Jetson NX 8G with custom carrier board with 6911(HDMI to MIPI birdge) on board
L4T 32.6.1
Testing has 4 GStreamer based windows show 4 streams each have a gst-pipeline
2 HDMI cameras +2 IPC cameras (with 2 IPC or not doesn’t make any difference)
Create /destroy HDMI cams preview pipeline 200 times, in about 175 times, totally about 1/175 fail rate, screen will freeze and show this picture,half green half picture (some time full green)
Jetpack 4.6 , 32.6.1
Cams input size is 1080P30, ,in this case, is 2 1080P30 HDMI to MIPI , which I don’t think have any bandwidth issue, we have testing 4k cams also working, it is on board we have 3 6911 HDMI to MIPI, each has config as 4 lanes MIPI
pipeline like this :
gst-launch-1.0 v4l2src device=/dev/video0 ! “video/x-raw,width=1920,height=1080,framerate=(fraction)30/1” ! xvimagesink
For this case you may need to confirm the MIPI signal match the MIPI spec like the power sequence …
Also you can try different mode like MIPI continuous/discontinuous mode and adjust the setting time.
I think this is kind of like HW signal level verification HWV need scope to measure it which is kind of very hard to do it right now
I am not aware how to setting it , How to config it ?thanks
we have some new founding
Testing 1:
Environment:
lt6911uxc dts use attachment tegra194-camera-rbpcv2-lt6911_old1.dtsi
using lt6911uxc firmware which is for 1080PEDID FW
testing 1080P30 without any eroror with 3 round each 500 times
Testing 2
Environment
lt6911uxc dts use attachment tegra194-camera-rbpcv2-lt6911_new1.dtsi
using lt6911uxc firmware which is for 1080PEDID fw
with fail rate with below pciture error in kernel message
update lastest testing , we found issue is very random , on test 2 , still have failed rate , it dependence on various factor , for example , cams , machines and even the cable length ,
we already asking 6911 vendor provides the continuous clock FW for next round test
