Change default current limit of jetson xavier
I ran mobile face on jetson xavier, while handling 10 cameras currently, the dmesg fired a warning OC ALARM 0x00000001, it maybe be over-current limit.
The default of crit_current_limit_0 is 3600ma, I increased the value to 5000ma, the warning OC ALARM 0x00000001 disappeared.
I based on solution on topic: System throttled due to over-current?
If I increase that value is there any risk to the jetson xavier circuit?
