The attached code is crashing strangely and I’m not quite sure why.
It’s a low level crash and generates a dump. The dump seems to be uploading to your (NVidia’s) servers. So perhaps the following id is useful from the crash log:
d4d2f350-254a-437b-a3de-96e1b1dae560
The code that’s crashing is below:
import omni.ui as ui
from omni.ui import DockPreference
class NewUserDialog(ui.Window):
_username_model:ui.SimpleStringModel
_printname_model:ui.SimpleStringModel
_password_model:ui.SimpleStringModel
def __init__(self, title: str, dockPreference: DockPreference = DockPreference.DISABLED, **kwargs) -> None:
self._username_model = ui.SimpleStringModel()
self._printname_model = ui.SimpleStringModel()
self._password_model = ui.SimpleStringModel()
super().__init__(title, dockPreference, **kwargs)
self._build_window()
self.set_visibility_changed_fn(self._on_vis_changed)
def _build_window(self):
with self.frame:
with ui.VStack(height=0):
ui.StringField(self._username_model)
ui.StringField(self._printname_model)
ui.StringField(self._password_model)
with ui.HStack(width=0):
ui.Button("Create", clicked_fn=lambda: self._on_create())
ui.Button("Cancel", clicked_fn=lambda: self._on_cancel())
def _on_create(self):
pass
def _on_cancel(self):
self.visible = False
def _on_vis_changed(self,vis:bool):
if not vis:
self.destroy()
def destroy(self) -> None:
self._username_model = None
self._printname_model = None
self._password_model = None
print("destroying!")
super().destroy()
Here’s the weird bit. If you click the “Cancel” button, then I crash out with the minidump referenced above. But, if you instead click the ‘x’ button for the window, which presumably just sets visibility to False: it DOES NOT crash. This suggests to me that there’s something having to do with the call coming from within the button’s loop? Or perhaps I’m doing this all wrong. Thoughts?
I’ve tried making those clicked_fn args as lambdas, and also as simple function pointers. I’ve also tried defining the function just above inside the method rather than as a class function. All with the same results: a crash.
Anyhow, without a debug-able version of carb (which I presume to be c++ code) I cannot debug any further and find what is probably a stupid mistake on my part.
