Cboot "eeprom: Failed to read I2C slave device"
My development environment is as follows.
  • Hardware Platform - Custom Jetson Xavier NX
  • JetPack Version - 4.5
  • L4T - 32.5
NX board was manufactured separately.
EEPROM read failure in cboot.
I know that cboot does not provide source code.
Is there any way to fix the EEPROM failure?
The cboot log looks like this:
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
ÿâ
[0000.377] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba5943)
[0000.377] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.378] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.379] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.384] W> device prod register failed
[0000.388] I> Boot-device: QSPI
[0000.391] I> Boot_device: QSPI_FLASH instance: 0
[0000.396] I> QSPI Flash Size = 32 MB
[0000.402] I> Qspi initialized successfully
[0000.403] I> qspi flash-0 params source = boot args
[0000.785] I> sdmmc DDR50 mode
[0000.787] I> sdmmc-3 params source = safe params
[0000.792] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.794] W> Cannot find any partition table for 00000003
[0000.798] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.799] W> No valid slot number is found in scratch register
[0000.800] W> Return default slot: _a
[0000.800] I> Active Boot chain : 0
[0000.801] I> parsing oem signed section of bpmp-fw header done
[0000.802] I> bpmp-fw binary init read from storage
[0000.806] I> oem authentication of bpmp-fw header done
[0000.820] I> bpmp-fw binary done read from storage
[0000.821] I> bpmp-fw: Authentication init Done
[0000.822] I> parsing oem signed section of cpubl header done
[0000.825] I> cpubl binary init read from storage
[0000.830] I> bpmp-fw: Authentication Finalize Done
[0000.835] I> oem authentication of cpubl header done
[0000.842] I> cpubl binary done read from storage
[0000.844] I> cpubl: Authentication init Done
[0000.848] I> parsing oem signed section of rce header done
[0000.853] I> rce binary init read from storage
[0000.858] I> Relocating BR-BCT
[0000.861] I> cpubl: Authentication Finalize Done
[0000.865] I> oem authentication of rce header done
[0000.870] I> rce binary done read from storage
[0000.874] I> rce: Authentication init Done
[0000.878] I> parsing oem signed section of ape header done
[0000.883] I> ape binary init read from storage
[0000.887] I> rce: Authentication Finalize Done
[0000.892] I> oem authentication of ape header done
[0000.896] I> ape binary done read from storage
[0000.901] I> ape: Authentication init Done
[0000.905] I> parsing oem signed section of tos header done
[0000.910] I> tos binary init read from storage
[0000.914] I> ape: Authentication Finalize Done
[0000.919] I> oem authentication of tos header done
[0000.925] I> tos binary done read from storage
[0000.927] I> tos: Authentication init Done
[0000.932] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.937] I> bpmp-fw-dtb binary init read from storage
[0000.942] I> tos: Authentication Finalize Done
[0000.948] I> oem authentication of bpmp-fw-dtb header done
[0000.952] I> bpmp-fw-dtb binary done read from storage
[0000.957] I> bpmp-fw-dtb: Authentication init Done
[0000.962] I> parsing oem signed section of cpubl-dtb header done
[0000.968] I> cpubl-dtb binary init read from storage
[0000.972] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.029] I> oem authentication of cpubl-dtb header done
[0001.030] I> cpubl-dtb binary done read from storage
[0001.031] I> cpubl-dtb: Authentication init Done
[0001.032] I> parsing oem signed section of eks header done
[0001.032] I> eks binary init read from storage
[0001.033] I> cpubl-dtb: Authentication Finalize Done
[0001.034] I> oem authentication of eks header done
[0001.038] I> eks binary done read from storage
[0001.042] I> eks: Authentication init Done
[0001.046] I> eks: Authentication Finalize Done
[0001.050] I> EKB detected (length: 0x410) @ VA:0x52714400
ÿäNOTICE:  BL31: v1.3(release):5b49e7f80
NOTICE:  BL31: Built : 14:42:47, Jan 15 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
ÿâ
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
ÿá
[0001.391] I> Welcome to Cbootÿâmrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
ÿá
[0001.392] I> Cboot Version: t194-9efcbc4f
[0001.393] I> CPU-BL Params @ 0xf2820000
[0001.397] I>  0) Base:0x00000000 Size:0x00000000
[0001.401] I>  1) Base:0xf1100000 Size:0x00100000
ÿâclk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ÿá[0001.406] I>  2) Base:0xf2000000 Size:0x00200000
[0001.560] I>  3) Base:0xf1200000 Size:0x00200000
[0001.564] I>  4) Base:0xf1000000 Size:0x00100000
[0001.569] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.573] I>  6) Base:0xf3800000 Size:0x00400000
[0001.578] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.582] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.587] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.591] I> 10) Base:0xf3000000 Size:0x00800000
[0001.596] I> 11) Base:0x40000000 Size:0x00040000
[0001.600] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.605] I> 13) Base:0x40046000 Size:0x00002000
[0001.609] I> 14) Base:0x40048000 Size:0x00002000
[0001.614] I> 15) Base:0xac000000 Size:0x00004000
[0001.618] I> 16) Base:0x4004a000 Size:0x00002000
[0001.622] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.627] I> 18) Base:0x4004c000 Size:0x00002000
[0001.631] I> 19) Base:0xf2200000 Size:0x00600000
[0001.636] I> 20) Base:0x4004e000 Size:0x00002000
[0001.640] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.645] I> 22) Base:0x00000000 Size:0x00000000
[0001.649] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.654] I> 24) Base:0xf6000000 Size:0x02000000
[0001.658] I> 25) Base:0x40050000 Size:0x00002000
[0001.663] I> 26) Base:0x40040000 Size:0x00006000
[0001.667] I> 27) Base:0xf1800000 Size:0x00400000
[0001.672] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.676] I> 29) Base:0xf1400000 Size:0x00400000
[0001.680] I> 30) Base:0x00000000 Size:0x00000000
[0001.685] I> 31) Base:0x00000000 Size:0x00000000
[0001.689] I> 32) Base:0xf8000000 Size:0x08000000
[0001.694] I> 33) Base:0x00000000 Size:0x00000000
[0001.698] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.703] I> 35) Base:0xab000000 Size:0x01000000
[0001.707] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.712] I> 37) Base:0xf2800000 Size:0x00800000
[0001.716] I> 38) Base:0x80000000 Size:0x20000000
[0001.721] I> 39) Base:0xb0000000 Size:0x08000000
[0001.725] I> 40) Base:0x00000000 Size:0x00000000
[0001.730] I> 41) Base:0x00000000 Size:0x00000000
[0001.734] I> 42) Base:0x00000000 Size:0x00000000
[0001.739] I> 43) Base:0x00000000 Size:0x00000000
[0001.743] I> 44) Base:0x00000000 Size:0x00000000
[0001.747] I> 45) Base:0x00000000 Size:0x00000000
[0001.752] GIC-SPI Target CPU: 0
[0001.755] Interrupts Init done
[0001.758] calling constructors
[0001.761] initializing heap
[0001.763] I> Heap: [0xa06945e8 ... 0xab000000]
[0001.768] initializing threads
[0001.770] initializing timers
[0001.773] creating bootstrap completion thread
[0001.778] top of bootstrap2()
[0001.780] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.785] initializing platform
[0001.788] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.793] W> device prod register failed
[0001.797] I> Bl_dtb @0xaaf00000
[0001.802] W> "plugin-manager" doesn't exist, creating
[0001.805] W> "ids" doesn't exist, creating
[0001.809] W> "connection" doesn't exist, creating
[0001.814] W> "configs" doesn't exist, creating
[0001.822] I> Find /i2c@3160000's alias i2c0
[0001.822] I> Reading eeprom i2c=0 address=0x50
[0001.851] I> Device at /i2c@3160000:0x50
[0001.852] I> Reading eeprom i2c=0 address=0x57
[0001.852] E> I2C: slave not found in slaves.
[0001.853] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.854] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.854] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.861] E> eeprom: Failed to read I2C slave device
[0001.866] I> Eeprom read failed 0x3526070d
[0001.871] I> Find /i2c@c240000's alias i2c1
[0001.874] I> Reading eeprom i2c=1 address=0x50
[0001.880] E> I2C: slave not found in slaves.
[0001.883] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.891] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.896] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.906] E> eeprom: Retry to read I2C slave device.
[0001.911] E> I2C: slave not found in slaves.
[0001.914] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.922] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.928] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.937] E> eeprom: Failed to read I2C slave device
[0001.942] I> Eeprom read failed 0x3526070d
[0001.946] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0001.951] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.962] I> Adding plugin-manager/ids/3668-0001-300=/i2c@3160000:module@0x50
[0001.970] W> "i2c@3160000" doesn't exist, creating
[0001.974] W> "module@0x50" doesn't exist, creating
[0001.980] I> Adding plugin-manager/cvm
[0001.983] W> "chip-id" doesn't exist, creating
[0001.987] I> Adding plugin-manager/chip-id/A02P
[0001.991] I> Plugin-manager override starting
[0001.996] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.006] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.011] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.018] I> Disable plugin-manager status in FDT
[0002.018] I> Plugin-manager override finished successfully
[0002.023] I> gpio framework initialized
[0002.028] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.035] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.042] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.049] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.056] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.063] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.069] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.077] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.084] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.091] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.098] I> fixed regulator driver initialized
[0002.106] I> register 'maxim' power off handle
[0002.107] I> virtual i2c enabled
[0002.109] I> registered 'maxim,max20024' pmic
[0002.113] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.120] I> Boot-device: QSPI
[0002.123] I> Boot_device: QSPI_FLASH instance: 0
[0002.128] I> QSPI source rate = 204000 Khz
[0002.131] I> Requested rate for QSPI clock = 34000 Khz
[0002.136] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.141] I> QSPI Flash Size = 32 MB
[0002.149] I> Qspi initialized successfully
[0002.149] I> qspi flash-0 params source = boot args
[0002.153] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0002.158] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.173] I> sdmmc-3 params source = safe params
[0002.175] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.195] W> Cannot find any partition table for 00000003
[0002.208] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.217] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.222] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.222] I> hdmi cable connected
[0002.224] W> set volts not configured for 'vdd-1v0'
[0002.226] W> set volts not configured for 'vdd-1v8-hs'
[0002.230] E> invalid display type
[0002.231] E> cannot find any other nvdisp nodes
[0002.234] E> I2C: slave not found in slaves.
[0002.234] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.235] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.240] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instance 3.
[0002.249] E> could not read edid
[0002.256] I> hdmi_enable, starting HDMI initialisation
[0002.261] I> hdmi_enable, HDMI initialisation complete
[0002.270] I> Load in CBoot Boot Options partition and parse it
[0002.271] E> Error -9 when finding node with path /boot-configuration
[0002.274] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.281] I> Using default boot order
[0002.285] I> boot-dev-order :-
[0002.288] I> 1.sd
[0002.290] I> 2.usb
[0002.291] I> 3.nvme
[0002.293] I> 4.emmc
[0002.295] I> 5.net
[0002.297] I> Hit any key to stop autoboot:	4	3	2
TEGRA194 #
hello young,
please access https://developer.nvidia.com/embedded/linux-tegra page to access CBoot sources.
thanks
Thank you for answer.
