Hi to all
I am using Cg and OpenGL on a Fedora Core 8 system.
The problem comes up after typing ./configure and trying to start make:
make all-recursive
make[1]: Entering directory /root/Desktop/gpusplatgui' Making all in src make[2]: Entering directory
/root/Desktop/gpusplatgui/src’
/bin/sh …/libtool --tag=CXX --mode=link g++ -g -O2 -o gpusplatgui /usr/lib/libCg.so /usr/lib/libCgGL.so /usr/lib/libGL.so /usr/lib/libglut.so /usr/lib/libpthread.so gpusplatgui.o gpusplatdrr.o
g++: /usr/lib/libglut.so: No such file or directory
make[2]: *** [gpusplatgui] Fehler 1
make[2]: Leaving directory /root/Desktop/gpusplatgui/src' make[1]: *** [all-recursive] Fehler 1 make[1]: Leaving directory
/root/Desktop/gpusplatgui’
make: *** [all] Fehler 2
[root@musca gpusplatgui]# make
make all-recursive
I suspect the error arises because I have libglut.so.3 and libglut.so.3.8.0 in /usr/lib64/ .
I have read in a couple of forums that it helps to establish a symbolic link in the /usr/lib/ directory. Unfortunately sym links are reported to be broken in my case.
What else can I do?
Greetings, Isabella
