I’m currently using Sekonix AR0231 SF3324/5/6-100 (RCCB sensor) cameras with the nvmimg_cap sample. I’m able to use a sample configuration that shoots in raw12 at 1920x1208. Is it possible to shoot with a different input/surface format and to also shoot at a different resolution?
Thank you for the reply. I looked at the img_cap documentation further especially the “Camera Power Control” and “Camera Register Control” sections. I have also successfully run the examples provided. Where can I find more information on the other register addresses and values available to control as well as additional information on how to change such other registers?
I’m trying to control the shooting resolution of the AR0231 camera sensor. Currently, the default resolution is 1920x1208 and I would like to shoot at a smaller resolution. Also, is it possible to encode a different surface format (i.e. RGB) using such registers?
I have tried to change the config passed with “nvmimg_cap” and the application works for all the included configs for the AR0231 lens. However, when I modify the resolution parameter (to something other than “1920x1208 or 1920x1008”) in the .conf file and run “nvmimg_cap” I get the following errors:
nvmedia: ERROR: CaptureInit: 360
nvmedia: ERROR: Init: doesn't support the given property, check input param and image property
nvmedia: ERROR: CaptureInit: Failed to initialize ISC devices
nvmedia: ERROR: CaptureInit: Failed to initialize Capture
nvmedia: ERROR: main: Failed to Initialize Capture
Is there some other way to change the shooting resolution to a custom resolution using the configuration files?
