tstamp:40830130007 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:11 vi_tstamp:1306564051488 data:0x000000000802000b
kworker/0:3-134 [000] .... 1284.431069: rtcpu_vinotify_event: tstamp:40830130157 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306564117312 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1284.431069: rtcpu_vinotify_event: tstamp:40830130291 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306564122912 data:0x000000003100000c
kworker/0:3-134 [000] .... 1284.431070: rtcpu_vinotify_error: tstamp:40830455844 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:10 vi_tstamp:1306574563936 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.431071: rtcpu_vinotify_event: tstamp:40830459895 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:10 vi_tstamp:1306574563936 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.431085: rtcpu_vinotify_error: tstamp:40830542329 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:11 vi_tstamp:1306577329632 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.431086: rtcpu_vinotify_event: tstamp:40830772853 cch:-1 vi:0 tag:FS channel:0x01 frame:11 vi_tstamp:1306576996512 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.431086: rtcpu_vinotify_event: tstamp:40830773003 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:11 vi_tstamp:1306577329632 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.487049: rtcpu_vinotify_event: tstamp:40832337932 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:11 vi_tstamp:1306633115232 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.487050: rtcpu_vinotify_event: tstamp:40832338088 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:11 vi_tstamp:1306633115648 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.487051: rtcpu_vinotify_event: tstamp:40832338225 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:11 vi_tstamp:1306633117760 data:0x000000000202000b
kworker/0:3-134 [000] .... 1284.487052: rtcpu_vinotify_event: tstamp:40832338377 cch:0 vi:0 tag:FE channel:0x00 frame:11 vi_tstamp:1306633345408 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.487052: rtcpu_vinotify_event: tstamp:40832338514 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:1306633345440 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.487053: rtcpu_vinotify_event: tstamp:40832338667 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:11 vi_tstamp:1306633349664 data:0x000000000002000b
kworker/0:3-134 [000] .... 1284.487054: rtcpu_vinotify_event: tstamp:40832650918 cch:0 vi:0 tag:FS channel:0x00 frame:12 vi_tstamp:1306635778016 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.487054: rtcpu_vinotify_event: tstamp:40832651079 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:1306635778048 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.487055: rtcpu_vinotify_event: tstamp:40832651217 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:12 vi_tstamp:1306636111232 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.487055: rtcpu_vinotify_event: tstamp:40832651367 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:12 vi_tstamp:1306636112480 data:0x000000000802000c
kworker/0:3-134 [000] .... 1284.487056: rtcpu_vinotify_event: tstamp:40832651499 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306636178944 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1284.487071: rtcpu_vinotify_event: tstamp:40832651647 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306636184480 data:0x000000003100000d
kworker/0:3-134 [000] .... 1284.487072: rtcpu_vinotify_error: tstamp:40832707752 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:11 vi_tstamp:1306646624832 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.487072: rtcpu_vinotify_event: tstamp:40832708348 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:11 vi_tstamp:1306646624832 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.487073: rtcpu_vinotify_error: tstamp:40832794239 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:12 vi_tstamp:1306649390624 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.543047: rtcpu_vinotify_event: tstamp:40832995214 cch:-1 vi:0 tag:FS channel:0x01 frame:12 vi_tstamp:1306649057440 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.543049: rtcpu_vinotify_event: tstamp:40832995349 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:12 vi_tstamp:1306649390624 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.543050: rtcpu_vinotify_event: tstamp:40834560218 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:12 vi_tstamp:1306705176224 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.543051: rtcpu_vinotify_event: tstamp:40834560371 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:12 vi_tstamp:1306705176640 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.543051: rtcpu_vinotify_event: tstamp:40834560528 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:12 vi_tstamp:1306705178752 data:0x000000000202000c
kworker/0:3-134 [000] .... 1284.543052: rtcpu_vinotify_event: tstamp:40834560666 cch:0 vi:0 tag:FE channel:0x00 frame:12 vi_tstamp:1306705406432 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.543053: rtcpu_vinotify_event: tstamp:40834560821 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:1306705406432 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.543053: rtcpu_vinotify_event: tstamp:40834560956 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:12 vi_tstamp:1306705410656 data:0x000000000002000c
kworker/0:3-134 [000] .... 1284.599040: rtcpu_vinotify_event: tstamp:40834873284 cch:0 vi:0 tag:FS channel:0x00 frame:13 vi_tstamp:1306707839008 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.599041: rtcpu_vinotify_event: tstamp:40834873430 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:1306707839040 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.599042: rtcpu_vinotify_event: tstamp:40834873621 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:13 vi_tstamp:1306708172128 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.599043: rtcpu_vinotify_event: tstamp:40834873758 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:13 vi_tstamp:1306708173408 data:0x000000000802000d
kworker/0:3-134 [000] .... 1284.599043: rtcpu_vinotify_event: tstamp:40834873909 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306708242784 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1284.599044: rtcpu_vinotify_event: tstamp:40834874043 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306708248352 data:0x000000003100000e
kworker/0:3-134 [000] .... 1284.599045: rtcpu_vinotify_error: tstamp:40834959655 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:12 vi_tstamp:1306718685824 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.599045: rtcpu_vinotify_event: tstamp:40835035708 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:12 vi_tstamp:1306718685824 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.599046: rtcpu_vinotify_event: tstamp:40835035843 cch:-1 vi:0 tag:FS channel:0x01 frame:13 vi_tstamp:1306721118432 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.599046: rtcpu_vinotify_error: tstamp:40835046141 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:13 vi_tstamp:1306721451616 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.599047: rtcpu_vinotify_event: tstamp:40835342761 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:13 vi_tstamp:1306721451616 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.655068: rtcpu_vinotify_event: tstamp:40836907766 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:13 vi_tstamp:1306777237216 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.655069: rtcpu_vinotify_event: tstamp:40836907923 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:13 vi_tstamp:1306777237632 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.655070: rtcpu_vinotify_event: tstamp:40836908058 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:13 vi_tstamp:1306777239744 data:0x000000000202000d
kworker/0:3-134 [000] .... 1284.655071: rtcpu_vinotify_event: tstamp:40836908207 cch:0 vi:0 tag:FE channel:0x00 frame:13 vi_tstamp:1306777467360 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.655071: rtcpu_vinotify_event: tstamp:40836908346 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:1306777467360 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.655072: rtcpu_vinotify_event: tstamp:40836908496 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:13 vi_tstamp:1306777471584 data:0x000000000002000d
kworker/0:3-134 [000] .... 1284.655072: rtcpu_vinotify_event: tstamp:40836908632 cch:0 vi:0 tag:FS channel:0x00 frame:14 vi_tstamp:1306779899936 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.655073: rtcpu_vinotify_event: tstamp:40836908787 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:1306779899936 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.655074: rtcpu_vinotify_event: tstamp:40836908929 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:14 vi_tstamp:1306780233120 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.655074: rtcpu_vinotify_event: tstamp:40836909078 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:14 vi_tstamp:1306780234400 data:0x000000000802000e
kworker/0:3-134 [000] .... 1284.655075: rtcpu_vinotify_event: tstamp:40836909212 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306780304128 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1284.655075: rtcpu_vinotify_event: tstamp:40836909361 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306780309696 data:0x000000003100000f
kworker/0:3-134 [000] .... 1284.655076: rtcpu_vinotify_error: tstamp:40837211564 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:13 vi_tstamp:1306790746816 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.655077: rtcpu_vinotify_event: tstamp:40837220752 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:13 vi_tstamp:1306790746816 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.655078: rtcpu_vinotify_error: tstamp:40837298015 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:14 vi_tstamp:1306793512544 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.655079: rtcpu_vinotify_event: tstamp:40837298608 cch:-1 vi:0 tag:FS channel:0x01 frame:14 vi_tstamp:1306793179424 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.655079: rtcpu_vinotify_event: tstamp:40837298740 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:14 vi_tstamp:1306793512544 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.711037: rtcpu_vinotify_event: tstamp:40839067504 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:14 vi_tstamp:1306849298112 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.711038: rtcpu_vinotify_event: tstamp:40839067656 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:14 vi_tstamp:1306849298560 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.711039: rtcpu_vinotify_event: tstamp:40839067810 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:14 vi_tstamp:1306849300672 data:0x000000000202000e
kworker/0:3-134 [000] .... 1284.711039: rtcpu_vinotify_event: tstamp:40839067944 cch:0 vi:0 tag:FE channel:0x00 frame:14 vi_tstamp:1306849528320 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.711040: rtcpu_vinotify_event: tstamp:40839068098 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:1306849528352 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.711041: rtcpu_vinotify_event: tstamp:40839068230 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:14 vi_tstamp:1306849532576 data:0x000000000002000e
kworker/0:3-134 [000] .... 1284.711042: rtcpu_vinotify_event: tstamp:40839380542 cch:0 vi:0 tag:FS channel:0x00 frame:15 vi_tstamp:1306851960928 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.711042: rtcpu_vinotify_event: tstamp:40839380685 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:15 vi_tstamp:1306851960928 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.711043: rtcpu_vinotify_event: tstamp:40839380835 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:15 vi_tstamp:1306852294112 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.711043: rtcpu_vinotify_event: tstamp:40839380969 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:15 vi_tstamp:1306852295392 data:0x000000000802000f
kworker/0:3-134 [000] .... 1284.711044: rtcpu_vinotify_event: tstamp:40839381119 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306852359840 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1284.711044: rtcpu_vinotify_event: tstamp:40839381253 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306852365376 data:0x0000000031000010
kworker/0:3-134 [000] .... 1284.711059: rtcpu_vinotify_error: tstamp:40839463466 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:14 vi_tstamp:1306862807776 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.711060: rtcpu_vinotify_error: tstamp:40839549951 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:15 vi_tstamp:1306865573536 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.711060: rtcpu_vinotify_event: tstamp:40839693469 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:14 vi_tstamp:1306862807776 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.711061: rtcpu_vinotify_event: tstamp:40839693600 cch:-1 vi:0 tag:FS channel:0x01 frame:15 vi_tstamp:1306865240352 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.711062: rtcpu_vinotify_event: tstamp:40839693748 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:15 vi_tstamp:1306865573536 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.767041: rtcpu_vinotify_event: tstamp:40841293263 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:15 vi_tstamp:1306921359104 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.767044: rtcpu_vinotify_event: tstamp:40841602835 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:15 vi_tstamp:1306921359552 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.767044: rtcpu_vinotify_event: tstamp:40841602974 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:15 vi_tstamp:1306921362656 data:0x000000000202000f
kworker/0:3-134 [000] .... 1284.767045: rtcpu_vinotify_event: tstamp:40841603125 cch:0 vi:0 tag:FE channel:0x00 frame:15 vi_tstamp:1306921589312 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.767045: rtcpu_vinotify_event: tstamp:40841603264 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:15 vi_tstamp:1306921589344 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.767046: rtcpu_vinotify_event: tstamp:40841603413 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:15 vi_tstamp:1306921593568 data:0x000000000002000f
kworker/0:3-134 [000] .... 1284.767046: rtcpu_vinotify_event: tstamp:40841603545 cch:0 vi:0 tag:FS channel:0x00 frame:16 vi_tstamp:1306924021920 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.767047: rtcpu_vinotify_event: tstamp:40841603698 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:1306924021920 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.767066: rtcpu_vinotify_event: tstamp:40841603832 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:16 vi_tstamp:1306924355040 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.767067: rtcpu_vinotify_event: tstamp:40841603981 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:16 vi_tstamp:1306924356320 data:0x0000000008020010
kworker/0:3-134 [000] .... 1284.767067: rtcpu_vinotify_event: tstamp:40841604113 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306924421024 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1284.767068: rtcpu_vinotify_event: tstamp:40841604263 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306924426624 data:0x0000000031000011
kworker/0:3-134 [000] .... 1284.823033: rtcpu_vinotify_error: tstamp:40841715371 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:15 vi_tstamp:1306934868736 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.823034: rtcpu_vinotify_error: tstamp:40841801861 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:16 vi_tstamp:1306937634528 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.823035: rtcpu_vinotify_event: tstamp:40841915761 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:15 vi_tstamp:1306934868736 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.823035: rtcpu_vinotify_event: tstamp:40841915909 cch:-1 vi:0 tag:FS channel:0x01 frame:16 vi_tstamp:1306937301344 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.823036: rtcpu_vinotify_event: tstamp:40841916040 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:16 vi_tstamp:1306937634528 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.879030: rtcpu_vinotify_event: tstamp:40843545178 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:16 vi_tstamp:1306993420096 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.879032: rtcpu_vinotify_event: tstamp:40843545323 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:16 vi_tstamp:1306993420544 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.879034: rtcpu_vinotify_event: tstamp:40843856432 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:16 vi_tstamp:1306993423648 data:0x0000000002020010
kworker/0:3-134 [000] .... 1284.879035: rtcpu_vinotify_event: tstamp:40843856571 cch:0 vi:0 tag:FE channel:0x00 frame:16 vi_tstamp:1306993650272 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.879035: rtcpu_vinotify_event: tstamp:40843856729 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:1306993650272 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.879036: rtcpu_vinotify_event: tstamp:40843856862 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:16 vi_tstamp:1306993654496 data:0x0000000000020010
kworker/0:3-134 [000] .... 1284.879036: rtcpu_vinotify_event: tstamp:40843857014 cch:0 vi:0 tag:FS channel:0x00 frame:17 vi_tstamp:1306996082880 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.879037: rtcpu_vinotify_event: tstamp:40843857150 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:1306996082880 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.879038: rtcpu_vinotify_event: tstamp:40843857302 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:17 vi_tstamp:1306996416032 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.879038: rtcpu_vinotify_event: tstamp:40843857434 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:17 vi_tstamp:1306996417312 data:0x0000000008020011
kworker/0:3-134 [000] .... 1284.879039: rtcpu_vinotify_event: tstamp:40843857583 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306996486688 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1284.879039: rtcpu_vinotify_event: tstamp:40843857717 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1306996492288 data:0x0000000031000012
kworker/0:3-134 [000] .... 1284.879054: rtcpu_vinotify_error: tstamp:40843967452 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:16 vi_tstamp:1307006929728 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.879055: rtcpu_vinotify_error: tstamp:40844053763 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:17 vi_tstamp:1307009695456 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.879055: rtcpu_vinotify_event: tstamp:40844169484 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:16 vi_tstamp:1307006929728 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.879056: rtcpu_vinotify_event: tstamp:40844169624 cch:-1 vi:0 tag:FS channel:0x01 frame:17 vi_tstamp:1307009362336 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.879056: rtcpu_vinotify_event: tstamp:40844169772 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:17 vi_tstamp:1307009695456 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.935039: rtcpu_vinotify_event: tstamp:40845797104 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:17 vi_tstamp:1307065481056 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.935041: rtcpu_vinotify_event: tstamp:40845797263 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:17 vi_tstamp:1307065481472 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.935041: rtcpu_vinotify_event: tstamp:40845797400 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:17 vi_tstamp:1307065483616 data:0x0000000002020011
kworker/0:3-134 [000] .... 1284.935043: rtcpu_vinotify_event: tstamp:40846078727 cch:0 vi:0 tag:FE channel:0x00 frame:17 vi_tstamp:1307065711264 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.935044: rtcpu_vinotify_event: tstamp:40846078881 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:1307065711264 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.935045: rtcpu_vinotify_event: tstamp:40846079034 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:17 vi_tstamp:1307065715488 data:0x0000000000020011
kworker/0:3-134 [000] .... 1284.935045: rtcpu_vinotify_event: tstamp:40846079167 cch:0 vi:0 tag:FS channel:0x00 frame:18 vi_tstamp:1307068143840 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.935046: rtcpu_vinotify_event: tstamp:40846079322 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:18 vi_tstamp:1307068143840 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.935046: rtcpu_vinotify_event: tstamp:40846079454 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:18 vi_tstamp:1307068477024 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.935047: rtcpu_vinotify_event: tstamp:40846079604 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:18 vi_tstamp:1307068478304 data:0x0000000008020012
kworker/0:3-134 [000] .... 1284.935047: rtcpu_vinotify_event: tstamp:40846079737 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307068543872 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1284.935063: rtcpu_vinotify_event: tstamp:40846079885 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307068549440 data:0x0000000031000013
kworker/0:3-134 [000] .... 1284.935064: rtcpu_vinotify_error: tstamp:40846219182 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:17 vi_tstamp:1307078990688 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.935065: rtcpu_vinotify_error: tstamp:40846305668 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:18 vi_tstamp:1307081756448 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.935065: rtcpu_vinotify_event: tstamp:40846391775 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:17 vi_tstamp:1307078990688 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.935066: rtcpu_vinotify_event: tstamp:40846391923 cch:-1 vi:0 tag:FS channel:0x01 frame:18 vi_tstamp:1307081423264 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.935066: rtcpu_vinotify_event: tstamp:40846392054 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:18 vi_tstamp:1307081756448 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.991023: rtcpu_vinotify_event: tstamp:40848057631 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:18 vi_tstamp:1307137542048 data:0x0000000004370002
kworker/0:3-134 [000] .... 1284.991025: rtcpu_vinotify_event: tstamp:40848057770 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:18 vi_tstamp:1307137542464 data:0x0000000000000000
kworker/0:3-134 [000] .... 1284.991026: rtcpu_vinotify_event: tstamp:40848057923 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:18 vi_tstamp:1307137544576 data:0x0000000002020012
kworker/0:3-134 [000] .... 1284.991026: rtcpu_vinotify_event: tstamp:40848058054 cch:0 vi:0 tag:FE channel:0x00 frame:18 vi_tstamp:1307137772256 data:0x0000000000000020
kworker/0:3-134 [000] .... 1284.991027: rtcpu_vinotify_event: tstamp:40848363746 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:18 vi_tstamp:1307137772256 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.991028: rtcpu_vinotify_event: tstamp:40848363886 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:18 vi_tstamp:1307137777472 data:0x0000000000020012
kworker/0:3-134 [000] .... 1284.991029: rtcpu_vinotify_event: tstamp:40848364042 cch:0 vi:0 tag:FS channel:0x00 frame:19 vi_tstamp:1307140204832 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.991029: rtcpu_vinotify_event: tstamp:40848364182 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:19 vi_tstamp:1307140204832 data:0x0000000800000000
kworker/0:3-134 [000] .... 1284.991045: rtcpu_vinotify_event: tstamp:40848364333 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:19 vi_tstamp:1307140537984 data:0x0000000000000001
kworker/0:3-134 [000] .... 1284.991045: rtcpu_vinotify_event: tstamp:40848364469 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:19 vi_tstamp:1307140539232 data:0x0000000008020013
kworker/0:3-134 [000] .... 1284.991046: rtcpu_vinotify_event: tstamp:40848364619 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307140609408 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1284.991046: rtcpu_vinotify_event: tstamp:40848364751 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307140614976 data:0x0000000031000014
kworker/0:3-134 [000] .... 1284.991047: rtcpu_vinotify_error: tstamp:40848471086 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:18 vi_tstamp:1307151051680 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.991048: rtcpu_vinotify_error: tstamp:40848557573 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:19 vi_tstamp:1307153817440 data:0x0000000000000569
kworker/0:3-134 [000] .... 1284.991048: rtcpu_vinotify_event: tstamp:40848676668 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:18 vi_tstamp:1307151051680 data:0x0000000000000220
kworker/0:3-134 [000] .... 1284.991049: rtcpu_vinotify_event: tstamp:40848676799 cch:-1 vi:0 tag:FS channel:0x01 frame:19 vi_tstamp:1307153484256 data:0x0000000000000010
kworker/0:3-134 [000] .... 1284.991049: rtcpu_vinotify_event: tstamp:40848676945 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:19 vi_tstamp:1307153817440 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.047020: rtcpu_vinotify_event: tstamp:40850309534 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:19 vi_tstamp:1307209603008 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.047022: rtcpu_vinotify_event: tstamp:40850309689 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:19 vi_tstamp:1307209603456 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.047022: rtcpu_vinotify_event: tstamp:40850309824 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:19 vi_tstamp:1307209605568 data:0x0000000002020013
kworker/0:3-134 [000] .... 1285.047023: rtcpu_vinotify_event: tstamp:40850309973 cch:0 vi:0 tag:FE channel:0x00 frame:19 vi_tstamp:1307209833184 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.047023: rtcpu_vinotify_event: tstamp:40850310111 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:19 vi_tstamp:1307209833184 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.103023: rtcpu_vinotify_event: tstamp:40850617329 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:19 vi_tstamp:1307209838400 data:0x0000000000020013
kworker/0:3-134 [000] .... 1285.103024: rtcpu_vinotify_event: tstamp:40850617473 cch:0 vi:0 tag:FS channel:0x00 frame:20 vi_tstamp:1307212265760 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.103025: rtcpu_vinotify_event: tstamp:40850617630 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:20 vi_tstamp:1307212265792 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.103025: rtcpu_vinotify_event: tstamp:40850617764 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:20 vi_tstamp:1307212598944 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.103026: rtcpu_vinotify_event: tstamp:40850617917 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:20 vi_tstamp:1307212600224 data:0x0000000008020014
kworker/0:3-134 [000] .... 1285.103027: rtcpu_vinotify_event: tstamp:40850618050 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307212666272 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1285.103027: rtcpu_vinotify_event: tstamp:40850618199 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307212671840 data:0x0000000031000015
kworker/0:3-134 [000] .... 1285.103028: rtcpu_vinotify_error: tstamp:40850723005 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:19 vi_tstamp:1307223112672 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.103029: rtcpu_vinotify_error: tstamp:40850809478 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:20 vi_tstamp:1307225878368 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.103046: rtcpu_vinotify_event: tstamp:40850930376 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:19 vi_tstamp:1307223112672 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.103046: rtcpu_vinotify_event: tstamp:40850930524 cch:-1 vi:0 tag:FS channel:0x01 frame:20 vi_tstamp:1307225545248 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.103047: rtcpu_vinotify_event: tstamp:40850930655 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:20 vi_tstamp:1307225878368 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.159013: rtcpu_vinotify_event: tstamp:40852561469 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:20 vi_tstamp:1307281663968 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.159014: rtcpu_vinotify_event: tstamp:40852561608 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:20 vi_tstamp:1307281664384 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.159015: rtcpu_vinotify_event: tstamp:40852561761 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:20 vi_tstamp:1307281666496 data:0x0000000002020014
kworker/0:3-134 [000] .... 1285.159016: rtcpu_vinotify_event: tstamp:40852561893 cch:0 vi:0 tag:FE channel:0x00 frame:20 vi_tstamp:1307281894176 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.159016: rtcpu_vinotify_event: tstamp:40852562061 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:20 vi_tstamp:1307281894176 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.159017: rtcpu_vinotify_event: tstamp:40852562194 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:20 vi_tstamp:1307281898400 data:0x0000000000020014
kworker/0:3-134 [000] .... 1285.159018: rtcpu_vinotify_event: tstamp:40852870907 cch:0 vi:0 tag:FS channel:0x00 frame:21 vi_tstamp:1307284326752 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.159032: rtcpu_vinotify_event: tstamp:40852871051 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:21 vi_tstamp:1307284326784 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.159033: rtcpu_vinotify_event: tstamp:40852871204 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:21 vi_tstamp:1307284659936 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.159033: rtcpu_vinotify_event: tstamp:40852871337 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:21 vi_tstamp:1307284661216 data:0x0000000008020015
kworker/0:3-134 [000] .... 1285.159034: rtcpu_vinotify_event: tstamp:40852871488 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307284727168 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1285.159035: rtcpu_vinotify_event: tstamp:40852871621 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307284733088 data:0x0000000031000016
kworker/0:3-134 [000] .... 1285.159035: rtcpu_vinotify_error: tstamp:40852974897 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:20 vi_tstamp:1307295173568 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.159036: rtcpu_vinotify_error: tstamp:40853061419 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:21 vi_tstamp:1307297939392 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.159037: rtcpu_vinotify_event: tstamp:40853183962 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:20 vi_tstamp:1307295173568 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.159037: rtcpu_vinotify_event: tstamp:40853184094 cch:-1 vi:0 tag:FS channel:0x01 frame:21 vi_tstamp:1307297606176 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.159038: rtcpu_vinotify_event: tstamp:40853184242 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:21 vi_tstamp:1307297939392 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.215016: rtcpu_vinotify_event: tstamp:40854887907 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:21 vi_tstamp:1307353724960 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.215017: rtcpu_vinotify_event: tstamp:40854888067 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:21 vi_tstamp:1307353725376 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.215018: rtcpu_vinotify_event: tstamp:40854888206 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:21 vi_tstamp:1307353727488 data:0x0000000002020015
kworker/0:3-134 [000] .... 1285.215019: rtcpu_vinotify_event: tstamp:40854888356 cch:0 vi:0 tag:FE channel:0x00 frame:21 vi_tstamp:1307353955168 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.215019: rtcpu_vinotify_event: tstamp:40854888495 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:21 vi_tstamp:1307353955168 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.215020: rtcpu_vinotify_event: tstamp:40854888647 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:21 vi_tstamp:1307353959392 data:0x0000000000020015
kworker/0:3-134 [000] .... 1285.215020: rtcpu_vinotify_event: tstamp:40854888780 cch:0 vi:0 tag:FS channel:0x00 frame:22 vi_tstamp:1307356387744 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.215022: rtcpu_vinotify_event: tstamp:40855187237 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:22 vi_tstamp:1307356387776 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.215022: rtcpu_vinotify_event: tstamp:40855187377 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:22 vi_tstamp:1307356720864 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.215023: rtcpu_vinotify_event: tstamp:40855187534 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:22 vi_tstamp:1307356722144 data:0x0000000008020016
kworker/0:3-134 [000] .... 1285.215041: rtcpu_vinotify_event: tstamp:40855187666 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307356788928 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1285.215041: rtcpu_vinotify_event: tstamp:40855187818 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307356794496 data:0x0000000031000017
kworker/0:3-134 [000] .... 1285.215042: rtcpu_vinotify_error: tstamp:40855226804 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:21 vi_tstamp:1307367234560 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.215043: rtcpu_vinotify_error: tstamp:40855313286 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:22 vi_tstamp:1307370000352 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.215043: rtcpu_vinotify_event: tstamp:40855500164 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:21 vi_tstamp:1307367234560 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.215044: rtcpu_vinotify_event: tstamp:40855500312 cch:-1 vi:0 tag:FS channel:0x01 frame:22 vi_tstamp:1307369667168 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.215044: rtcpu_vinotify_event: tstamp:40855500445 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:22 vi_tstamp:1307370000352 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.271007: rtcpu_vinotify_event: tstamp:40857065354 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:22 vi_tstamp:1307425785952 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.271008: rtcpu_vinotify_event: tstamp:40857065494 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:22 vi_tstamp:1307425786368 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.271009: rtcpu_vinotify_event: tstamp:40857065649 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:22 vi_tstamp:1307425788480 data:0x0000000002020016
kworker/0:3-134 [000] .... 1285.271009: rtcpu_vinotify_event: tstamp:40857065782 cch:0 vi:0 tag:FE channel:0x00 frame:22 vi_tstamp:1307426016064 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.271010: rtcpu_vinotify_event: tstamp:40857065939 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:22 vi_tstamp:1307426016096 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.271010: rtcpu_vinotify_event: tstamp:40857066077 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:22 vi_tstamp:1307426020288 data:0x0000000000020016
kworker/0:3-134 [000] .... 1285.271011: rtcpu_vinotify_event: tstamp:40857139815 cch:0 vi:0 tag:FS channel:0x00 frame:23 vi_tstamp:1307428448672 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.271011: rtcpu_vinotify_event: tstamp:40857139956 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:23 vi_tstamp:1307428448672 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.271012: rtcpu_vinotify_event: tstamp:40857440837 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:23 vi_tstamp:1307428781856 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.271013: rtcpu_vinotify_event: tstamp:40857440975 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:23 vi_tstamp:1307428783136 data:0x0000000008020017
kworker/0:3-134 [000] .... 1285.271014: rtcpu_vinotify_event: tstamp:40857441128 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307428850304 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1285.271014: rtcpu_vinotify_event: tstamp:40857441262 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307428855872 data:0x0000000031000018
kworker/0:3-134 [000] .... 1285.327001: rtcpu_vinotify_error: tstamp:40857478710 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:22 vi_tstamp:1307439295552 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.327003: rtcpu_vinotify_error: tstamp:40857565203 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:23 vi_tstamp:1307442061280 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.327004: rtcpu_vinotify_event: tstamp:40857753763 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:22 vi_tstamp:1307439295552 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.327004: rtcpu_vinotify_event: tstamp:40857753896 cch:-1 vi:0 tag:FS channel:0x01 frame:23 vi_tstamp:1307441728160 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.327006: rtcpu_vinotify_event: tstamp:40857754045 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:23 vi_tstamp:1307442061280 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.383009: rtcpu_vinotify_event: tstamp:40859318793 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:23 vi_tstamp:1307497846848 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.383011: rtcpu_vinotify_event: tstamp:40859318957 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:23 vi_tstamp:1307497847296 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.383011: rtcpu_vinotify_event: tstamp:40859319091 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:23 vi_tstamp:1307497849408 data:0x0000000002020017
kworker/0:3-134 [000] .... 1285.383012: rtcpu_vinotify_event: tstamp:40859319243 cch:0 vi:0 tag:FE channel:0x00 frame:23 vi_tstamp:1307498077056 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.383013: rtcpu_vinotify_event: tstamp:40859319382 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:23 vi_tstamp:1307498077088 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.383013: rtcpu_vinotify_event: tstamp:40859319532 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:23 vi_tstamp:1307498081312 data:0x0000000000020017
kworker/0:3-134 [000] .... 1285.383014: rtcpu_vinotify_event: tstamp:40859403835 cch:0 vi:0 tag:FS channel:0x00 frame:24 vi_tstamp:1307500509664 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.383015: rtcpu_vinotify_event: tstamp:40859403997 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:24 vi_tstamp:1307500509664 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.383015: rtcpu_vinotify_event: tstamp:40859404133 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:24 vi_tstamp:1307500842848 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.383016: rtcpu_vinotify_event: tstamp:40859694423 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:24 vi_tstamp:1307500845120 data:0x0000000008020018
kworker/0:3-134 [000] .... 1285.383016: rtcpu_vinotify_event: tstamp:40859694567 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307500924032 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1285.383017: rtcpu_vinotify_event: tstamp:40859694722 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307500929632 data:0x0000000031000019
kworker/0:3-134 [000] .... 1285.383036: rtcpu_vinotify_error: tstamp:40859730615 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:23 vi_tstamp:1307511356480 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.383037: rtcpu_vinotify_error: tstamp:40859817097 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:24 vi_tstamp:1307514122272 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.383037: rtcpu_vinotify_event: tstamp:40860007477 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:23 vi_tstamp:1307511356480 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.383038: rtcpu_vinotify_event: tstamp:40860007626 cch:-1 vi:0 tag:FS channel:0x01 frame:24 vi_tstamp:1307513789088 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.383038: rtcpu_vinotify_event: tstamp:40860007757 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:24 vi_tstamp:1307514122272 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.438997: rtcpu_vinotify_event: tstamp:40861573124 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:24 vi_tstamp:1307569907840 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.438998: rtcpu_vinotify_event: tstamp:40861573265 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:24 vi_tstamp:1307569908288 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.438999: rtcpu_vinotify_event: tstamp:40861573421 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:24 vi_tstamp:1307569910400 data:0x0000000002020018
kworker/0:3-134 [000] .... 1285.439000: rtcpu_vinotify_event: tstamp:40861573557 cch:0 vi:0 tag:FE channel:0x00 frame:24 vi_tstamp:1307570138048 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.439000: rtcpu_vinotify_event: tstamp:40861573714 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:24 vi_tstamp:1307570138080 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.439001: rtcpu_vinotify_event: tstamp:40861573848 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:24 vi_tstamp:1307570142272 data:0x0000000000020018
kworker/0:3-134 [000] .... 1285.439017: rtcpu_vinotify_event: tstamp:40861655826 cch:0 vi:0 tag:FS channel:0x00 frame:25 vi_tstamp:1307572570656 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.439017: rtcpu_vinotify_event: tstamp:40861655970 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:25 vi_tstamp:1307572570656 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.439018: rtcpu_vinotify_event: tstamp:40861656122 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:25 vi_tstamp:1307572903776 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.439018: rtcpu_vinotify_event: tstamp:40861656254 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:25 vi_tstamp:1307572905056 data:0x0000000008020019
kworker/0:3-134 [000] .... 1285.439019: rtcpu_vinotify_event: tstamp:40861948010 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307572989312 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1285.439020: rtcpu_vinotify_event: tstamp:40861948143 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307572995200 data:0x000000003100001a
kworker/0:3-134 [000] .... 1285.439020: rtcpu_vinotify_error: tstamp:40861982518 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:24 vi_tstamp:1307583417472 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.439021: rtcpu_vinotify_error: tstamp:40862069003 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:25 vi_tstamp:1307586183264 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.439021: rtcpu_vinotify_event: tstamp:40862261075 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:24 vi_tstamp:1307583417472 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.439022: rtcpu_vinotify_event: tstamp:40862261210 cch:-1 vi:0 tag:FS channel:0x01 frame:25 vi_tstamp:1307585850080 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.439022: rtcpu_vinotify_event: tstamp:40862261359 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:25 vi_tstamp:1307586183264 data:0x0000000000000569
kworker/0:3-134 [000] .... 1285.495000: rtcpu_vinotify_event: tstamp:40863826245 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x22 frame:0 vi_tstamp:1307634764160 data:0xcd9cdf0010000000
kworker/0:3-134 [000] .... 1285.495002: rtcpu_vinotify_event: tstamp:40863826402 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x22 frame:0 vi_tstamp:1307634769760 data:0x0000000031000001
kworker/0:3-134 [000] .... 1285.495003: rtcpu_vinotify_event: tstamp:40863826539 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:25 vi_tstamp:1307641968832 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.495004: rtcpu_vinotify_event: tstamp:40863826691 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:25 vi_tstamp:1307641969280 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.495004: rtcpu_vinotify_event: tstamp:40863826825 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:25 vi_tstamp:1307641971392 data:0x0000000002020019
kworker/0:3-134 [000] .... 1285.495005: rtcpu_vinotify_event: tstamp:40863826979 cch:0 vi:0 tag:FE channel:0x00 frame:25 vi_tstamp:1307642198976 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.495005: rtcpu_vinotify_event: tstamp:40863827117 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:25 vi_tstamp:1307642198976 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.495006: rtcpu_vinotify_event: tstamp:40863827268 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:25 vi_tstamp:1307642203200 data:0x0000000000020019
kworker/0:3-134 [000] .... 1285.495007: rtcpu_vinotify_event: tstamp:40863907614 cch:0 vi:0 tag:FS channel:0x00 frame:26 vi_tstamp:1307644631584 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.495007: rtcpu_vinotify_event: tstamp:40863907775 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:26 vi_tstamp:1307644631584 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.495008: rtcpu_vinotify_event: tstamp:40863907910 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:26 vi_tstamp:1307644964768 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.495028: rtcpu_vinotify_event: tstamp:40864201761 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:26 vi_tstamp:1307644967040 data:0x000000000802001a
kworker/0:3-134 [000] .... 1285.495029: rtcpu_vinotify_event: tstamp:40864201897 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307645044096 data:0xcd9ce50010000000
kworker/0:3-134 [000] .... 1285.495029: rtcpu_vinotify_event: tstamp:40864202050 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307645049760 data:0x000000003100001b
kworker/0:3-134 [000] .... 1285.495030: rtcpu_vinotify_error: tstamp:40864234425 cch:1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:25 vi_tstamp:1307655478464 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.550990: rtcpu_vinotify_event: tstamp:40864514641 cch:1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:25 vi_tstamp:1307655478464 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.550992: rtcpu_vinotify_event: tstamp:40864514797 cch:1 vi:0 tag:FS channel:0x01 frame:26 vi_tstamp:1307657911072 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.550993: rtcpu_vinotify_event: tstamp:40864514937 cch:1 vi:0 tag:ATOMP_FS channel:0x00 frame:26 vi_tstamp:1307657911072 data:0x0000000400000000
kworker/0:3-134 [000] .... 1285.550993: rtcpu_vinotify_event: tstamp:40864515090 cch:1 vi:0 tag:CHANSEL_PXL_SOF channel:0x22 frame:26 vi_tstamp:1307658244192 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.550994: rtcpu_vinotify_event: tstamp:40864515226 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x22 frame:26 vi_tstamp:1307658245440 data:0x0000000008020001
kworker/0:3-134 [000] .... 1285.550995: rtcpu_vinotify_event: tstamp:40866079702 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:26 vi_tstamp:1307714029760 data:0x0000000004370002
kworker/0:3-134 [000] .... 1285.550996: rtcpu_vinotify_event: tstamp:40866079842 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:26 vi_tstamp:1307714030208 data:0x0000000000000000
kworker/0:3-134 [000] .... 1285.550996: rtcpu_vinotify_event: tstamp:40866079998 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:26 vi_tstamp:1307714032288 data:0x000000000202001a
kworker/0:3-134 [000] .... 1285.550997: rtcpu_vinotify_event: tstamp:40866080134 cch:0 vi:0 tag:FE channel:0x00 frame:26 vi_tstamp:1307714259968 data:0x0000000000000020
kworker/0:3-134 [000] .... 1285.550998: rtcpu_vinotify_event: tstamp:40866080288 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:26 vi_tstamp:1307714259968 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.550998: rtcpu_vinotify_event: tstamp:40866080422 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:26 vi_tstamp:1307714264192 data:0x000000000002001a
kworker/0:3-134 [000] .... 1285.551015: rtcpu_vinotify_event: tstamp:40866147425 cch:0 vi:0 tag:FS channel:0x00 frame:27 vi_tstamp:1307716692576 data:0x0000000000000010
kworker/0:3-134 [000] .... 1285.551016: rtcpu_vinotify_event: tstamp:40866147563 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:27 vi_tstamp:1307716692576 data:0x0000000800000000
kworker/0:3-134 [000] .... 1285.607003: rtcpu_vinotify_event: tstamp:40866455384 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:27 vi_tstamp:1307717025760 data:0x0000000000000001
kworker/0:3-134 [000] .... 1285.607005: rtcpu_vinotify_event: tstamp:40866455524 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:27 vi_tstamp:1307717027040 data:0x000000000802001b
kworker/0:3-134 [000] .... 1285.607006: rtcpu_vinotify_event: tstamp:40866455677 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307717092480 data:0xcd9ce20010000000
kworker/0:3-134 [000] .... 1285.607007: rtcpu_vinotify_event: tstamp:40866455811 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1307717098144 data:0x000000003100001c
kworker/0:3-134 [000] .... 1285.607008: rtcpu_vinotify_error: tstamp:40866486765 cch:1 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:26 vi_tstamp:1307727539392 data:0x0000000000000220
kworker/0:3-134 [000] .... 1285.607009: rtcpu_string: tstamp:40866487679 id:0x04010000 str:"ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "
kworker/0:3-134 [000] .... 1285.607011: rtcpu_string: tstamp:40866487782 id:0x04010000 str:"""
kworker/0:3-134 [000] .... 1285.607012: rtcpu_string: tstamp:40866488612 id:0x04010000 str:"General error queue is out of sync with frame qu"
kworker/0:3-134 [000] .... 1285.607014: rtcpu_string: tstamp:40866488714 id:0x04010000 str:"eue. ts=1307655478464 sof_ts=1307658244192 gerro"
kworker/0:3-134 [000] .... 1285.607015: rtcpu_string: tstamp:40866488820 id:0x04010000 str:"r_code=2 gerror_data=220 notify_bits=10"
kworker/0:3-134 [000] .... 1285.607016: rtcpu_string: tstamp:40866488973 id:0x04010000 str:""
</pre>
What can be the problem?
