Hi
where can I get a copy of the CE certification for the Nvidia Jetson TX1 and TX2?
Thank you
Hi
Thank you
Hello, please see these downloads available:
Jetson TX1 Regulatory & Compliance Documents
Jetson TX2 Regulatory & Compliance Documents
Hi Dusty,
I would like to know whether Nvidia has performed FCC testing with sub part 15, class C for TX2 SOM. Because the above documents says that TX2/TX1 has been tested for class B standard ( un-intentional Radiator ). I would like to know whether it is tested for class C ( intentional Radiator ). Also I can see that TX2 uses Broadcom BCM4354 chip, can you please provide the FCC certification/ document for this chip.
Thank you
Hi, you can get detail info from FCC site below:
