CGF prebuilt nodes documentation
@sushant.bahadure
Good to hear that the sample can be run in 6.0.8.1!
Could you share more info to help me to repeat?
  1. Do you run the CGF demo and mini pipeline in host-docker or directly in drive-orin-devkit?
  2. Is there any extra modification of files to make it run correctly?
  3. While you are running the cgf apps, do you ever encounter the issue mentioned in [BUG] DO6081/CGF 5.14 app cannot exit gracefully: rerun failed, reporting internel errors and require reboot (nvidia.com)
