Below is the updated code from .dts
sdhci@3460000 {
compatible = "nvidia,tegra194-sdhci";
reg = <0x0 0x3460000 0x0 0x20000>;
interrupts = <0x0 0x41 0x4>;
iommus = <0x2 0x17>;
dma-coherent;
max-clk-limit = <0xbebc200>;
ddr-clk-limit = <0x30a32c0>;
bus-width = <0x8>;
only-1-8-v;
ignore-pm-notify;
keep-power-in-suspend;
non-removable;
cap-mmc-highspeed;
cap-sd-highspeed;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
mmc-hs400-1_8v;
mmc-hs400-enhanced-strobe;
nvidia,min-tap-delay = <0x60>;
nvidia,max-tap-delay = <0x8b>;
nvidia,en-periodic-cflush;
nvidia,periodic-cflush-to = <0xa>;
resets = <0x5 0x55>;
reset-names = "sdhci";
pll_source = "pll_p", "pll_c4_out0_lj";
nvidia,set-parent-clk;
nvidia,parent_clk_list = "pll_p", "pll_p", "NULL", "NULL", "NULL", "NULL", "NULL", "NULL", "pll_p", "pll_c4_out0_lj", "pll_c4_out0_lj";
clocks = <0x4 0x7b 0x4 0x66 0x4 0xed 0x4 0xdb>;
clock-names = "sdmmc", "pll_p", "pll_c4_out0_lj", "sdmmc_legacy_tm";
status = "okay";
vmmc-supply = <0x1b>;
vqmmc-supply = <0x18>;
uhs-mask = <0x0>;
nvidia,enable-hwcq;
linux,phandle = <0xbf>;
phandle = <0xbf>;
prod-settings {
#prod-cells = <0x4>;
prod {
prod = <0x0 0x4 0xfff 0x200 0x0 0x28 0x20 0x20 0x0 0x100 0x1fff004a 0x14080000 0x0 0x10c 0x3f00 0x2800 0x0 0x128 0x43000000 0x0 0x0 0x1ac 0x4 0x0 0x0 0x1c0 0x1fc0 0x40 0x0 0x1c4 0x3ff77 0x400 0x0 0x1e0 0x87f7f000 0xa0a000 0x0 0x1e4 0x20000000 0x20000000 0x0 0x204 0x80000000 0x0 0x0 0x218 0x80000000 0x0>;
prod_c_ds {
prod = <0x0 0x100 0x1fff0000 0x14080000>;
prod_c_hs {
prod_c_cqe {
prod = <0x0 0xf008 0x1 0x1>;
prod_c_ddr52 {
prod = <0x0 0x3c 0x70000 0x40000 0x0 0x120 0xfffe 0x298>;
prod_c_hs200 {
prod = <0x0 0x3c 0x70000 0x30000 0x0 0x1c0 0xe000 0x4000>;
prod_c_hs400 {
prod = <0x0 0x3c 0x70000 0x50000 0x0 0x100 0xff0008 0x80008 0x0 0x1c0 0xe000 0x4000 0x0 0x1e4 0x7f7f 0x0>;
prod_c_sdr50 {
prod = <0x0 0x3c 0x70000 0x20000>;
sdhci@3440000 {
reg = <0x0 0x3440000 0x0 0x20000>;
interrupts = <0x0 0x40 0x4>;
iommus = <0x2 0x18>;
dma-coherent;
max-clk-limit = <0xc65d400>;
bus-width = <0x4>;
cap-mmc-highspeed;
cap-sd-highspeed;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
cd-inverted;
nvidia,vqmmc-always-on;
pwrdet-support;
pinctrl-names = "sdmmc_e_33v_enable", "sdmmc_e_33v_disable";
pinctrl-0 = <0x1c>;
pinctrl-1 = <0x1d>;
ignore-pm-notify;
resets = <0x5 0x54>;
pll_source = "pll_p", "pll_c4_muxed";
nvidia,parent_clk_list = "pll_p", "pll_p", "pll_p", "pll_p", "pll_p", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "NULL";
clocks = <0x4 0x7a 0x4 0x66 0x4 0xf1 0x4 0xdb>;
clock-names = "sdmmc", "pll_p", "pll_c4_muxed", "sdmmc_legacy_tm";
uhs-mask = <0x0>;
nvidia,en-periodic-calib;
status = "okay";
nvidia,enable-hwcq;
test-value = "testing123";
linux,phandle = <0xf0>;
phandle = <0xf0>;
prod-settings {
prod_c_1_8v {
prod = <0x0 0x1e0 0x7f00000 0x600000>;
prod_c_3_3v {
prod = <0x0 0x1e0 0x7f00000 0x800000>;
prod {
prod = <0x0 0x4 0xfff 0x200 0x0 0x28 0x22 0x2 0x0 0x100 0x1fff004a 0x5090000 0x0 0x128 0x42000000 0x0 0x0 0x1ac 0x4 0x0 0x0 0x1c0 0x1fc0 0x40 0x0 0x1c4 0x3ff77 0x400 0x0 0x1e0 0x8007f000 0x7000 0x0 0x1e4 0x20000000 0x20000000 0x0 0x204 0x80000000 0x0>;
prod_c_ds {
prod = <0x0 0x100 0x1fff0000 0x5090000>;
prod_c_hs {
prod_c_ddr52 {
prod_c_hs200 {
prod_c_sdr104 {
prod_c_sdr12 {
prod = <0x0 0x3c 0x70000 0x0>;
prod_c_sdr25 {
prod = <0x0 0x3c 0x70000 0x10000>;
prod_c_sdr50 {
prod = <0x0 0x3c 0x70000 0x20000 0x0 0x1c0 0xe000 0x8000>;
