I am not sure if cboot will read and use device tree from bootloader-dtb partition. I checked the cboot source code, did not find code to read that partition. Does anyone know if cboot use DT data in bootloader-dtb partition?
Yes, cboot uses the DT in the bootloader-dtb partition.
You can just get a arbitrary driver which would read DT properties to test.
But I can’t find the code in cboot to read DT from bootloader-dtb partition.
I can find the code to read CBO and kernel dtb partition in cboot.
Have you found it to move your issue forward? Any result can be shared? Thanks
I did find find cboot code read bootloader-dtb partition, but it seems it uses other way to read the dtb data.
