In Isaac ROS, there is a horizontal shift in the CenterPose inference coordinates.
When checking the inference results in TAO, no such shift occurs.
isaac ros
I confirm that the model trained is for 512x512 images, which is why changing the image size to the center no longer works.
Evaluation Data
The performance of the CenterPose model during inference was evaluated using the test samples from each category in the official dataset release. These frames, originally high-resolution images of 600x800 pixels, were resized to 512x512 pixels before being processed by the CenterPose model.
