• Hardware Platform (Jetson / GPU) Jetson Xavier
• DeepStream Version 4.0.2
• JetPack Version (valid for Jetson only) 4.3
• TensorRT Version 6.0.1
When I try objectDetector_Yolo project, I change the network model with yolov3 network trained with 4 classes.
I changed the code as follow:
config_infer_primary_yoloV3.txt
num-detected-classes=80 =>> num-detected-classes=4
label.txt
car
person
bicycle
bus
nvdsparsebbox_Yolo.cpp
static const int NUM_CLASSES_YOLO = 80; =>> static const int NUM_CLASSES_YOLO = 4;
However, when running deepstream-app -c deepstream_app_config_yoloV3.txt
, I cna load the model and build the TensorRT Engine, but still have an error of class mismatch. Can you help me?
Using winsys: x11
Creating LL OSD context new
0:00:00.891588919 12995 0x7f1c002240 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
Loading pre-trained weights...
Loading complete!
Total Number of weights read : 61592497
layer inp_size out_size weightPtr
(1) conv-bn-leaky 3 x 416 x 416 32 x 416 x 416 992
(2) conv-bn-leaky 32 x 416 x 416 64 x 208 x 208 19680
(3) conv-bn-leaky 64 x 208 x 208 32 x 208 x 208 21856
(4) conv-bn-leaky 32 x 208 x 208 64 x 208 x 208 40544
(5) skip 64 x 208 x 208 64 x 208 x 208 -
(6) conv-bn-leaky 64 x 208 x 208 128 x 104 x 104 114784
(7) conv-bn-leaky 128 x 104 x 104 64 x 104 x 104 123232
(8) conv-bn-leaky 64 x 104 x 104 128 x 104 x 104 197472
(9) skip 128 x 104 x 104 128 x 104 x 104 -
(10) conv-bn-leaky 128 x 104 x 104 64 x 104 x 104 205920
(11) conv-bn-leaky 64 x 104 x 104 128 x 104 x 104 280160
(12) skip 128 x 104 x 104 128 x 104 x 104 -
(13) conv-bn-leaky 128 x 104 x 104 256 x 52 x 52 576096
(14) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 609376
(15) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 905312
(16) skip 256 x 52 x 52 256 x 52 x 52 -
(17) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 938592
(18) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 1234528
(19) skip 256 x 52 x 52 256 x 52 x 52 -
(20) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 1267808
(21) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 1563744
(22) skip 256 x 52 x 52 256 x 52 x 52 -
(23) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 1597024
(24) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 1892960
(25) skip 256 x 52 x 52 256 x 52 x 52 -
(26) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 1926240
(27) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 2222176
(28) skip 256 x 52 x 52 256 x 52 x 52 -
(29) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 2255456
(30) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 2551392
(31) skip 256 x 52 x 52 256 x 52 x 52 -
(32) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 2584672
(33) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 2880608
(34) skip 256 x 52 x 52 256 x 52 x 52 -
(35) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 2913888
(36) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 3209824
(37) skip 256 x 52 x 52 256 x 52 x 52 -
(38) conv-bn-leaky 256 x 52 x 52 512 x 26 x 26 4391520
(39) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 4523616
(40) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 5705312
(41) skip 512 x 26 x 26 512 x 26 x 26 -
(42) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 5837408
(43) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 7019104
(44) skip 512 x 26 x 26 512 x 26 x 26 -
(45) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 7151200
(46) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 8332896
(47) skip 512 x 26 x 26 512 x 26 x 26 -
(48) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 8464992
(49) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 9646688
(50) skip 512 x 26 x 26 512 x 26 x 26 -
(51) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 9778784
(52) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 10960480
(53) skip 512 x 26 x 26 512 x 26 x 26 -
(54) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 11092576
(55) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 12274272
(56) skip 512 x 26 x 26 512 x 26 x 26 -
(57) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 12406368
(58) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 13588064
(59) skip 512 x 26 x 26 512 x 26 x 26 -
(60) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 13720160
(61) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 14901856
(62) skip 512 x 26 x 26 512 x 26 x 26 -
(63) conv-bn-leaky 512 x 26 x 26 1024 x 13 x 13 19624544
(64) conv-bn-leaky 1024 x 13 x 13 512 x 13 x 13 20150880
(65) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 24873568
(66) skip 1024 x 13 x 13 1024 x 13 x 13 -
(67) conv-bn-leaky 1024 x 13 x 13 512 x 13 x 13 25399904
(68) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 30122592
(69) skip 1024 x 13 x 13 1024 x 13 x 13 -
(70) conv-bn-leaky 1024 x 13 x 13 512 x 13 x 13 30648928
(71) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 35371616
(72) skip 1024 x 13 x 13 1024 x 13 x 13 -
(73) conv-bn-leaky 1024 x 13 x 13 512 x 13 x 13 35897952
(74) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 40620640
(75) skip 1024 x 13 x 13 1024 x 13 x 13 -
(76) conv-bn-leaky 1024 x 13 x 13 512 x 13 x 13 41146976
(77) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 45869664
(78) conv-bn-leaky 1024 x 13 x 13 512 x 13 x 13 46396000
(79) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 51118688
(80) conv-bn-leaky 1024 x 13 x 13 512 x 13 x 13 51645024
(81) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 56367712
(82) conv-linear 1024 x 13 x 13 27 x 13 x 13 56395387
(83) yolo 27 x 13 x 13 27 x 13 x 13 56395387
(84) route - 512 x 13 x 13 56395387
(85) conv-bn-leaky 512 x 13 x 13 256 x 13 x 13 56527483
(86) upsample 256 x 13 x 13 256 x 26 x 26 -
(87) route - 768 x 26 x 26 56527483
(88) conv-bn-leaky 768 x 26 x 26 256 x 26 x 26 56725115
(89) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 57906811
(90) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 58038907
(91) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 59220603
(92) conv-bn-leaky 512 x 26 x 26 256 x 26 x 26 59352699
(93) conv-bn-leaky 256 x 26 x 26 512 x 26 x 26 60534395
(94) conv-linear 512 x 26 x 26 27 x 26 x 26 60548246
(95) yolo 27 x 26 x 26 27 x 26 x 26 60548246
(96) route - 256 x 26 x 26 60548246
(97) conv-bn-leaky 256 x 26 x 26 128 x 26 x 26 60581526
(98) upsample 128 x 26 x 26 128 x 52 x 52 -
(99) route - 384 x 52 x 52 60581526
(100) conv-bn-leaky 384 x 52 x 52 128 x 52 x 52 60631190
(101) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 60927126
(102) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 60960406
(103) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 61256342
(104) conv-bn-leaky 256 x 52 x 52 128 x 52 x 52 61289622
(105) conv-bn-leaky 128 x 52 x 52 256 x 52 x 52 61585558
(106) conv-linear 256 x 52 x 52 27 x 52 x 52 61592497
(107) yolo 27 x 52 x 52 27 x 52 x 52 61592497
Output blob names :
yolo_83
yolo_95
yolo_107
Total number of layers: 257
Total number of layers on DLA: 0
Building the TensorRT Engine...
Building complete!
0:05:35.819364291 12995 0x7f1c002240 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/nvidia/deepstream_sdk_v4.0.2_jetson/sources/objectDetector_Yolo/model_b1_int8.engine
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
WARNING: Num classes mismatch. Configured:4, detected by network: 80
