Hi Everyone
All CC3 and CC4 characters’ leg inside has strips on the omniverse screen. I tried to fix this deformation on the stitch line but I couldn’t. If you have any solution to fix this issue, please share it with me. Thank you very much.
These might help you:
first do the “Reset Texture for SSS Map” trick shown here:
Strange horizontal lines around eye browses - #25 by pekka.varis by Joanne.
Then backin Omniverse ( create or machinima )
set
sub surface scale 0.25
sub surface advanced
all to 1.0
The above parameters can be seen ( with wrong values ) at bottom right in this image:
For body and head skin materials.
If these do not solve, try this:
Pekka Varis
Hi Pekka
Thank you very much for your detailed reply. I will try it.
Regards
Hi Pekka
I tried all but it doesn’t work. Strips are the same intensity.
oh such a sad thing :(
Hopefully reallusion people can answer this…
wanna try this too heheh?
I’ll try. Thank you very much.
You are a LEGEND mate. You solved the whole issue with one button. Amazing.
You two! :)
