I am working on a TOF sensor (UART) that can be cascaded. But when I connect two sensors on the /dev/ttyTHS0, I can only access the sensor that is directly connected to the carrier board.
I have checked both codes and sensors, they can all work properly if I use a USB to TTL deceive, like FT232, to connect them to Orin NX.
So could you give me some insights where the problem is? The hardware design of the carrier board or some configurations of the UART?
Thank you very much!
