I am having difficulty troubleshooting why a tesla k80 card is falling off the PCI bus and causing all 16 cards in the system to be inacessible. It’s hard to tell which card is problematic.
I don’t see an attach func to include the bug report so copying it in-line.
Thanks for any insight.
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 22924279
Date: Wed Oct 10 07:20:27 PDT 2018
uname: Linux leia 3.10.0-862.3.2.el7.x86_64 #1 SMP Mon May 21 23:36:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r–. 1 root root 23 2018-05-17 06:53:03.000000000 -0700 /etc/issue
\S
Kernel \r on an \m
*** /etc/redhat-release
*** ls: lrwxrwxrwx. 1 root root 14 2018-05-23 11:37:20.492863667 -0700 /etc/redhat-release → centos-release
CentOS Linux release 7.5.1804 (Core)
*** /var/log/nvidia-installer.log does not exist
*** /var/lib/dkms/nvidia/384.125/3.10.0-862.3.2.el7.x86_64/x86_64/log/make.log
*** ls: -rw-r–r–. 1 root root 16884 2018-05-23 13:56:00.106297967 -0700 /var/lib/dkms/nvidia/384.125/3.10.0-862.3.2.el7.x86_64/x86_64/log/make.log
DKMS make.log for nvidia-384.125 for kernel 3.10.0-862.3.2.el7.x86_64 (x86_64)
Wed May 23 13:55:32 PDT 2018
make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-862.3.2.el7.x86_64/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-862.3.2.el7.x86_64/source M=/var/lib/dkms/nvidia/384.125/build ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-862.3.2.el7.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-862.3.2.el7.x86_64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory /usr/src/kernels/3.10.0-862.3.2.el7.x86_64' make -C /lib/modules/3.10.0-862.3.2.el7.x86_64/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-862.3.2.el7.x86_64 \ KBUILD_EXTMOD="/var/lib/dkms/nvidia/384.125/build" -f /usr/src/kernels/3.10.0-862.3.2.el7.x86_64/Makefile \ modules SYMLINK /var/lib/dkms/nvidia/384.125/build/nvidia/nv-kernel.o SYMLINK /var/lib/dkms/nvidia/384.125/build/nvidia-modeset/nv-modeset-kernel.o CONFTEST: INIT_WORK CONFTEST: remap_pfn_range CONFTEST: hash__remap_4k_pfn CONFTEST: follow_pfn CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: console_lock CONFTEST: kmem_cache_create CONFTEST: on_each_cpu CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_get_property CONFTEST: of_find_node_by_phandle CONFTEST: of_node_to_nid CONFTEST: pnv_pci_get_npu_dev CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: pci_remove_bus_device CONFTEST: pci_stop_and_remove_bus_device CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: timer_setup CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: get_user_pages CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: drm_driver_has_gem_prime_res_obj CONFTEST: is_export_symbol_gpl_of_node_to_nid CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: vm_fault_has_address CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: mm_context_t CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: pnv_npu2_init_context CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_driver_has_set_busid CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_function_args CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct CONFTEST: drm_master_drop_has_from_release_arg CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: drm_crtc_helper_funcs_has_atomic_enable CONFTEST: drm_old_atomic_state_iterators_present CONFTEST: drm_mode_object_find_has_file_priv_arg CONFTEST: dom0_kernel_present CONFTEST: nvidia_vgpu_kvm_build CONFTEST: nvidia_grid_build CONFTEST: drm_available CONFTEST: drm_atomic_available CONFTEST: drm_atomic_modeset_nonblocking_commit_available CONFTEST: is_export_symbol_gpl_refcount_inc CONFTEST: is_export_symbol_gpl_refcount_dec_and_test CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-frontend.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-instance.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-gpu-numa.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-acpi.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-chrdev.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-cray.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-dma.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-gvi.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-i2c.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-mempool.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-mmap.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-p2p.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-pat.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-procfs.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-usermap.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-vm.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-vtophys.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/os-interface.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/os-mlock.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/os-pci.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/os-registry.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/os-usermap.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-modeset-interface.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-pci-table.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-kthread-q.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-kthread-q-selftest.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-memdbg.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv-report-err.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nv_uvm_interface.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia/nvlink_linux.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_volta_host.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_volta.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_volta_fault_buffer.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_volta_access_counter_buffer.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_gpu_non_replayable_faults.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_gpu_access_counters.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm_utils.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm_common.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm_linux.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/nvstatus.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_tools.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_global.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_gpu.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_gpu_isr.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_procfs.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_va_space.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_mem.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_rm_mem.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_channel.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_lock.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_hal.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_range_tree.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_range_allocator.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_va_range.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_va_block.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_range_group.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_gpu_replayable_faults.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_events.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_module.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_mmu.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pte_batch.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_tlb_batch.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_push.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pushbuffer.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_thread_context.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_tracker.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_kepler.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_kepler_ce.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_kepler_host.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_maxwell.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_maxwell_host.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pascal.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pascal_ce.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pascal_host.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_policy.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_utils.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_kvmalloc.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_migrate.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_map_external.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_user_channel.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_hmm.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_test_rng.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_range_tree_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_mem_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_page_tree_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_tracker_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_push_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_channel_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_ce_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_lock_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_pmm_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_events_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_perf_module_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_mmu_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_va_block_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-modeset/nvidia-modeset-linux.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-drv.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-utils.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-crtc.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-encoder.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-connector.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-gem.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-fb.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-modeset.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-prime-fence.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-linux.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nvidia-drm-helper.o CC [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm/nv-pci-table.o ld -r -o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-interface.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-frontend.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-instance.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-gpu-numa.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-acpi.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-chrdev.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-cray.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-dma.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-gvi.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-i2c.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-mempool.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-mmap.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-p2p.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-pat.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-procfs.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-usermap.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-vm.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-vtophys.o /var/lib/dkms/nvidia/384.125/build/nvidia/os-interface.o /var/lib/dkms/nvidia/384.125/build/nvidia/os-mlock.o /var/lib/dkms/nvidia/384.125/build/nvidia/os-pci.o /var/lib/dkms/nvidia/384.125/build/nvidia/os-registry.o /var/lib/dkms/nvidia/384.125/build/nvidia/os-usermap.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-modeset-interface.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-pci-table.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-kthread-q.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-kthread-q-selftest.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-memdbg.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv-report-err.o /var/lib/dkms/nvidia/384.125/build/nvidia/nv_uvm_interface.o /var/lib/dkms/nvidia/384.125/build/nvidia/nvlink_linux.o ld -r -o /var/lib/dkms/nvidia/384.125/build/nvidia-modeset/nv-modeset-interface.o /var/lib/dkms/nvidia/384.125/build/nvidia-modeset/nvidia-modeset-linux.o LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia.o LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia-modeset.o LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm.o LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm.o Building modules, stage 2. MODPOST 4 modules CC /var/lib/dkms/nvidia/384.125/build/nvidia-drm.mod.o CC /var/lib/dkms/nvidia/384.125/build/nvidia-modeset.mod.o CC /var/lib/dkms/nvidia/384.125/build/nvidia-uvm.mod.o CC /var/lib/dkms/nvidia/384.125/build/nvidia.mod.o LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia-drm.ko LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia-modeset.ko LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia-uvm.ko LD [M] /var/lib/dkms/nvidia/384.125/build/nvidia.ko make[1]: Leaving directory
/usr/src/kernels/3.10.0-862.3.2.el7.x86_64’
journalctl -b -0 _COMM=Xorg
– No entries –
journalctl -b -1 _COMM=Xorg
journalctl -b -2 _COMM=Xorg
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
journalctl -b -2 _COMM=Xorg.bin
– No entries –
*** /var/log/Xorg.0.log
*** ls: -rw-r–r–. 1 root root 52381 2018-05-23 13:35:48.776213467 -0700 /var/log/Xorg.0.log
[ 92.963]
X.Org X Server 1.19.3
Release Date: 2017-03-15
[ 92.963] X Protocol Version 11, Revision 0
[ 92.963] Build Operating System: 3.10.0-514.16.1.el7.x86_64
[ 92.963] Current Operating System: Linux leia 3.10.0-693.el7.x86_64 #1 SMP Tue Aug 22 21:09:27 UTC 2017 x86_64
[ 92.964] Kernel command line: BOOT_IMAGE=/vmlinuz-3.10.0-693.el7.x86_64 root=/dev/mapper/centos-root ro crashkernel=auto rd.lvm.lv=centos/root rd.lvm.lv=centos/swap rhgb quiet LANG=en_US.UTF-8
[ 92.964] Build Date: 05 August 2017 06:19:43AM
[ 92.964] Build ID: xorg-x11-server 1.19.3-11.el7
[ 92.964] Current version of pixman: 0.34.0
[ 92.964] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 92.964] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 92.964] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed May 23 11:32:18 2018
[ 92.965] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 92.965] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 92.966] (==) No Layout section. Using the first Screen section.
[ 92.966] (==) No screen section available. Using defaults.
[ 92.966] () |–>Screen “Default Screen Section” (0)
[ 92.966] (**) | |–>Monitor “”
[ 92.966] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 92.966] (==) Automatically adding devices
[ 92.966] (==) Automatically enabling devices
[ 92.966] (==) Automatically adding GPU devices
[ 92.966] (==) Automatically binding GPU devices
[ 92.966] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 92.966] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 92.966] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 92.966] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 92.966] (II) Loader magic: 0x55801a261020
[ 92.966] (II) Module ABI versions:
[ 92.966] X.Org ANSI C Emulation: 0.4
[ 92.966] X.Org Video Driver: 23.0
[ 92.966] X.Org XInput driver : 24.1
[ 92.966] X.Org Server Extension : 10.0
[ 92.968] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 92.987] (–) PCI: (0:6:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xc1000000/16777216, 0xc3800000000/17179869184, 0xc3c00000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:7:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xc0000000/16777216, 0xc3000000000/17179869184, 0xc3400000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:10:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xc4000000/16777216, 0xc2800000000/17179869184, 0xc2c00000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:11:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xc3000000/16777216, 0xc2000000000/17179869184, 0xc2400000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:16:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xbe000000/16777216, 0xc1800000000/17179869184, 0xc1c00000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:17:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xbd000000/16777216, 0xc1000000000/17179869184, 0xc1400000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:20:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xbb000000/16777216, 0xc0800000000/17179869184, 0xc0c00000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:21:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xba000000/16777216, 0xc0000000000/17179869184, 0xc0400000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI:*(0:24:0:0) 1a03:2000:1a03:2000 rev 48, Mem @ 0xc6000000/16777216, 0xc7000000/131072, I/O @ 0x00006000/128, BIOS @ 0x???/131072
[ 92.987] (–) PCI: (0:133:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xfa000000/16777216, 0xc7800000000/17179869184, 0xc7c00000000/33554432, BIOS @ 0x???/65536
[ 92.987] (–) PCI: (0:134:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xf9000000/16777216, 0xc7000000000/17179869184, 0xc7400000000/33554432, BIOS @ 0x???/65536
[ 92.988] (–) PCI: (0:137:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xf7000000/16777216, 0xc6800000000/17179869184, 0xc6c00000000/33554432, BIOS @ 0x???/65536
[ 92.988] (–) PCI: (0:138:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xf6000000/16777216, 0xc6000000000/17179869184, 0xc6400000000/33554432, BIOS @ 0x???/65536
[ 92.988] (–) PCI: (0:143:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xf4000000/16777216, 0xc5800000000/17179869184, 0xc5c00000000/33554432, BIOS @ 0x???/65536
[ 92.988] (–) PCI: (0:144:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xf3000000/16777216, 0xc5000000000/17179869184, 0xc5400000000/33554432, BIOS @ 0x???/65536
[ 92.988] (–) PCI: (0:147:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xf1000000/16777216, 0xc4800000000/17179869184, 0xc4c00000000/33554432, BIOS @ 0x???/65536
[ 92.988] (–) PCI: (0:148:0:0) 10de:102d:10de:106c rev 161, Mem @ 0xf0000000/16777216, 0xc4000000000/17179869184, 0xc4400000000/33554432, BIOS @ 0x???/65536
[ 92.988] (II) LoadModule: “glx”
[ 92.988] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 92.990] (II) Module glx: vendor=“X.Org Foundation”
[ 92.990] compiled for 1.19.3, module version = 1.0.0
[ 92.990] ABI class: X.Org Server Extension, version 10.0
[ 92.990] (==) Matched modesetting as autoconfigured driver 0
[ 92.990] (==) Matched fbdev as autoconfigured driver 1
[ 92.990] (==) Matched vesa as autoconfigured driver 2
[ 92.990] (==) Assigned the driver to the xf86ConfigLayout
[ 92.990] (II) LoadModule: “modesetting”
[ 92.990] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 92.990] (II) Module modesetting: vendor=“X.Org Foundation”
[ 92.990] compiled for 1.19.3, module version = 1.19.3
[ 92.990] Module class: X.Org Video Driver
[ 92.990] ABI class: X.Org Video Driver, version 23.0
[ 92.990] (II) LoadModule: “fbdev”
[ 92.991] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 92.991] (II) Module fbdev: vendor=“X.Org Foundation”
[ 92.991] compiled for 1.19.3, module version = 0.4.3
[ 92.991] Module class: X.Org Video Driver
[ 92.991] ABI class: X.Org Video Driver, version 23.0
[ 92.991] (II) LoadModule: “vesa”
[ 92.991] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 92.991] (II) Module vesa: vendor=“X.Org Foundation”
[ 92.991] compiled for 1.19.3, module version = 2.3.2
[ 92.991] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 92.991] (II) FBDEV: driver for framebuffer: fbdev
[ 92.991] (II) VESA: driver for VESA chipsets: vesa
[ 92.991] (++) using VT number 1
[ 92.993] (II) modeset(0): using drv /dev/dri/card0
[ 92.993] (WW) Falling back to old probe method for fbdev
[ 92.993] (II) Loading sub module “fbdevhw”
[ 92.993] (II) LoadModule: “fbdevhw”
[ 92.993] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 92.993] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 92.993] compiled for 1.19.3, module version = 0.0.2
[ 92.993] ABI class: X.Org Video Driver, version 23.0
[ 92.993] (WW) Falling back to old probe method for vesa
[ 92.993] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 92.993] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 92.993] (==) modeset(0): RGB weight 888
[ 92.993] (==) modeset(0): Default visual is TrueColor
[ 92.993] (II) Loading sub module “glamoregl”
[ 92.993] (II) LoadModule: “glamoregl”
[ 92.993] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 92.999] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 92.999] compiled for 1.19.3, module version = 1.0.0
[ 92.999] ABI class: X.Org ANSI C Emulation, version 0.4
[ 92.999] (II) glamor: OpenGL accelerated X.org driver based.
[ 93.011] (II) glamor: EGL version 1.4 (DRI2):
[ 93.011] EGL_MESA_drm_image required.
[ 93.012] (EE) modeset(0): glamor initialization failed
[ 93.012] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[ 93.012] (II) modeset(0): Double-buffered shadow updates: on
[ 93.015] (II) modeset(0): Output VGA-1 has no monitor section
[ 93.018] (II) modeset(0): EDID for output VGA-1
[ 93.018] (II) modeset(0): Printing probed modes for output VGA-1
[ 93.018] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 93.018] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 93.018] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 93.018] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 93.018] (II) modeset(0): Output VGA-1 connected
[ 93.018] (II) modeset(0): Using exact sizes for initial modes
[ 93.018] (II) modeset(0): Output VGA-1 using initial mode 1024x768 +0+0
[ 93.018] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 93.018] (==) modeset(0): DPI set to (96, 96)
[ 93.018] (II) Loading sub module “fb”
[ 93.018] (II) LoadModule: “fb”
[ 93.018] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 93.019] (II) Module fb: vendor=“X.Org Foundation”
[ 93.019] compiled for 1.19.3, module version = 1.0.0
[ 93.019] ABI class: X.Org ANSI C Emulation, version 0.4
[ 93.019] (II) Loading sub module “shadow”
[ 93.019] (II) LoadModule: “shadow”
[ 93.019] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[ 93.019] (II) Module shadow: vendor=“X.Org Foundation”
[ 93.019] compiled for 1.19.3, module version = 1.1.0
[ 93.019] (II) UnloadModule: “fbdev”
[ 93.019] (II) Unloading fbdev
[ 93.019] (II) UnloadSubModule: “fbdevhw”
[ 93.019] (II) Unloading fbdevhw
[ 93.019] (II) UnloadModule: “vesa”
[ 93.019] (II) Unloading vesa
[ 93.019] (==) Depth 24 pixmap format is 32 bpp
[ 93.020] (==) modeset(0): Backing store enabled
[ 93.020] (==) modeset(0): Silken mouse enabled
[ 93.020] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 93.020] (==) modeset(0): DPMS enabled
[ 93.020] (–) RandR disabled
[ 93.026] (II) SELinux: Disabled by boolean
[ 93.027] (II) AIGLX: Screen 0 is not DRI2 capable
[ 93.027] (EE) AIGLX: reverting to software rendering
[ 93.032] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[ 93.032] (II) IGLX: Loaded and initialized swrast
[ 93.032] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 93.033] (II) modeset(0): Damage tracking initialized
[ 93.033] (II) modeset(0): Setting screen physical size to 270 x 203
[ 93.073] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 93.073] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 93.073] () Power Button: Applying InputClass “system-keyboard”
[ 93.073] (II) LoadModule: “evdev”
[ 93.074] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 93.074] (II) Module evdev: vendor=“X.Org Foundation”
[ 93.074] compiled for 1.19.3, module version = 2.10.5
[ 93.074] Module class: X.Org XInput Driver
[ 93.074] ABI class: X.Org XInput driver, version 24.1
[ 93.074] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 93.074] () Power Button: always reports core events
[ 93.074] () evdev: Power Button: Device: “/dev/input/event1”
[ 93.075] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 93.075] (–) evdev: Power Button: Found keys
[ 93.075] (II) evdev: Power Button: Configuring as keyboard
[ 93.075] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 93.075] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 93.075] () Option “xkb_rules” “evdev”
[ 93.075] () Option “xkb_layout” “us”
[ 93.075] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 93.076] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 93.076] () Power Button: Applying InputClass “system-keyboard”
[ 93.076] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 93.076] () Power Button: always reports core events
[ 93.076] () evdev: Power Button: Device: “/dev/input/event0”
[ 93.076] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 93.076] (–) evdev: Power Button: Found keys
[ 93.076] (II) evdev: Power Button: Configuring as keyboard
[ 93.076] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0”
[ 93.076] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 93.076] () Option “xkb_rules” “evdev”
[ 93.076] () Option “xkb_layout” “us”
[ 93.077] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/event2)
[ 93.077] () Lenovo Optical USB Mouse: Applying InputClass “evdev pointer catchall”
[ 93.077] (II) Using input driver ‘evdev’ for ‘Lenovo Optical USB Mouse’
[ 93.077] () Lenovo Optical USB Mouse: always reports core events
[ 93.077] () evdev: Lenovo Optical USB Mouse: Device: “/dev/input/event2”
[ 93.128] (–) evdev: Lenovo Optical USB Mouse: Vendor 0x17ef Product 0x6019
[ 93.128] (–) evdev: Lenovo Optical USB Mouse: Found 3 mouse buttons
[ 93.128] (–) evdev: Lenovo Optical USB Mouse: Found scroll wheel(s)
[ 93.128] (–) evdev: Lenovo Optical USB Mouse: Found relative axes
[ 93.128] (–) evdev: Lenovo Optical USB Mouse: Found x and y relative axes
[ 93.128] (II) evdev: Lenovo Optical USB Mouse: Configuring as mouse
[ 93.128] (II) evdev: Lenovo Optical USB Mouse: Adding scrollwheel support
[ 93.128] () evdev: Lenovo Optical USB Mouse: YAxisMapping: buttons 4 and 5
[ 93.128] () evdev: Lenovo Optical USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 93.128] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1:1.0/input/input2/event2”
[ 93.128] (II) XINPUT: Adding extended input device “Lenovo Optical USB Mouse” (type: MOUSE, id 8)
[ 93.128] (II) evdev: Lenovo Optical USB Mouse: initialized for relative axes.
[ 93.128] () Lenovo Optical USB Mouse: (accel) keeping acceleration scheme 1
[ 93.128] () Lenovo Optical USB Mouse: (accel) acceleration profile 0
[ 93.128] () Lenovo Optical USB Mouse: (accel) acceleration factor: 2.000
[ 93.128] () Lenovo Optical USB Mouse: (accel) acceleration threshold: 4
[ 93.129] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/mouse0)
[ 93.129] (II) No input driver specified, ignoring this device.
[ 93.129] (II) This device may have been added with another device file.
[ 93.129] (II) config/udev: Adding input device LITE-ON Technology USB NetVista Full Width Keyboard. (/dev/input/event3)
[ 93.130] () LITE-ON Technology USB NetVista Full Width Keyboard.: Applying InputClass “evdev keyboard catchall”
[ 93.130] () LITE-ON Technology USB NetVista Full Width Keyboard.: Applying InputClass “system-keyboard”
[ 93.130] (II) Using input driver ‘evdev’ for ‘LITE-ON Technology USB NetVista Full Width Keyboard.’
[ 93.130] () LITE-ON Technology USB NetVista Full Width Keyboard.: always reports core events
[ 93.130] () evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Device: “/dev/input/event3”
[ 93.130] (–) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Vendor 0x4b3 Product 0x3025
[ 93.130] (–) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Found keys
[ 93.130] (II) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Configuring as keyboard
[ 93.130] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.2/3-4.2:1.0/input/input3/event3”
[ 93.130] (II) XINPUT: Adding extended input device “LITE-ON Technology USB NetVista Full Width Keyboard.” (type: KEYBOARD, id 9)
[ 93.130] () Option “xkb_rules” “evdev”
[ 93.130] () Option “xkb_layout” “us”
[ 93.131] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 93.131] (II) No input driver specified, ignoring this device.
[ 93.131] (II) This device may have been added with another device file.
[ 93.362] AUDIT: Wed May 23 11:32:19 2018: 14237: client 1 connected from local host ( uid=0 gid=0 pid=14276 )
Auth name: MIT-MAGIC-COOKIE-1 ID: 625
[ 93.369] AUDIT: Wed May 23 11:32:19 2018: 14237: client 1 disconnected
[ 93.373] AUDIT: Wed May 23 11:32:19 2018: 14237: client 1 connected from local host ( uid=0 gid=0 pid=14278 )
[ 93.377] AUDIT: Wed May 23 11:32:19 2018: 14237: client 1 disconnected
[ 93.381] AUDIT: Wed May 23 11:32:19 2018: 14237: client 1 connected from local host ( uid=0 gid=0 pid=14230 )
[ 93.724] AUDIT: Wed May 23 11:32:19 2018: 14237: client 2 connected from local host ( uid=42 gid=42 pid=14292 )
[ 93.774] AUDIT: Wed May 23 11:32:19 2018: 14237: client 3 connected from local host ( uid=42 gid=42 pid=14295 )
[ 93.830] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 connected from local host ( uid=42 gid=42 pid=14295 )
[ 93.830] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 disconnected
[ 93.836] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 connected from local host ( uid=42 gid=42 pid=14313 )
[ 93.836] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 disconnected
[ 93.846] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 connected from local host ( uid=42 gid=42 pid=14313 )
[ 93.846] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 disconnected
[ 93.853] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 connected from local host ( uid=42 gid=42 pid=14321 )
[ 93.853] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 disconnected
[ 93.854] AUDIT: Wed May 23 11:32:19 2018: 14237: client 4 connected from local host ( uid=42 gid=42 pid=14321 )
[ 93.856] AUDIT: Wed May 23 11:32:19 2018: 14237: client 5 connected from local host ( uid=42 gid=42 pid=14322 )
[ 94.077] AUDIT: Wed May 23 11:32:20 2018: 14237: client 5 disconnected
[ 94.082] AUDIT: Wed May 23 11:32:20 2018: 14237: client 3 disconnected
[ 94.661] AUDIT: Wed May 23 11:32:20 2018: 14237: client 3 connected from local host ( uid=42 gid=42 pid=14345 )
[ 94.662] AUDIT: Wed May 23 11:32:20 2018: 14237: client 3 disconnected
[ 94.669] AUDIT: Wed May 23 11:32:20 2018: 14237: client 3 connected from local host ( uid=42 gid=42 pid=14345 )
[ 95.108] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 95.120] AUDIT: Wed May 23 11:32:21 2018: 14237: client 5 connected from local host ( uid=42 gid=42 pid=14345 )
[ 95.132] AUDIT: Wed May 23 11:32:21 2018: 14237: client 6 connected from local host ( uid=42 gid=42 pid=14345 )
[ 95.133] AUDIT: Wed May 23 11:32:21 2018: 14237: client 6 disconnected
[ 95.273] AUDIT: Wed May 23 11:32:21 2018: 14237: client 6 connected from local host ( uid=42 gid=42 pid=14345 )
[ 95.273] AUDIT: Wed May 23 11:32:21 2018: 14237: client 6 disconnected
[ 95.339] AUDIT: Wed May 23 11:32:21 2018: 14237: client 6 connected from local host ( uid=42 gid=42 pid=14389 )
[ 95.339] AUDIT: Wed May 23 11:32:21 2018: 14237: client 6 disconnected
[ 98.279] AUDIT: Wed May 23 11:32:24 2018: 14237: client 6 connected from local host ( uid=42 gid=42 pid=14426 )
[ 98.439] AUDIT: Wed May 23 11:32:24 2018: 14237: client 7 connected from local host ( uid=42 gid=42 pid=14345 )
[ 98.439] AUDIT: Wed May 23 11:32:24 2018: 14237: client 7 disconnected
[ 99.044] AUDIT: Wed May 23 11:32:25 2018: 14237: client 7 connected from local host ( uid=42 gid=42 pid=14448 )
[ 99.052] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 connected from local host ( uid=42 gid=42 pid=14448 )
[ 99.053] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 disconnected
[ 99.265] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 connected from local host ( uid=42 gid=42 pid=14448 )
[ 99.266] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 disconnected
[ 99.661] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 connected from local host ( uid=42 gid=42 pid=14448 )
[ 99.662] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 disconnected
[ 99.678] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 connected from local host ( uid=42 gid=42 pid=14426 )
[ 99.679] AUDIT: Wed May 23 11:32:25 2018: 14237: client 8 disconnected
[ 100.536] AUDIT: Wed May 23 11:32:26 2018: 14237: client 8 connected from local host ( uid=42 gid=42 pid=14448 )
[ 100.537] AUDIT: Wed May 23 11:32:26 2018: 14237: client 8 disconnected
[ 110.467] AUDIT: Wed May 23 11:32:36 2018: 14237: client 4 disconnected
[ 110.469] AUDIT: Wed May 23 11:32:36 2018: 14237: client 4 connected from local host ( uid=42 gid=42 pid=14313 )
[ 110.473] AUDIT: Wed May 23 11:32:36 2018: 14237: client 4 disconnected
[ 110.503] AUDIT: Wed May 23 11:32:36 2018: 14237: client 3 disconnected
[ 110.503] AUDIT: Wed May 23 11:32:36 2018: 14237: client 5 disconnected
[ 110.541] AUDIT: Wed May 23 11:32:36 2018: 14237: client 6 disconnected
[ 110.565] AUDIT: Wed May 23 11:32:36 2018: 14237: client 2 disconnected
[ 110.568] AUDIT: Wed May 23 11:32:36 2018: 14237: client 7 disconnected
[ 110.640] AUDIT: Wed May 23 11:32:36 2018: 14237: client 2 connected from local host ( uid=0 gid=0 pid=14535 )
[ 110.641] AUDIT: Wed May 23 11:32:36 2018: 14237: client 2 disconnected
[ 110.643] AUDIT: Wed May 23 11:32:36 2018: 14237: client 2 connected from local host ( uid=0 gid=0 pid=14536 )
[ 110.643] AUDIT: Wed May 23 11:32:36 2018: 14237: client 2 disconnected
[ 110.682] AUDIT: Wed May 23 11:32:36 2018: 14237: client 2 connected from local host ( uid=0 gid=0 pid=14541 )
[ 111.116] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 connected from local host ( uid=0 gid=0 pid=14702 )
[ 111.117] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 disconnected
[ 111.147] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 connected from local host ( uid=0 gid=0 pid=14704 )
[ 111.147] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 disconnected
[ 111.345] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 connected from local host ( uid=0 gid=0 pid=14720 )
[ 111.354] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 connected from local host ( uid=0 gid=0 pid=14720 )
[ 111.354] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 disconnected
[ 111.359] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 connected from local host ( uid=0 gid=0 pid=14722 )
[ 111.359] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 disconnected
[ 111.374] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 connected from local host ( uid=0 gid=0 pid=14722 )
[ 111.374] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 disconnected
[ 111.378] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 disconnected
[ 111.380] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 connected from local host ( uid=0 gid=0 pid=14730 )
[ 111.380] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 disconnected
[ 111.382] AUDIT: Wed May 23 11:32:37 2018: 14237: client 3 connected from local host ( uid=0 gid=0 pid=14730 )
[ 111.648] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 connected from local host ( uid=0 gid=0 pid=14749 )
[ 111.649] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 disconnected
[ 111.649] AUDIT: Wed May 23 11:32:37 2018: 14237: client 4 connected from local host ( uid=0 gid=0 pid=14749 )
[ 111.714] AUDIT: Wed May 23 11:32:37 2018: 14237: client 5 connected from local host ( uid=0 gid=0 pid=14749 )
[ 111.726] AUDIT: Wed May 23 11:32:37 2018: 14237: client 6 connected from local host ( uid=0 gid=0 pid=14749 )
[ 111.726] AUDIT: Wed May 23 11:32:37 2018: 14237: client 6 disconnected
[ 111.786] AUDIT: Wed May 23 11:32:37 2018: 14237: client 6 connected from local host ( uid=0 gid=0 pid=14749 )
[ 111.787] AUDIT: Wed May 23 11:32:37 2018: 14237: client 6 disconnected
[ 112.320] AUDIT: Wed May 23 11:32:38 2018: 14237: client 6 connected from local host ( uid=0 gid=0 pid=14795 )
[ 112.517] AUDIT: Wed May 23 11:32:38 2018: 14237: client 7 connected from local host ( uid=0 gid=0 pid=14749 )
[ 112.517] AUDIT: Wed May 23 11:32:38 2018: 14237: client 7 disconnected
[ 115.781] AUDIT: Wed May 23 11:32:41 2018: 14237: client 7 connected from local host ( uid=0 gid=0 pid=14899 )
[ 115.781] AUDIT: Wed May 23 11:32:41 2018: 14237: client 7 disconnected
[ 115.813] AUDIT: Wed May 23 11:32:41 2018: 14237: client 7 connected from local host ( uid=0 gid=0 pid=14901 )
[ 115.821] AUDIT: Wed May 23 11:32:41 2018: 14237: client 8 connected from local host ( uid=0 gid=0 pid=14901 )
[ 115.821] AUDIT: Wed May 23 11:32:41 2018: 14237: client 8 disconnected
[ 115.826] AUDIT: Wed May 23 11:32:41 2018: 14237: client 8 connected from local host ( uid=0 gid=0 pid=14904 )
[ 115.827] AUDIT: Wed May 23 11:32:41 2018: 14237: client 8 disconnected
[ 116.051] AUDIT: Wed May 23 11:32:42 2018: 14237: client 8 connected from local host ( uid=0 gid=0 pid=14901 )
[ 116.052] AUDIT: Wed May 23 11:32:42 2018: 14237: client 8 disconnected
[ 116.109] AUDIT: Wed May 23 11:32:42 2018: 14237: client 8 connected from local host ( uid=0 gid=0 pid=14916 )
[ 116.110] AUDIT: Wed May 23 11:32:42 2018: 14237: client 8 disconnected
[ 116.179] AUDIT: Wed May 23 11:32:42 2018: 14237: client 8 connected from local host ( uid=0 gid=0 pid=14910 )
[ 116.186] AUDIT: Wed May 23 11:32:42 2018: 14237: client 9 connected from local host ( uid=0 gid=0 pid=14919 )
[ 116.206] AUDIT: Wed May 23 11:32:42 2018: 14237: client 9 disconnected
[ 116.252] AUDIT: Wed May 23 11:32:42 2018: 14237: client 9 connected from local host ( uid=0 gid=0 pid=14921 )
[ 116.252] AUDIT: Wed May 23 11:32:42 2018: 14237: client 9 disconnected
[ 116.457] AUDIT: Wed May 23 11:32:42 2018: 14237: client 9 connected from local host ( uid=0 gid=0 pid=14901 )
[ 116.458] AUDIT: Wed May 23 11:32:42 2018: 14237: client 9 disconnected
[ 116.816] AUDIT: Wed May 23 11:32:42 2018: 14237: client 9 connected from local host ( uid=0 gid=0 pid=14922 )
[ 116.823] AUDIT: Wed May 23 11:32:42 2018: 14237: client 10 connected from local host ( uid=0 gid=0 pid=14922 )
[ 116.823] AUDIT: Wed May 23 11:32:42 2018: 14237: client 10 disconnected
[ 117.048] AUDIT: Wed May 23 11:32:43 2018: 14237: client 10 connected from local host ( uid=0 gid=0 pid=14953 )
[ 117.055] AUDIT: Wed May 23 11:32:43 2018: 14237: client 11 connected from local host ( uid=0 gid=0 pid=14953 )
[ 117.055] AUDIT: Wed May 23 11:32:43 2018: 14237: client 11 disconnected
[ 117.070] AUDIT: Wed May 23 11:32:43 2018: 14237: client 11 connected from local host ( uid=0 gid=0 pid=14945 )
[ 117.076] AUDIT: Wed May 23 11:32:43 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14945 )
[ 117.076] AUDIT: Wed May 23 11:32:43 2018: 14237: client 12 disconnected
[ 117.121] AUDIT: Wed May 23 11:32:43 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14953 )
[ 117.121] AUDIT: Wed May 23 11:32:43 2018: 14237: client 12 disconnected
[ 117.213] AUDIT: Wed May 23 11:32:43 2018: 14237: client 10 disconnected
[ 117.213] AUDIT: Wed May 23 11:32:43 2018: 14237: client 10 connected from local host ( uid=0 gid=0 pid=14966 )
[ 118.301] AUDIT: Wed May 23 11:32:44 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14964 )
[ 118.309] AUDIT: Wed May 23 11:32:44 2018: 14237: client 13 connected from local host ( uid=0 gid=0 pid=14964 )
[ 118.310] AUDIT: Wed May 23 11:32:44 2018: 14237: client 13 disconnected
[ 118.335] AUDIT: Wed May 23 11:32:44 2018: 14237: client 13 connected from local host ( uid=0 gid=0 pid=15062 )
[ 118.340] AUDIT: Wed May 23 11:32:44 2018: 14237: client 14 connected from local host ( uid=0 gid=0 pid=15062 )
[ 118.341] AUDIT: Wed May 23 11:32:44 2018: 14237: client 14 disconnected
[ 118.935] AUDIT: Wed May 23 11:32:44 2018: 14237: client 14 connected from local host ( uid=0 gid=0 pid=15023 )
[ 119.028] AUDIT: Wed May 23 11:32:45 2018: 14237: client 14 disconnected
[ 120.210] AUDIT: Wed May 23 11:32:46 2018: 14237: client 14 connected from local host ( uid=0 gid=0 pid=14901 )
[ 120.211] AUDIT: Wed May 23 11:32:46 2018: 14237: client 14 disconnected
[ 122.751] AUDIT: Wed May 23 11:32:48 2018: 14237: client 14 connected from local host ( uid=0 gid=0 pid=15108 )
[ 123.033] AUDIT: Wed May 23 11:32:49 2018: 14237: client 14 disconnected
[ 124.458] AUDIT: Wed May 23 11:32:50 2018: 14237: client 14 connected from local host ( uid=0 gid=0 pid=14957 )
[ 124.464] AUDIT: Wed May 23 11:32:50 2018: 14237: client 15 connected from local host ( uid=0 gid=0 pid=14957 )
[ 124.464] AUDIT: Wed May 23 11:32:50 2018: 14237: client 15 disconnected
[ 126.009] AUDIT: Wed May 23 11:32:51 2018: 14237: client 15 connected from local host ( uid=0 gid=0 pid=15211 )
[ 126.021] AUDIT: Wed May 23 11:32:51 2018: 14237: client 16 connected from local host ( uid=0 gid=0 pid=15211 )
[ 126.026] AUDIT: Wed May 23 11:32:52 2018: 14237: client 16 disconnected
[ 126.223] AUDIT: Wed May 23 11:32:52 2018: 14237: client 16 connected from local host ( uid=0 gid=0 pid=15216 )
[ 126.232] AUDIT: Wed May 23 11:32:52 2018: 14237: client 17 connected from local host ( uid=0 gid=0 pid=15216 )
[ 126.232] AUDIT: Wed May 23 11:32:52 2018: 14237: client 17 disconnected
[ 126.753] AUDIT: Wed May 23 11:32:52 2018: 14237: client 15 disconnected
[ 128.421] AUDIT: Wed May 23 11:32:54 2018: 14237: client 13 disconnected
[ 144.450] AUDIT: Wed May 23 11:33:10 2018: 14237: client 12 disconnected
[ 144.538] AUDIT: Wed May 23 11:33:10 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=15301 )
[ 144.546] AUDIT: Wed May 23 11:33:10 2018: 14237: client 13 connected from local host ( uid=0 gid=0 pid=15301 )
[ 144.547] AUDIT: Wed May 23 11:33:10 2018: 14237: client 13 disconnected
[ 144.936] AUDIT: Wed May 23 11:33:10 2018: 14237: client 13 connected from local host ( uid=0 gid=0 pid=15316 )
[ 144.942] AUDIT: Wed May 23 11:33:10 2018: 14237: client 15 connected from local host ( uid=0 gid=0 pid=15316 )
[ 144.942] AUDIT: Wed May 23 11:33:10 2018: 14237: client 15 disconnected
[ 146.620] AUDIT: Wed May 23 11:33:12 2018: 14237: client 15 connected from local host ( uid=0 gid=0 pid=15316 )
[ 146.620] AUDIT: Wed May 23 11:33:12 2018: 14237: client 15 disconnected
[ 147.730] AUDIT: Wed May 23 11:33:13 2018: 14237: client 13 disconnected
[ 152.700] AUDIT: Wed May 23 11:33:18 2018: 14237: client 12 disconnected
[ 409.758] AUDIT: Wed May 23 11:37:35 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 409.759] AUDIT: Wed May 23 11:37:35 2018: 14237: client 12 disconnected
[ 514.498] (II) config/udev: removing device LITE-ON Technology USB NetVista Full Width Keyboard.
[ 514.503] (II) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Close
[ 514.503] (II) UnloadModule: “evdev”
[ 514.503] (II) config/udev: removing device Lenovo Optical USB Mouse
[ 514.509] (II) evdev: Lenovo Optical USB Mouse: Close
[ 514.509] (II) UnloadModule: “evdev”
[ 607.063] (II) config/udev: removing device Power Button
[ 607.076] (II) evdev: Power Button: Close
[ 607.076] (II) UnloadModule: “evdev”
[ 607.079] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 607.079] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 607.079] () Power Button: Applying InputClass “system-keyboard”
[ 607.079] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 607.079] () Power Button: always reports core events
[ 607.079] () evdev: Power Button: Device: “/dev/input/event1”
[ 607.089] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 607.089] (–) evdev: Power Button: Found keys
[ 607.089] (II) evdev: Power Button: Configuring as keyboard
[ 607.089] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 607.089] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 607.089] () Option “xkb_rules” “evdev”
[ 607.089] () Option “xkb_layout” “us”
[ 607.217] (II) config/udev: removing device Power Button
[ 607.227] (II) evdev: Power Button: Close
[ 607.227] (II) UnloadModule: “evdev”
[ 607.228] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 607.228] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 607.228] () Power Button: Applying InputClass “system-keyboard”
[ 607.228] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 607.228] () Power Button: always reports core events
[ 607.228] () evdev: Power Button: Device: “/dev/input/event0”
[ 607.241] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 607.241] (–) evdev: Power Button: Found keys
[ 607.241] (II) evdev: Power Button: Configuring as keyboard
[ 607.241] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0”
[ 607.241] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 607.241] () Option “xkb_rules” “evdev”
[ 607.241] () Option “xkb_layout” “us”
[ 607.308] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 607.308] (II) No input driver specified, ignoring this device.
[ 607.308] (II) This device may have been added with another device file.
[ 751.555] AUDIT: Wed May 23 11:43:17 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 751.556] AUDIT: Wed May 23 11:43:17 2018: 14237: client 12 disconnected
[ 767.007] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/mouse0)
[ 767.007] (II) No input driver specified, ignoring this device.
[ 767.008] (II) This device may have been added with another device file.
[ 767.077] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/event2)
[ 767.077] () Lenovo Optical USB Mouse: Applying InputClass “evdev pointer catchall”
[ 767.077] (II) Using input driver ‘evdev’ for ‘Lenovo Optical USB Mouse’
[ 767.077] () Lenovo Optical USB Mouse: always reports core events
[ 767.077] () evdev: Lenovo Optical USB Mouse: Device: “/dev/input/event2”
[ 767.128] (–) evdev: Lenovo Optical USB Mouse: Vendor 0x17ef Product 0x6019
[ 767.128] (–) evdev: Lenovo Optical USB Mouse: Found 3 mouse buttons
[ 767.128] (–) evdev: Lenovo Optical USB Mouse: Found scroll wheel(s)
[ 767.128] (–) evdev: Lenovo Optical USB Mouse: Found relative axes
[ 767.128] (–) evdev: Lenovo Optical USB Mouse: Found x and y relative axes
[ 767.128] (II) evdev: Lenovo Optical USB Mouse: Configuring as mouse
[ 767.128] (II) evdev: Lenovo Optical USB Mouse: Adding scrollwheel support
[ 767.128] () evdev: Lenovo Optical USB Mouse: YAxisMapping: buttons 4 and 5
[ 767.128] () evdev: Lenovo Optical USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 767.128] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1:1.0/input/input5/event2”
[ 767.128] (II) XINPUT: Adding extended input device “Lenovo Optical USB Mouse” (type: MOUSE, id 8)
[ 767.128] (II) evdev: Lenovo Optical USB Mouse: initialized for relative axes.
[ 767.129] () Lenovo Optical USB Mouse: (accel) keeping acceleration scheme 1
[ 767.129] () Lenovo Optical USB Mouse: (accel) acceleration profile 0
[ 767.129] () Lenovo Optical USB Mouse: (accel) acceleration factor: 2.000
[ 767.129] () Lenovo Optical USB Mouse: (accel) acceleration threshold: 4
[ 767.219] (II) config/udev: Adding input device LITE-ON Technology USB NetVista Full Width Keyboard. (/dev/input/event3)
[ 767.219] () LITE-ON Technology USB NetVista Full Width Keyboard.: Applying InputClass “evdev keyboard catchall”
[ 767.219] () LITE-ON Technology USB NetVista Full Width Keyboard.: Applying InputClass “system-keyboard”
[ 767.219] (II) Using input driver ‘evdev’ for ‘LITE-ON Technology USB NetVista Full Width Keyboard.’
[ 767.219] () LITE-ON Technology USB NetVista Full Width Keyboard.: always reports core events
[ 767.219] () evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Device: “/dev/input/event3”
[ 767.219] (–) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Vendor 0x4b3 Product 0x3025
[ 767.219] (–) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Found keys
[ 767.219] (II) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Configuring as keyboard
[ 767.219] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.2/3-4.2:1.0/input/input6/event3”
[ 767.219] (II) XINPUT: Adding extended input device “LITE-ON Technology USB NetVista Full Width Keyboard.” (type: KEYBOARD, id 9)
[ 767.219] () Option “xkb_rules” “evdev”
[ 767.220] () Option “xkb_layout” “us”
[ 805.205] (II) config/udev: removing device Lenovo Optical USB Mouse
[ 805.211] (II) evdev: Lenovo Optical USB Mouse: Close
[ 805.211] (II) UnloadModule: “evdev”
[ 805.211] (II) config/udev: removing device LITE-ON Technology USB NetVista Full Width Keyboard.
[ 805.220] (II) evdev: LITE-ON Technology USB NetVista Full Width Keyboard.: Close
[ 805.220] (II) UnloadModule: “evdev”
[ 1155.799] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 1155.800] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 disconnected
[ 1155.800] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 1155.801] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 disconnected
[ 1155.801] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 1155.802] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 1155.802] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 disconnected
[ 1155.803] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 disconnected
[ 1155.803] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 1155.804] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 disconnected
[ 1155.804] AUDIT: Wed May 23 11:50:01 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 1156.309] AUDIT: Wed May 23 11:50:02 2018: 14237: client 12 connected from local host ( uid=0 gid=0 pid=14901 )
[ 1156.309] AUDIT: Wed May 23 11:50:02 2018: 14237: client 12 disconnected
[ 1209.651] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/mouse0)
[ 1209.651] (II) No input driver specified, ignoring this device.
[ 1209.651] (II) This device may have been added with another device file.
[ 1209.724] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/event2)
[ 1209.724] () Lenovo Optical USB Mouse: Applying InputClass “evdev pointer catchall”
[ 1209.724] (II) Using input driver ‘evdev’ for ‘Lenovo Optical USB Mouse’
[ 1209.724] () Lenovo Optical USB Mouse: always reports core events
[ 1209.724] (**) evdev: Lenovo Optical USB Mouse: Device: “/dev/input/event2”
[ 1209.775] (–) evdev: Lenovo Optical USB Mouse: Vendor 0x17ef Product 0x6019
[ 1209.775] (–) evdev: Lenovo Optical USB Mouse: Found 3 mouse buttons
