CE Compliance documentation
I previously asked about compliance documentation associated with the NVIDIA Jetson Xavier, however looking through the documentation sent and now on the main website (thank you), we were sent the compliance documentation for just the P2888 module instead of the whole development kit which seems to be module name P2972. Could we get a copy of the CE compliance certification for that module?
Many Thanks,
James
Yes, you should be able to find the Jetson AGX Xavier Series Regulatory and Compliance Documents from Jetson Download Center | NVIDIA Developer
Hi kayccc, you’re right, however the certificate in the download centre is specifically for the P2888 module. This relates to the compute module itself. We require a certificate for the P2972 module, which encompasses the whole development kit. Any help on this would be great.
Many Thanks.
All we have are provided in there.
Why using P2972 module for production?
Supposed customer should order and use P2888 module.
We’re not in production, this is a one off application which requires documentation. The user guide for this developer kit also mentions that a declaration of conformity may be obtained directly from NVIDIA GmbH (Floessergasse 2, 81369 Munich, Germany) and bears the CE mark for ECD 2014/30/EU, LVD 2014/35/EU and RoHS 2011/65/EU.
Interestingly, I checked the UL certificate number and it does have the P2972 module attached to it.
This declaration documentation should be available, so any help would be great.
The P2972 developer kit contains a P2888 module. It sounds like you already found the regulatory and compliance documents for P2888, as well as the Compliance Information section including CE mark within the Jetson AGX Xavier Developer Kit User Guide.
If you want a copy of the CE declaration of conformity, the devkit user guide states:
A copy of the Declaration of Conformity to the essential requirements may be obtained directly from NVIDIA GmbH (Floessergasse 2, 81369 Munich, Germany).
