i am using dusty-nv/jetson-inference/imagenet-camera. I want to ask how could we change the confidence level of a label like it should display a dog only when the probability is greater than 0.9 instead of 0.5 which is set by default.
You can add check before showing the results.
For example:
https://github.com/dusty-nv/jetson-inference/blob/master/imagenet-camera/imagenet-camera.cpp#L164
if( font != NULL && <b>confidence > 0.9</b> )
char str[256];
sprintf(str, "%05.2f%% %s", confidence * 100.0f, net->GetClassDesc(img_class));
font->RenderOverlay((float4*)imgRGBA, (float4*)imgRGBA, camera->GetWidth(), camera->GetHeight(),
str, 0, 0, make_float4(255.0f, 255.0f, 255.0f, 255.0f));
