Change displayColor when selected/highlighted?
Is there a simple way to change the color of a mesh when it is selected/highlighted by adding something simple to the (static) usda file? I’ve seen some amazing complex animations upon selection/highlighting, but I just want a simple color change.
Thanks in advance, Chuck
Ah, I’ve found the whole ActionGraph/PushGraph workflow in Composer…
A “simple way.” Simpler suggestions welcomed:
I do not have a better suggestion that that. Sorry. If that works great.
No apology necessary. Just just throwing it out there to see if there’s a more efficient way. This works fine.
FYI, for the most bulletproof use, put an array maker between the Select If and the Write Prim…
