in the optixHair sample (OptiX 7.4) there is no normal calculaton shown for catmull rom,
so instead of “optixGetCubicBSplineVertexData” I found “optixGetCatmullRomVertexData”, but
how to define CatmullRomSegment interpolator( controlPoints ) ?
Analogously to the Cubic normal computation (normalCubic() in optixHair.cu), you’d initialize the CubicInterpolator using a linear transformation to convert the Catrom control points into those for Cubic interpolation. Add the following to the struct CubicInterpolator in curve.h:
// Compute surface normal of Catmull-Rom pimitive in world space.
static __forceinline__ __device__ float3 normalCatrom( const int primitiveIndex )
const OptixTraversableHandle gas = optixGetGASTraversableHandle();
const unsigned int gasSbtIndex = optixGetSbtGASIndex();
float4 controlPoints[4];
optixGetCatmullRomVertexData( gas, primitiveIndex, gasSbtIndex, 0.0f, controlPoints );
CubicInterpolator interpolator;
interpolator.initializeFromCatrom(controlPoints);
float3 hitPoint = getHitPoint();
// interpolators work in object space
hitPoint = optixTransformPointFromWorldToObjectSpace( hitPoint );
const float3 normal = surfaceNormal( interpolator, optixGetCurveParameter(), hitPoint );
return optixTransformNormalFromObjectToWorldSpace( normal );
in optixHair.cu.
In other words, you’re reusing the existing cubic interpolator and transform the Catmul-Rom control points into the form the interpolator needs using a matrix multiplication the same way it’s done for the cubic b-spline control points.
Ah, right. Good you found David’s post. Those are the right weights for the current SDK. The code I showed is from the upcoming release in which we’re also changing the CubicInterpolator to use plain polynomial evaluation. Sorry for the confusion.
