Are there specifications available on the audio codec that is used on the Jetson Carrier Board (attached to the HD Audio Header)? Specifically, I’d like to know the power rating of the output, to determine if an additional amplification stage is needed for my application.
Hi, carrier board is just for development not for product. The codec on board is Realtek ALC5658, you need to check with vendor to decide if need to add external PA.
extremely difficult to find out the ALC5658 datasheet and the register map, anyone’s got it? the component is way too old.
ESZ
